well83
17 -
Can't boot with 23.05 or later builds on s905x2 (g12a) or s905x3 (sm1)
well83 replied to well83's topic in Amlogic CPU Boxes
@Devmfc I confirm it works. Thanks Devmfc -
@adrian0541 Right click on panel doesn't work? Try to install whisker from apt. I dont know cause i use armbian headless and on desktop i have kde. So i cant help you here.
@adrian0541 Hi ubuntu version is jammy 6.1.11 Working s905x3 are in dtb file a95xf3-air x96-air and H96 Max version with s905x3 (be careful when choosing this model cause there are many with same name but other cpu brands)
@adrian0541 Hi. For audio try to use ubuntu version of build . If there no audio it apears after install on emmc. And for wifi try to run armbian config
@adrian0541 Hi. just change extlinux file.
@adrian0541 Hi. Try sei610 dtb file or others that support s905x3 processor cause sei510 i think it is for s905x2
@adrian0541 Hi. Last working version is 6.1.11. https://fi.mirror.armbian.de/archive/aml-s9xx-box/archive/ They changed something in new versions so the uboot file doesnt work anymore. -
@boxonly26https://fi.mirror.armbian.de/archive/aml-s9xx-box/archive/
Did you see if your Virtual Disk Service is enabled? type: sc query vds , if stopped type: net start vds. See if automount is enabled. diskpart --> automount --> automount enable. If this bug steel persists and if you are using image writer often i would reinstall windows -
@Maxxim It's something with windows 10 or 11 that it dindnt asign drive letters. Somebody have this bug somebody no. I dont have this bug on my windows 11. My windows asigns drive letters with very same image files that you are using. If i use Raspbery pi imager and Balena etcher i have letter assigned but with rufus and fedora media writer its not assigned -
@tgillett Ok try to use this u-boot file u-boot.ext ---------------------------- One question. What dtb file are you using on Armbian_20.10_Arm-64_bullseye_current_5.9.0_desktop.img.xz as i see there is no specific dtb for your box inside dtb folder? -
@Maxxim Look in this page maybe there is solution. https://gearupwindows.com/fix-windows-11-10-doesnt-assign-drive-letter-to-external-and-usb-flash-drives/#how-to-disable-8216-hidden-and-8216-no-default-driver-letter-attributes -
@Maxxim Hi if you dont see boot partition download last version of bootice go to Partition Management choose boot and assign drive letter -
@tgillett Hi on 6.1.11 1. edit extlinux.conf your dtb is this meson-sm1-a95xf3-air.dtb or this meson-sm1-a95xf3-air-gbit.dtb 2. rename u-boot-s905x2-s922 to u-boot.ext 3. profit -------------------------------------------------------- If you want to try 6.1.30 i uploaded modified u-boot.ext that one guy from 4pda sent to me. You have to add it in your boot directory than change extlinux.conf u-boot.ext
