Hardik Gohil
  1. I have tried with new version too still issue is there
  2. I am not using dvfs. did you mean this patch https://github.com/armbian/build/pull/2352/commits/59cdf431ef691d67d649adbfaf973f9d451823bc#diff-dc13c5522aed383d1b20662d765c5be9f2635553256069dce64f29be94f89b69. I have tried that too which kernel version to try ?
  3. The board is using armada 38x RTC driver and it can be found in kernel logs. Still I am not able to figure out the fix
  4. Hello All, root:# hwclock --systohc root:# while true; do date; hwclock -r; sleep 60; done observing drift of 1 sec. even tried this https://github.com/armbian/build/pull/2352/commits/59cdf431ef691d67d649adbfaf973f9d451823bc#diff-dc13c5522aed383d1b20662d765c5be9f2635553256069dce64f29be94f89b69 specs: Armada 38x RTC driver ARM_GLOBAL_TIMER Board : Marvell Armada A385 DB AP Kernel : 4.14 community help will be grateful Regards Hardik
