1 -
I am trying to get yrzr opnsense image to boot on my Espressobinv7 with a sata ssd plugged in, I am having trouble with it. Been able to boot the image off an mmc sd card without any issues. But when trying to boot off the ssd it appears to boot halfway but then stop when trying to boot the GEOM managed disk which doesn't show up. I've found out that my issue may be related that i am booting off u-boot Armbian 2022.04 and that appears to only have 'scsi' option but not 'sata' ? is this correct? Is there a way i can get existing current u-boot Armbian 2022.04 image to function with 'sata' ? Or is there any way i can force the ssd to be detected when trying to boot via 'scsi'? Am I doing this all wrong? any insight will be much appreciated. Output is below. TIM-1.0 mv_ddr-devel-g251bc63 DDR4 16b 1GB 1CS WTMI-devel-18.12.1-1d97715 WTMI: system early-init SVC REV: 5, CPU VDD voltage: 1.108V Setting clocks: CPU 1000 MHz, DDR 800 MHz CZ.NIC's Armada 3720 Secure Firmware 0b68a33-dirty (May 16 2022 17:51:06) Running on ESPRESSObin NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.6(release):a921da5e NOTICE: BL1: Built : 17:54:27, May 16 2022 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.6(release):a921da5e NOTICE: BL2: Built : 17:54:27, May 16 2022 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.6(release):a921da5e NOTICE: BL31: Built : 17:54:27, May 16 2022 U-Boot 2022.04-armbian (May 16 2022 - 17:50:52 +0000) DRAM: 1 GiB Core: 38 devices, 20 uclasses, devicetree: fit WDT: Not starting watchdog@8300 Comphy chip #0: Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 5 Gbps Comphy-2: SATA0 6 Gbps Target spinup took 0 ms. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIe: Link down MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Globalscale Marvell ESPRESSOBin Board Net: eth0: ethernet@30000 Hit any key to stop autoboot: 0 scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: SanDisk SD6SB1M1 Rev: X231 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) Device 0: (0:0) Vendor: ATA Prod.: SanDisk SD6SB1M1 Rev: X231 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) ... is now current device 1256188 bytes read in 27 ms (44.4 MiB/s) 16032 bytes read in 5 ms (3.1 MiB/s) MMC: no card present Scanning disk sdhci@d0000.blk... Disk sdhci@d0000.blk not ready Scanning disk ahci_scsi.id0lun0... Found 3 disks No EFI system partition Booting /EFI\BOOT\bootaa64.efi Consoles: EFI console Reading loader env vars from /efi/freebsd/loader.env Setting currdev to disk0p1: FreeBSD/arm64 EFI loader, Revision 1.1 Command line arguments: root=PARTUUID=00000000-02 rw rootwait Image base: 0x3e98c000 EFI version: 2.90 EFI Firmware: Das U-Boot (rev 8226.1024) Console: efi (0x1000) Load Path: /EFI\BOOT\bootaa64.efi Load Device: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0)/HD(1,MBR,0x8e6515d4,0x800,0x19000) Trying ESP: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0)/HD(1,MBR,0x8e6515d4,0x800,0x19000) Setting currdev to disk0p1: Trying: /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/Scsi(0,0)/HD(2,MBR,0x8e6515d4,0x19800,0x5e6800) Setting