Justly5653
  1. I tried to post there, but was told that since I'm not a client of invision forums, I can't report bugs: https://invisioncommunity.com/forums/topic/476628-mfa-multi-factor-authentication-not-working-with-firefox/ :(
  2. Sorry, I was unsure which category to post this under, feel free to move it if there is a better place. I enabled "multi factor authentication" for my forum account (ie. "the code thingy that changes with time"), but the window to ask for the code doesn't show up with Firefox (this is the latest version of Firefox 115.0.3 (64-bit) on MacOS). It does with with Safari though.
  3. Thanks, that worked. However the edge kernel doesn't seem to have the eCryptfs module (the one which can be used to encrypt home directories: https://man.archlinux.org/man/extra/ecryptfs-utils/ecryptfs-migrate-home.8.en). When I tried to go back to the current kernel (again with armbian-config -> system -> other), the whole system just didn't start after reboot. I'll have to re-flash my eMMC storage with armbian.
  4. Hi Igor, thanks for the quick reply! How can I do that? Is there a specific package I should install? Thanks.
  5. Hi, this seems to be an issue again with Odroid XU4 + Armbian. When I try to bring up a Wireguard interface I get: jul 17 12:52:30 odroidxu4 wg-quick[1940]: [#] ip link add wg0 type wireguard jul 17 12:52:30 odroidxu4 wg-quick[1949]: Error: Unknown device type. jul 17 12:52:30 odroidxu4 wg-quick[1952]: Unable to access interface: Protocol not supported Both wireguard and wireguard tools are up to date, I restarted the device multiple times. "sudo dkms status" doesn't output anything. Based on "sudo apt update" / "sudo apt dist-upgrade" I'm up to date. Looks like the wireguard module isn't loaded at all: $ sudo lsmod | grep wire <no output> Version information: $ uname -a Linux odroidxu4 5.4.243-odroidxu4 #1 SMP PREEMPT Mon May 22 13:57:29 UTC 2023 armv7l GNU/Linux $ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Armbian 23.05.1 bookworm Release: 12 Codename: bookworm I tried to find some "odroidxu4 specific kernel headers package", but that fails: $ sudo dpkg-reconfigure linux-headers-current-odroidxu4 Compiling headers - please wait ... Makefile:583: arch//Makefile: No existe el fichero o el directorio make: *** No hay ninguna regla para construir el objetivo 'arch//Makefile'. Alto. Makefile:927: scripts/Makefile.ubsan: No existe el fichero o el directorio make: *** No hay ninguna regla para construir el objetivo 'scripts/Makefile.ubsan'. Alto. Makefile:927: scripts/Makefile.ubsan: No existe el fichero o el directorio make: *** No hay ninguna regla para construir el objetivo 'scripts/Makefile.ubsan'. Alto. How can I make Wireguard usable on the OdroidXU4 with Armbian?
