pinebookpro-owner
11 -
Hello, It is good news that is new armbian version here. But unfortunatelly my issue listed above was not resolved. Both problems persists. The usb c port still doesn't work and the initramfs issue is also not resolved: Could you tell me is this error with usb c only on my comp or is it general, also for iniramfs?
Some issue is, but I don't know. Just checked again. Still not working . With manual paste on paste.armbian.com by saving come pop out message "some went wrong". And output from terminal by issuing sudo armbianmonitor -u gives me following output: System diagnosis information will now be uploaded to https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ Please post the URL in the forum where you've been asked for. As seen above there is no url with id. About the problem with usb port itself. I could not state anything general, it could be that is some hardware problem only at my side, I don't know therefore I asked.
Hello, as already mentioned in topic USB C port doesn't work after upgrading to the latest kernel 6.6.2 . The previous problem with not working left usb 3 port persist no more. Everything is fine. As I remember , before update the usb c port has worked with the adapter and the devices like mouse, usb flash etc. Now it doesn't work any more, furthermore it gives no signal of life. There is 0 amps current measured, also dmesg -W gives no output at all after plugging in the device. PS: I was unable to upload the report file, also the service paste.armbian.com doesn't work at the moment.
Problem with USB port on Pinebook pro
pinebookpro-owner replied to pinebookpro-owner's topic in Pinebook Pro
Sorry for the delayed replays. I will see the dmesg little later. To prove the USB C I could only if I find the adapter for the flash memory. Update follows soon. ____________________________ So, the output of dmesg -W is only for the right usb port. On the left is without response. $ dmesg -W [ 302.500236] usb 1-1.1: new low-speed USB device number 5 using ehci-platform [ 302.613848] usb 1-1.1: New USB device found, idVendor=1c4f, idProduct=0034, bcdDevice= 1.10 [ 302.613903] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 302.613929] usb 1-1.1: Product: Usb Mouse [ 302.613950] usb 1-1.1: Manufacturer: SIGMACHIP [ 302.620814] input: SIGMACHIP Usb Mouse as /devices/platform/fe3c0000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:1C4F:0034.0004/input/input15 [ 302.622397] hid-generic 0003:1C4F:0034.0004: input,hidraw0: USB HID v1.10 Mouse [SIGMACHIP Usb Mouse] on usb-fe3c0000.usb-1.1/input0 [ 313.263352] usb 1-1.1: USB disconnect, device number 5 Unfortunately, I am not able to test the usb c port. Regarding armbian-config. I also could not claim anything, but after the update it has stopped working. If it is corelated with armbian-config and update, once again I do not claim that. This problem is as seen known and it could be anything. ____________________ UPDATE: In meantime usb port type c checked. Flash memory works via adapter. Mouse also works. _____________________ Could you tell me, I ask as layman, are you sure this is not hardware issue. I am aware if is it software issue that also could be not less difficult, but could you tell if is it solvable in a month for instance? PROBLEM SOLVED on 30.11.2023 with the latest update of kernel. Thanks to the armbian team! -
Just for any case I've pasted both reports. First link is with mouse on the right slot, and the second link is the mouse in the left slot. I don't know if this command crops also some logs before. While before I have plugged also an usb stick in left usb port. In both cases I called this report from menu from armbian-config. Firmware update was ordinary from menu in armbian-config. Right after that left usb port became unresponsive. I have just recalled right now, It is good to mention also this: Relativly long ago, I have misplugged power in the audio jack which is on the right side, since then, the sound on earphones is always with regular soundspeakers. The sound could not be only in earphones. But I didn't see any problems. Before the latest firmware update, the left usb port has worked circa in 90% of boot ups, only in 10 % it was unresponsive after boot up. __________________________ And one more update regarding last mentioned. I have measured the voltage and current on mouse and usb memory stick plugged in. The results: Mouse: The Voltage is same in both cases : 5,10 V On the left side it draws the 8mA and on the right 9mA USB memory stick: On the left side draws 44mA and on the right 65mA __________________________ and the last I've found was this thread on pine64 forum: https://forum.pine64.org/showthread.php?tid=8243 -
Thank you for a friendly suggestion and patience. I am not often on forums. The report was, namely, already ready. It could be suggested command armbianmonitor -u, but from armbian script. The link is below: https://paste.armbian.com/zetukadivi PS: On the left (problematic) USB port the mouse has red light but it is not responsive. The usb flash memory stick does not have led on (it is older flash drive with 4GB, but led is very good for indication) It just briefly flashes and nothing after that. The report is with mouse on the another (right) usb port. The command lsusb does not list the mouse when is plugged in left usb port. ........ I have just uploaded report where the mouse is plugged in the problemtic (left) port. https://paste.armbian.com/hewelunure -
Hello all, I got a problem after new update of armbian firmware through your own module (script). The left USB port on pinebook pro has stoped working at all. Before that was occasionaly after 6 -7 boot ups only one time not working (it is used for mouse). Now after x rebooting it doesnt work at all. The right USB port works without problems. On the left, also USB flash drive doesn't work. No idea, what could it be? Before, as already said, it has worked in 90%. Before firmware upgrade.
