sliver85
  1. @Aurelio Indeed, it was indeed the fork image of Armbian. I tested with this image: Armbian_23.02.2_Aml-s9xx-box_bullseye_current_6.1.11.img.xz that you recommend and it starts correctly on Armbian now ๐Ÿ‘ Thank you very much for taking the time to answer me ๐Ÿ˜ƒ
  2. Hello, I try to install armbian on my Q96max 4K Ultra HD fake 8GB 128GB It is registered on the S905L-B processor (but I don't know if it's fake too) The reference on the PCB is PAM5LV207A1-4-121217 I tried the procedure indicated by @Aurelio and @thielj without success I use the image: Armbian_23.08.0_amlogic_s905x_jammy_5.15.133_server_2023.10.02.img with the u-boot-s905x-s912 but when I try to boot from the USB key (I tried 2 different USB keys and also a USB/SD reader) it does not start on armbian but on the Android recovery menu I see it says p201 so I also tried with u-boot p201 but same result. I also tried with the image intended for S905L-B (Armbian_23.08.0_amlogic_s905lb-r3300l_lunar_5.15.132_server_2023.09.20.img) but the same, I systematically arrive at this menu. Do you have any idea because I'm going in circles a bit? :(
ร—
ร—