currdev to disk0p2: Loading /boot/defaults/loader.conf Loading /boot/defaults/loader.conf Loading /boot/device.hints Loading /boot/loader.conf console vidconsole is invalid! Available consoles: efi comconsole Loading /boot/loader.conf.local | c- console vidconsole is invalid! no valid co ______ _____ _____ Available c / __ |/ ___ |/ __ | efi | | | | |__/ | | | |___ ___ _ __ ___ ___ comcons | | | | ___/| | | / __|/ _ \ '_ \/ __|/ _ \ | | |__| | | | | | \__ \ __/ | | \__ \ __/ |_____/|_| |_| /__|___/\___|_| |_|___/\___|console vidconsole is invalid! Available consoles: +-------------------console vidconsole is invalid!@@@@@@@@@@@@@@@@@@@@@@@@@@ Available consoles: | @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ 1. Boot Multi user [Enter] | @@@@@ @@@@@ 2. Boot Single user | @@@@@ @@@@@ A|ai3. Escape to loader prompt | @@@@@@@@@@@ @@@@@@@@@@@ | 4. Reboot | \\\\\ ///// | 5. Cons: Dual (Serial primary) | )))))))))))) ((((((((((( | | ///// \\\\\ | Options: | @@@@@@@@@@@ @@@@@@@@@@@ | 6. Kernel: default/kernel (1 of 1) | @@@@@ @@@@@ | 7. Boot Options | @@@@@ @@@@@ | | @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ | | @@@@@@@@@@@@@@@@@@@@@@@@@@@@ +-----------------------------------------+ Autoboot in 0 seconds. [Space] to pause 23.1 ``Quintessential Quail'' console vidconsole is invalid! Available consoles: Loading kernel... /boot/kernel/kernel text=0x2a8 text=0x928b30 text=0x21cf64 data=0x1b25d0 data=0x0+0x38a000 syms=[0x8+0x131940+0x8+0x156d2b] Loading configured modules...! /boot/kernel/pfsync.ko text=0x2f63 text=0x7f1c data=0xb38+0x8 syms=[0x8+0x1830+0x8+0x1192] loading required module 'pf' /boot/kernel/pf.ko text=0xe41c text=0x3e7d4 data=0x59f0+0x3bc syms=[0x8+0x5958+0x8+0x4727] /boot/kernel/if_bridge.ko text=0x36a3 text=0x710c data=0xd38+0x8 syms=[0x8+0x1bd8+0x8+0x15d7] loading required module 'bridgestp' /boot/kernel/bridgestp.ko text=0x12e4 text=0x4acc data=0x2c8+0x28 syms=[0x8+0xb88+0x8+0x6e9] /boot/kernel/if_enc.ko text=0x15ca text=0x934 data=0x750 syms=[0x8+0xca8+0x8+0xb71] /boot/entropy size=0x1000 /boot/kernel/pflog.ko text=0xf78 text=0x898 data=0x430 syms=[0x8+0x9f0+0x8+0x712] /boot/kernel/if_gre.ko text=0x2736 text=0x4938 data=0x8c8+0x40 syms=[0x8+0x16f8+0x8+0xfaf] /boot/kernel/if_lagg.ko text=0x3d27 text=0xa628 data=0xd18+0x8 syms=[0x8+0x1cb0+0x8+0x15bd] loading required module 'if_infiniband' /boot/kernel/if_infiniband.ko text=0x1102 text=0x10fc data=0x300+0x8 syms=[0x8+0x8d0+0x8+0x59a] /boot/kernel/carp.ko text=0x33ec text=0x6e54 data=0xc60+0x48 syms=[0x8+0x1980+0x8+0x1225] /etc/hostid size=0x25 Using DTB provided by EFI at 0x7f00000. EFI framebuffer information: addr, size 0x0, 0x0 dimensions 0 x 0 stride 0 masks 0x00000000, 0x00000000, 0x00000000, 0x00000000 ---<<BOOT>>--- KDB: debugger backends: ddb KDB: current backend: ddb Copyright (c) 1992-2021 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 13.1-RELEASE-p8 stable/23.1-n250461-cf0d42d1ca7 SMP arm64 FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.0-0-gd7b669b3a303) VT: init without driver. module firmware already present! real memory = 