13 -
Sure...I will. I am going to test your latest and get back to you. Once it passes, okay. If it fails, okay. I will use a paste service and link for the output. Seth
[π³|π¨] fatal: couldn't find remote ref th1520-v1.3.1 [π³|πΈ] improved_git try 3 failed, retrying in 10 seconds [ git fetch --recurse-submodules=no --no-tags https://github.com/riscv-software-src/opensbi th1520-v1.3.1 ] That is the error so far. I will look through the files now. Seth P.S. Also...see below: [π³|π¨] dpkg-deb: building package 'linux-dtb-edge-thead' in '/armbian/output/packages-hashed/global/linux-dtb-edge-thead_6.5-rc1-Sa3ce-D85a2-P0000-Caf2fHfe66-HK01ba-Vc222-Bc698-R448a_riscv64.deb'. [π³|π±] Packaging linux-headers [ thead linux-thead-edge ] [π³|π¨] '/armbian/.tmp/work-2b6f854c-1cc8-4ecd-9d31-fad769d55101/deb-k-linux-headers-edge-thead-AtuSw/lib/modules/6.5.0-rc1-edge-thead/build' -> '/usr/src/linux-headers-6.5.0-rc1-edge-thead' [π³|π¨] '/armbian/cache/sources/linux-kernel-worktree/6.5__thead__riscv64/.config' -> '/armbian/.tmp/work-2b6f854c-1cc8-4ecd-9d31-fad769d55101/deb-k-linux-headers-edge-thead-AtuSw/usr/src/linux-headers-6.5.0-rc1-edge-thead/.config' find: βModule.symversβ: No such file or directory [π³|π₯] Error 1 occurred in SUBSHELL [ SUBSHELL at /armbian/lib/functions/compilation/kernel-debs.sh:402 ] [π³|π₯] Error 1 occurred in main shell [ at /armbian/lib/functions/compilation/kernel-debs.sh:413
Okay, I will try to git clone your repo. and then try w/ your changes... Seth
'/armbian/cache/sources/linux-kernel-worktree/6.5__thead__riscv64/.config' -> '/armbian/.tmp/work-2074307d-fc24-46bf-858e-4419a1d10628/deb-k-linux-headers-edge-thead-reOFS/usr/src/linux-headers-6.5.0-rc1-edge-thead/.config' find: βModule.symversβ: No such file or directory That is the error w/ me updating to the branch you have for beaglev-ahead.csc listed after using: git checkout canIPetDatDawg
I can build for beaglev.csc but not for beaglev-ahead.csc for some reason. How should I change to your specific branch that is needed? Okay...I got it. I used `submodule`.
Okay @KREYREN, I have been unable to test. I tried. It seems I am getting errors quickly. [π±] -----------------Relaunching in Docker after 2s------------------ [ here comes the π³ ] [π³|πΏ] Applying cmdline param [ 'PREFER_DOCKER': '(unset)' --> 'no' early ] [π³|πΏ] Applying cmdline param [ 'BUILD_MINIMAL': '(unset)' --> 'yes' early ] [π³|πΏ] Applying cmdline param [ 'BUILD_DESKTOP': '(unset)' --> 'no' early ] [π³|πΏ] Applying cmdline param [ 'ARMBIAN_BUILD_UUID': '(unset)' --> '95690538-bdaa-4c73-948e-37ea0197d926' early ] [π³|πΏ] Applying cmdline param [ 'EXPERT': '(unset)' --> 'yes' early ] [π³|π±] Skip cmdline param [ 'ARMBIAN_RELAUNCHED': already set to 'yes' early ] [π³|πΏ] Applying cmdline param [ 'BRANCH': '(unset)' --> 'edge' early ] [π³|πΏ] Applying cmdline param [ 'BOARD': '(unset)' --> 'beaglev-ahead' early ] [π³|πΏ] Applying cmdline param [ 'SKIP_LOG_ARCHIVE': '(unset)' --> 'yes' early ] [π³|πΏ] Applying cmdline param [ 'SET_OWNER_TO_UID': '(unset)' --> '1000' early ] [π³|πΏ] Applying cmdline param [ 'RELEASE': '(unset)' --> 'sid' early ] [π³|πΏ] Applying cmdline param [ 'KERNEL_CONFIGURE': '(unset)' --> 'no' early ] [π³|π±] Starting single build process [ beaglev-ahead ] [π³|π±] Checking [ basic host setup ] [π³|π±] Build host OS release [ jammy ] [π³|π±] Build host architecture [ amd64 ] [π³|π₯] error! [ No such BOARD 'beaglev-ahead'; no board config file found. ] [π³|π₯] Exiting with error 43 [ at /armbian/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 config_source_board_file() --> lib/functions/main/config-prepare.sh:127 do_with_logging() --> lib/functions/logging/section-logging.sh:81 do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:23 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [π³|π₯] Cleaning up [ please wait for cleanups to finish ] [π³|πΏ] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-95690538-bdaa-4c73-948e-37ea0197d926.log.ans ] [π³|πΏ] Share log manually (or SHARE_LOG=yes): [ curl --data-binary @output/logs/log-build-95690538-bdaa-4c73-948e-37ea0197d926.log.ans https://paste.next.armbian.com/log ] [π₯] -------------Docker run failed after 3s-------------------------- [ π³ failed ] [π±] Cleaning up [ please wait for cleanups to finish ] I will keep trying. Seth P.S. I found my error. Testing is underway.
