I already posted the question in the Odroid forum. I decided to post it here too since it may be more inherent to the Armbian OS.
I used both Armbian_23.02.3_Odroidxu4_bullseye_current_5.4.239.img from the odroidxu4 archive and Armbian-unofficial_23.11.0-trunk_Odroidxu4_bullseye_current_6.1.63 generated from the Armbian build script. (Base CLI Image).
After flashing the former image and then installing OMV6, this is the output that OMV6 gives me when installing the openmediavault-wireguard plugin:
Then, after rebooting, here is the output of minicom:
And the ODROID doesn't go further. It stays stuck at "BOOTP broadcast 1".
Next, I tried to repeat the same steps with the image generated from the Armbian build script. Here is the output of OMV6 when installing openmediavault-wireguard:
And here is the output of minicom:
What could be the issue?
Thanks in advance for your help.
