alexc
7 -
@Nick A No problem. Thanks for your Armbian build as well! I am also looking forward to mainline. Currently I still didn't find open source Mesa driver for Allwinner BSP, GLES is only available as pre-compiled binary for Debian (haven't tested it but it's in the Radxa images). There already are mainline Mesa/Linux IMG GPU supports so I hope things can be ported to mainline soon. Please let me know if anyone finds the source code for Mesa BSP.
@Nick A Oh yeah, I did change a few things as well for type c. Maybe the drm heap changes are not needed after all. Looking at my changes. husb311 is now under drivers/power/typec, so just enable it. et7304 is not included in the original bsp, radxa team added them later so simply apply this same patch. https://github.com/radxa/allwinner-bsp/commit/156b6578cc173855b41ea311a229403ccbadb17c
@Nick A @Bones558 Hi there, I am not sure if that's definitely due to DRM heap. But I fixed that driver and it could be built now. I didn't know if USB C DP works or not before but it is working now (on a USB C monitor, maybe needs a few re-plug). I opened a PR on Radxa allwinner-bsp github (https://github.com/radxa/allwinner-bsp/pull/11), you can also test it out.
I have a Radxa Zero 3E and was facing the same issue. Since RK3566 is a stripped down version of RK3588. I figured the quirks on RK3588 might be able to apply to RK3566 as well. The issue seems to be fixed now after I implemented these quirks taken from rk3588-base.dtsi on top of rk356x-base.dtsi. tested on Linux 6.17.9 and 6.18.0-rc7(Armbian linux-edge-rockchip64) usb_host1_xhci: usb@fd000000 { compatible = "rockchip,rk3568-dwc3", "snps,dwc3"; reg = <0x0 0xfd000000 0x0 0x400000>; interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru CLK_USB3OTG1_REF>, <&cru CLK_USB3OTG1_SUSPEND>, <&cru ACLK_USB3OTG1>; clock-names = "ref_clk", "suspend_clk", "bus_clk"; dr_mode = "host"; phys = <&usb2phy0_host>, <&combphy1 PHY_TYPE_USB3>; phy-names = "usb2-phy", "usb3-phy"; phy_type = "utmi_wide"; power-domains = <&power RK3568_PD_PIPE>; resets = <&cru SRST_USB3OTG1>; snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + snps,dis-u2-freeclk-exists-quirk; + snps,dis-del-phy-power-chg-quirk; + snps,dis-tx-ipgap-linecheck-quirk; status = "disabled"; }; If anyone else has other RK356x devices please try it out and I think it would be nice if someone could submit a patch to mainline kernel dts.
well I guess I am too naïve about this lol. That's not the same as Raspberry Pi OS. I think Armbian is built for certain use cases. I tried CoreELEC, CEC and hardware acceleration work as expected. I understand maybe it's hard to bring all the stuff to the same distro/repo. Thanks for all the effort! btw now I know CEC is not modularized so it's not in /lib/modules. But CEC (at least cec-client or kodi) still won't work on Armbian
I am trying to use radxa-zero with HDMI CEC support on Armbian debian. I tried all different Armbian debian versions, lsmod never give me module cec So I took a look at images provided by radxa (https://github.com/radxa-build/radxa-zero/releases/tag/20220801-0213, not armbian ones), cec is loaded by default I think this is the key: /lib/modules/SOME_KERNEL/kernel/drivers/media/cec/core/cec.ko This is in their image but not /lib/modules/6.1.11-meson64 folder (I guess also not in other kernel versions) If that's the case, CEC should not work on any meson64 devices. I saw CONFIG_CEC_CORE=y is in config. btw, another possible related missing module is meson_dw_hdmi.ko Could someone take a look and figure out why they are not there? Really appreciate your help!
Hi everyone, I think I found a "solution" for Radxa Zero 1GB, at least for Debian Bookworm. I used armbian 22.08.1 Bullseye (Armbian_22.08.1_Radxa-zero_bullseye_current_5.10.139.img.xz) and apt upgraded everything to the latest (kernel == 6.1.11) I guess armbian 23.02.1 Bullseye (Armbian_23.02.1_Radxa-zero_bullseye_current_6.1.14.img.xz) should work too? Anyway, and then I flashed armbian 23.05.1 Bookworm (Armbian_23.5.1_Radxa-zero_bookworm_current_6.1.30.img.xz) (kernel == 6.1.30). I copied the /boot folder with everything == 6.1.11 as well as /lib/modules/6.1.11* to the SD card (need to match the partition UUID in armbianEnv.txt with the new partition) mount /dev/sdb1 MNTPOINT cp -r 6.1.11-meson64/ MNTPOINT/lib/modules rm -r MNTPOINT/boot cp -r boot/ MNTPOINT cp boot_6.1.30/armbianEnv.txt MNTPOINT/boot cd MNTPOINT rm initrd.img.old ln -s boot/initrd.img-6.1.11-meson64 initrd.img.old rm initrd.img ln -s boot/initrd.img-6.1.11-meson64 initrd.img rm vmlinuz.old ln -s boot/vmlinuz-6.1.11-meson64 vmlinuz.old rm vmlinuz ln -s boot/vmlinuz-6.1.11-meson64 vmlinuz umount MNTPOINT It successfully booted into the system. I tried a lot of stuff, but looks like removing both plymouth and fuse3 works. sudo apt remove plymouth fuse3 && sudo apt autoremove I am not sure where plymouth is used, but fuse3 only used by ntfs3g which I don't use at all. after everything, copy everything back and run sudo update-initramfs -c -v -k 6.1.30-meson64 This should update the initramfs. After reboot there will no longer be bootloops. Essentially I believe the problem is in initramfs but I am not sure why.