1071546368 (1021 MB) avail memory = 1019772928 (972 MB) Starting CPU 1 (1) FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs random: unblocking device. random: entropy device external interface MAP 3eac4000 mode 2 pages 1 MAP 3eac8000 mode 2 pages 3 MAP 3eacc000 mode 2 pages 4 MAP 3fef0000 mode 2 pages 16 kbd0 at kbdmux0 ofwbus0: <Open Firmware Device Tree> simplebus0: <Flattened device tree simple bus> on ofwbus0 simplebus1: <Flattened device tree simple bus> on simplebus0 simple_mfd0: <Simple MFD (Multi-Functions Device)> mem 0x13800-0x138ff,0x13c00-0x13c1f on simplebus1 simple_mfd1: <Simple MFD (Multi-Functions Device)> mem 0x18800-0x188ff,0x18c00-0x18c1f on simplebus1 psci0: <ARM Power State Co-ordination Interface Driver> on ofwbus0 gic0: <ARM Generic Interrupt Controller v3.0> mem 0x1d00000-0x1d0ffff,0x1d40000-0x1d7ffff,0x1d80000-0x1d81fff,0x1d90000-0x1d91fff,0x1da0000-0x1dbffff irq 28 on simplebus1 gpio0: <Armada 37x0 North Bridge GPIO Controller> mem 0x13800-0x138ff,0x13c00-0x13c1f irq 29,30,31,32,33,34,35,36,37,38,39,40 on simple_mfd0 gpiobus0: <OFW GPIO bus> on gpio0 gpio1: <Armada 37x0 South Bridge GPIO Controller> mem 0x18800-0x188ff,0x18c00-0x18c1f irq 41,42,43,44,45 on simple_mfd1 gpiobus1: <OFW GPIO bus> on gpio1 gpioregulator0: <GPIO controlled regulator> on ofwbus0 generic_timer0: <ARMv8 Generic Timer> irq 0,1,2,3 on ofwbus0 Timecounter "ARM MPCore Timecounter" frequency 12500000 Hz quality 1000 Event timer "ARM MPCore Eventtimer" frequency 12500000 Hz quality 1000 cpulist0: <Open Firmware CPU Group> on ofwbus0 cpu0: <Open Firmware CPU> on cpulist0 cpu1: <Open Firmware CPU> on cpulist0 pmu0: <Performance Monitoring Unit> irq 4 on ofwbus0 spi0: <Armada 37x0 SPI controller> mem 0x10600-0x10fff irq 6 on simplebus1 uart0: <Marvell Armada 3700 UART> mem 0x12000-0x121ff irq 9,10,11 on simplebus1 uart0: console (115200,n,8,1) gpioc0: <GPIO controller> on gpio0 gpioc1: <GPIO controller> on gpio1 mvneta0: <NETA controller> mem 0x30000-0x33fff irq 14 on simplebus1 mvneta0: version is 10 mvneta0: Ethernet address: 00:51:82:11:22:00 mdio0: <MDIO> on mvneta0 mdioproxy0: <MII/MDIO proxy, MDIO side> on mdio0 e6000sw0: <Marvell 88E6341> on mdio0 e6000sw0: multi-chip addressing mode (0x1) e6000sw0: CPU port at 0 e6000sw0: fixed port at 0 e6000sw0: PHY at port 1 miibus0: <MII bus> on e6000sw0 e1000phy0: <Marvell 88E1000 Gigabit PHY> PHY 17 on miibus0 e1000phy0: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto e6000sw0: PHY at port 2 miibus1: <MII bus> on e6000sw0 e1000phy1: <Marvell 88E1000 Gigabit PHY> PHY 18 on miibus1 e1000phy1: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto e6000sw0: PHY at port 3 miibus2: <MII bus> on e6000sw0 e1000phy2: <Marvell 88E1000 Gigabit PHY> PHY 19 on miibus2 e1000phy2: none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto e6000sw0: switch is ready. etherswitch0: <Switch controller> on e6000sw0 xhci0: <Generic USB 3.0 controller> mem 0x58000-0x5bfff irq 16 on simplebus1 xhci0: 32 bytes context size, 32-bit DMA usbus0 on xhci0 ehci0: <Marvell Integrated USB 2.0 controller> mem 0x5e000-0x5efff irq 17 