kriptonus
  1. Everything is good. At least it's booting to standard screen with set root password.
  2. @Gunjan Gupta Thanks a lot, I'll try to build image and write down. So, I doesn't work as fast as you
  3. Hi, I've tried last version build system, it didn't work also. You mentioned about What do I need to do to change version in build script?
  4. @Gunjan Gupta, Hi! I've tried built image from your's source, but it didn't work also. Nothing on the debug serial. Board isn't starting.
  5. @Gunjan Gupta, Ok, I'm going to try later and write about results.
  6. Hi there! I've just compiled from armbian buil tools a new image for Orange Pi 3 LTS. Then flash it on sdcard, anything was well, but armbian doesn't start at all. Nothing on the HDMI, nothing on the debug serial. Also LED doesn't light. I've tried two images: ubuntu jammy with GNOME and next case XFCE. Both cases didn't work. I've downloaded prebuilt image from armbian.org and it starts well. In my opinion, some problem with custom images in u-boot. but I don't know how to give a diagnosis.
