0ka
  1. wwx* thing still happens on ubuntu noble
  2. in the end the only thing that works is connecting a second modem with a slight delay. i also tried network manager gsm.* options for specifying operator-id or device-id for each gsm connection, but they just don't work: operator-id value is ignored (or any value is accepted), setting device-id makes an error (No suitable device found for this connection) i still sometimes get "wwx02358c073be8" interface but whatever...
  3. i have 2 USB LTE modems (quectel ec25) and i most of the time i get "wwan0" (modem 0) and "wwan1" (modem 1) network interface names, but sometimes they switch to "wwan0" (modem 1) and "wwan1" (modem 0), sometimes i get "wwx*" interface name on one of them and "wwan1" on the other, this is very sad ;(. How can i get "wwx*" for both of them? modems are connected after the system is already started im using latest jammy cli image on opi zero, the only thing i did is installed "modemmanager" and created 2 gsm connections in networkmanager
  4. it's in regular ubuntu 22.04 for arm but not there, why?
  5. after i disconnect from ssh of opiz and wait a few hours, after trying to connect nothing happens for ~10 seconds (no network packets from opiz), but after waiting it starts responding and then it works fine until i disconnect and wait again. this is present on opiz in debian armbian 08.23, 11.23, bleeding edge build from yesterday. this is not present on opi pc+ in build 11.23. this doesn't affect any other network services, only affects ssh.
  6. @Wernerit worked, had to do "apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 93D6889F9F0E78D5" for some reason after apt upgrade to armbian 23.11.1
  7. Get:60 http://deb.debian.org/debian bookworm/main armhf openssl armhf 3.0.11-1~deb12u2 [1,386 kB] Get:61 http://deb.debian.org/debian bookworm/main armhf openvpn armhf 2.6.3-1+deb12u2 [601 kB] Get:62 http://deb.debian.org/debian bookworm/main armhf python3-distro-info all 1.5+deb12u1 [6,772 B] Ign:8 http://fastmirror.pp.ua/armbian bookworm/main armhf armbian-zsh all 23.11.1 Ign:11 http://fastmirror.pp.ua/armbian bookworm/main armhf linux-u-boot-orangepizero-current armhf 23.11.1 Ign:8 http://fastmirror.pp.ua/armbian bookworm/main armhf armbian-zsh all 23.11.1 Ign:11 http://fastmirror.pp.ua/armbian bookworm/main armhf linux-u-boot-orangepizero-current armhf 23.11.1 Ign:8 http://fastmirror.pp.ua/armbian bookworm/main armhf armbian-zsh all 23.11.1 Ign:11 http://fastmirror.pp.ua/armbian bookworm/main armhf linux-u-boot-orangepizero-current armhf 23.11.1 Ign:8 http://fastmirror.pp.ua/armbian bookworm/main armhf armbian-zsh all 23.11.1 Err:8 http://apt.armbian.com bookworm/main armhf armbian-zsh all 23.11.1 Could not connect to fastmirror.pp.ua:80 (93.126.105.202), connection timed out Err:11 http://fastmirror.pp.ua/armbian bookworm/main armhf linux-u-boot-orangepizero-current armhf 23.11.1 Unable to connect to fastmirror.pp.ua:http: Fetched 141 MB in 38s (3,702 kB/s) E: Failed to fetch http://apt.armbian.com/pool/main/a/armbian-zsh/armbian-zsh_23.11.1_all__1-SAbfee-Baafd-R448a.deb Could not connect to fastmirror.pp.ua:80 (93.126.105.202), connection timed out E: Failed to fetch http://fastmirror.pp.ua/armbian/pool/main/l/linux-u-boot-orangepizero-current/linux-u-boot-orangepizero-current_23.11.1_armhf__2023.10-S4459-P4fc9-H0429-V5590-B1179-R448a.deb Unable to connect to fastmirror.pp.ua:http: E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
  8. sometimes apt tries to use fastmirror.pp.ua and it fails since a few weeks ago because russian government banned most *.ua domains and some ukrainian ip addresses
  9. can confirm. i use usb to sata adapter and reading APM works "hdparm -B /dev/sda", but writing APM value with "hdparm -B 254 /dev/sda" or smartctl doesn't do anything on opi pc (works fine on regular PC)
  10. it doesn't apply until i manually change ENABLE to true in /etc/default/cpufrequtils board is opi pc and opi zero and im using latest CLI image
