ercans
  1. @jock Thank you very much for your reply. I'm using windows, how can I switch to command line while running multitools on tvbox? I couldn't see an option for the multitools command line window. edit: I think he had the same problem as me. Since the topic is closed, I can't ask how it rained. I want to run linux here somehow, even through the sd card. Can you help me do this?
  2. @jock i have h96 max plus rk3328 4gb/64gb (b0807). The device was bricked in the previous android rom update. At startup, the google installer runs and stays that way. I want to install armbian on this device. I followed all the instructions in your first post. The device works very well from sd card with multitool. I copied the armbian version I gave to the image folder of the multitool. I made an erase flash with the multitool. And I burned it again with the multi tool. When I remove the sd card, the android google load screen still opens. Why is my eMMC not being erased even though I have erased flash with the multitool? For this reason, armbian cannot be started either. Even when I want to run armbian from the SD card, it does not see it, the google boot screen opens. All I can do is boot the multitool from the sd card. Erase flash doesn't work. I even short-circuited two pins on the motherboard in case the maskroom mode might work, but in vain. I can't even eraseflash this device in maskroom mode with androidtool, or I can't get chip info in maskroom mode with androidtool. What could be wrong with my device? How can we run this. I would be very grateful for your support. Now it's a matter of greed