Hello, Okay. I will get on my Debian Bookworm Distro soon and test. Yes, this is at my own precaution. So, not a big deal on your side. I take full responsibility. Seth P.S. I have gone over the pull request already. I will test soon. Thank you. I will update in the next week or so. Who knows? I may update you sooner.
Okay @KREYREN, I can test but I do not have the SiPeed. I do have a board w/ the TH1520 on it, though. But sure, we can try this idea. I will go to the pull request soon and return service. Seth P.S. I have been trying a repo. online for the BeagleV-Ahead recently but it keeps changing and I have been unable to keep up w/ changes so far. It seems that bash works w/in the builds for Armbian. So, I have been trying to build around bash scripts w/in: 1. /build/userpatches/source/families/My_File.conf
@Igor Seth here. I made a .conf file in /userpatches/source/families/My.conf to handle the build around this bunch of source: https://github.com/silver2row/xuantie-ubuntu-armbian . So, and yes, that is a clone of another build I found online. I will post the build soon and reply once I see anyone replying. Seth P.S. The build used to work but the git pull pulled in some new ideas and other source. So, I have to remake the build for Armbian in the My.conf file in /userpatches/source/families/. Also, it actually patches the kernel like you asked from beagleboard.org Linux kernel(s) w/ some updates and removals.
Hello, No sir. I am not using a patch. I was just pushing 6.5.x thinking I could. I have soon realized that Armbian carries specific kernels for current and edge, respectively. Seth Oh! P.S. Yes sir, I was using a kernels from my repo. clone of the upmost edge kernels. I was also trying to learn how to implement my clone of u-boot... My older scripts failed (as usual) but I found a good way to build w/out the current offerings. I can dig them up but it is nothing too fancy. At first, I used a xuantie-ubuntu repo clone, tied everything into a Makefile, and failed miserably. Then, I tried bash scripts one by one until I just made an image. Sir, also, I have not gained too much knowledge so far in furthering my experience in the field for now. I wanted to make a quick post to support their endeavors since I use their boards and have some, if any, knowledge on their docs. pages and just wanted to be a community person w/ their org. Anyway, I will reinvest time soon. If you need any additional info. or data, please let me know.
https://pastebin.com/S8CuKSR6 Has some interesting info. from my development desktop which does not allow me to parse a random Makefile w/in the build from a github repo. Seth P.S. If anyone can point me to the right direction, that would be helpful! I am in a stuck-cannot-move method right now.
I cloned a repo. and am currently trying to build for this board build: GitHub - silver2row/armbian-userpatches-example-BeagleV-Ahead: reference implementation of having a unique device completely configured via userpatches. I will be uploading some other files soon to update people that are interested in the build around armbian and updated/upgraded kernels and u-boot variables. Seth P.S. If you have any words edgewise, please do consider to chat a bit on this forum in this post.
Hello, There is a new BeagleV-Ahead I would like to see have Armbian support. * T-Head TH1520 (quad-core Xuantie C910 processor) and etc... I was trying to get support and I wanted to reach out. So, here I am. I am making a .csc file now which hopefully one day will be a full-blown .conf file w/ xxx_defconfig support. Seth P.S. Please let me know what steps I need to take to get support.
