Hi
I'm trying to enable GPU on my custom kernel. I have applied a patch from Nick's repository, But when I allow `gpu` node in the Transpeed device tree, the kernel freezes here:
[ 9.931994] sun50i-h616-codec 5096000.codec: Failed to register against DMAEngine
[ 9.933237] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 9.947692] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 9.955742] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 9.964193] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[ 9.972000] sun8i-ce 1904000.crypto: Register cbc(aes)
[ 9.977448] sun8i-ce 1904000.crypto: Register ecb(aes)
[ 9.982650] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[ 9.988522] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[ 9.994324] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[ 10.054128] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[ 10.150367] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture
[ 10.160265] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22
[ 10.176581] sunxi-snd-mach soc:ahub_dam_mach: probe with driver sunxi-snd-mach failed with error -22
[ 10.355412] videodev: Linux video capture interface: v2.00
[ OK ] Reached target sound.target - Sound Card.
[ 10.394078] Registered IR keymap rc-empty
[ 10.398320] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[ 10.405141] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input4
[ 10.413088] sunxi-ir 7040000.ir: initialized sunXi IR driver
[ 10.475252] panfrost 1800000.gpu: clock rate = 432000000
[ 10.480726] panfrost 1800000.gpu: bus_clock rate = 200000000
When I disable the `gpu` node. The Xserver comes up. However, the videos are playing slowly and the CPU usage is 100%.
Any idea what could be the problem?
