Ok guys, Hi.
So I have managed to connect box Q96MAX 4k Ultra HD, board MXQ_R2B_LP3_V2.62_220225 via maskrom mode, made EMMC backup, erased it.
btw thanks @MattWestB for your photos of pins https://github.com/MattWestb/R29-MXQ-LP3-V2.3-00908
Anyway,
Box boots armbian legacy from SD card, I have managed to connect to it via SSH, device specs.
Detected board features: │
│ Chip type: RK3228A/B - Serial: URKW46025 00000000032b0c │
│ CPU Leakage: 0x04 - Logic Leakage: 0x04 │
│ Internal flash: eMMC │
│ Wifi device: unknown - Device ID: 02d0:4334
EDIT2:
installed RDP client, can connect to device via RDP...HDMI NO Output
ok so thanks to this post https://github.com/MattWestb/R29-MXQ-LP3-V2.3-00908/blob/main/README.md armbian parameters set to emmc-hs200, ddr3-660 and led-config2, led started to work.
@MattWestB can you please comment how you fixed your box HDMI and wifi?:)
EDIT:
ok so ARMBIAN non legacy boots too, but same problems with WIFI and HDMI no video.
dmesg gives a lot of errors
[ 0.003538] CPU: Testing write buffer coherency: ok
[ 0.004292] /cpus/cpu@f00 missing clock-frequency property
[ 0.004358] /cpus/cpu@f01 missing clock-frequency property
[ 0.004391] /cpus/cpu@f02 missing clock-frequency property
[ 0.004424] /cpus/cpu@f03 missing clock-frequency property
[ 0.004446] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 2.029717] inno-hdmi-phy 12030000.hdmi-phy: error -ENXIO: IRQ index 0 not found
[ 2.030102] inno-hdmi-phy 12030000.hdmi-phy: phy_flag is: 0
[ 2.033084] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb127c87c)
[ 2.033274] dwhdmi-rockchip 200a0000.hdmi: supply avdd-0v9 not found, using dummy regulator
[ 2.033657] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[ 2.033677] dwhdmi-rockchip 200a0000.hdmi: supply avdd-1v8 not found, using dummy regulator
[ 2.034239] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy2)
[ 2.035607] mmc2: new high speed MMC card at address 0001
[ 2.035736] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.037470] mmcblk2: mmc2:0001 Q2J95T 7.28 GiB
[ 2.039082] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb1280568)
[ 3.603319] rockchip-pinctrl pinctrl: unable to find group for node reset-key
[ 15.966192] brcmfmac: brcmf_fw_alloc_request: Unknown chip BCM43342/0
[ 16.859644] systemd[1]: Starting Armbian memory supported logging...
[ 17.040253] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[ 17.091210] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 17.099828] brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
[ 17.144754] systemd[1]: Finished Raise network interfaces.
[ 45.622143] hdmi-audio-codec hdmi-audio-codec.2.auto: Only one simultaneous stream supported!
[ 45.652339] hdmi-audio-codec hdmi-audio-codec.2.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22
[ 45.676365] 100c0000.i2s0-i2s-hifi: ASoC: error at __soc_pcm_open on 100c0000.i2s0-i2s-hifi: -22
i attach log here pls help with wifi/hdmi
dmesg.log