on simplebus1 usbus1: EHCI version 1.0 usbus1 on ehci0 safexcel0: <SafeXcel EIP-97 crypto accelerator> mem 0x90000-0xaffff irq 18,19,20,21,22,23 on simplebus1 sdhci_xenon0: <Armada Xenon SDHCI controller> mem 0xd0000-0xd02ff,0x1e808-0x1e80b irq 25 on simplebus1 ahci0: <AHCI SATA controller> mem 0xe0000-0xe0177 irq 27 on simplebus1 ahci0: AHCI v1.30 with 1 6Gbps ports, Port Multiplier supported with FBS ahcich0: <AHCI channel> at channel 0 on ahci0 device_attach: ahcich0 attach returned 6 armv8crypto0: <AES-CBC,AES-XTS,AES-GCM> Timecounters tick every 1.000 msec mvneta0: link state changed to UP e6000sw0port1: link state changed to DOWN e6000sw0port2: link state changed to DOWN e6000sw0port3: link state changed to DOWN usbus0: 5.0Gbps Super Speed USB v3.0 usbus1: 480Mbps High Speed USB v2.0 spibus0: <OFW SPI bus> on spi0 spibus0: <unknown card> at cs 0 mode 0 CPU 0: ARM Cortex-A53 r0p4 affinity: 0 Cache Type = <64 byte D-cacheline,64 byte I-cacheline,VIPT ICache,64 byte ERG,64 byte CWG> Instruction Set Attributes 0 = <CRC32,SHA2,SHA1,AES+PMULL> Instruction Set Attributes 1 = <> Processor Features 0 = <GIC,AdvSIMD,FP,EL3 32,EL2 32,EL1 32,EL0 32> Processor Features 1 = <> Memory Model Features 0 = <TGran4,TGran64,SNSMem,BigEnd,16bit ASID,1TB PA> Memory Model Features 1 = <8bit VMID> Memory Model Features 2 = <32bit CCIDX,48bit VA> Debug Features 0 = <DoubleLock,2 CTX BKPTs,4 Watchpoints,6 Breakpoints,PMUv3,Debugv8> Debug Features 1 = <> Auxiliary Features 0 = <> Auxiliary Features 1 = <> AArch32 Instruction Set Attributes 5 = <CRC32,SHA2,SHA1,AES+VMULL,SEVL> AArch32 Media and VFP Features 0 = <FPRound,FPSqrt,FPDivide,DP VFPv3+v4,SP VFPv3+v4,AdvSIMD> AArch32 Media and VFP Features 1 = <SIMDFMAC,FPHP DP Conv,SIMDHP SP Conv,SIMDSP,SIMDInt,SIMDLS,FPDNaN,FPFtZ> CPU 1: ARM Cortex-A53 r0p4 affinity: 1 Release APs...done ugen1.1: <Marvell EHCI root HUB> at usbus1 ugen0.1: <Generic XHCI root HUB> at usbus0 uhub0 on usbus1 uhub1 on usbus0 uhub0: <Marvell EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 uhub1: <Generic XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0 Trying to mount root from ufs:/dev/ufs/OPNsense [rw]... uhub1: 2 ports with 2 removable, self powered uhub0: 1 port with 1 removable, self powered Root mount waiting for: CAM Root mount waiting for: CAM Root mount waiting for: CAM Root mount waiting for: CAM Root mount waiting for: CAM Root mount waiting for: CAM Root mount waiting for: CAM Root mount waiting for: CAM mountroot: waiting for device /dev/ufs/OPNsense... Mounting from ufs:/dev/ufs/OPNsense failed with error 19. Loader variables: vfs.root.mountfrom=ufs:/dev/ufs/OPNsense vfs.root.mountfrom.options=rw Manual root filesystem specification: <fstype>:<device> [options] Mount <device> using filesystem <fstype> and with the specified (optional) option list. eg. ufs:/dev/da0s1a zfs:zroot/ROOT/default cd9660:/dev/cd0 ro (which is equivalent to: mount -t cd9660 -o ro /dev/cd0 /) ? List valid disk boot devices . Yield 1 second (for background tasks) <empty line> Abort manual input mountroot> ? List of GEOM managed disk devices: mountroot>
