samuelef
2 -
Turns out it was the USB extension cable that I put on the USB-C power supply cable.
Hi, I'm testing the latest Armbian 23.08 Bookworm on a Rock3A board. I have installed the Armbian base system on both SD-CARD and eMMC. For my application I need to use an Intel WiFi M.2 board, precisely an Intel AX210 NGW with both Bluetooth and WiFi enabled at the same time. Currently I have found this situation: boot from the SD-CARD (eMMC removed from its socket) Intel AX210 M2 card plugged-in the OS boots corectly installed the firmware-iwlwifi package and bluetooth+wifi works without problems boot from the eMMC memory (SD-CARD removed from its socket) Intel AX210 M2 card plugged-in the OS enter in bootloop boot from the eMMC memory (SD-CARD removed from its socket) No WiFi card plugged in the M2 socket the OS boots corectly boot from the eMMC memory (SD-CARD removed from its socket) Using the default Radxa WiFi M2 card based on AP6212 the OS boots corectly I have highlighted the condition that causes the bootloop. I know that this WiFi board is not officially supported from the Armbian distribution, but it works correctly when the OS boots from the SD-CARD, so it seems a problem related to booting the OS from the eMMC... If anyone could point me in the direction to look for information regarding this issue, or could help me how to better debug the issue (because actually the system does not print any error, it simply reboots). BR Samuele. PS. This is the log captured from the serial port while re-booting... DDR Version V1.13 20220218 In ddrconfig:0 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB tdqss: cs0 dqs0: 48ps, dqs1: -72ps, dqs2: 24ps, dqs3: -96ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x60 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:0 vrefinner:24%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1560MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x1d cs 0: the read training result: DQS0:0x38, DQS1:0x37, DQS2:0x3b, DQS3:0x35, min : 0xe 0x10 0x14 0xf 0x2 0x5 0xa 0x5 , 0xa 0x8 0x3 0x3 0xc 0xa 0xd 0x7 , 0x15 0x14 0xe 0xd 0x3 0x1 0x3 0x5 , 0xd 0xa 0x9 0x2 0xf 0xf 0xd 0xf , mid :0x2a 0x2c 0x2e 0x2b 0x1d 0x21 0x24 0x21 ,0x26 0x24 0x1e 0x1f 0x28 0x25 0x28 0x24 , 0x2f 0x30 0x29 0x28 0x1e 0x1c 0x1d 0x20 ,0x29 0x25 0x24 0x1e 0x2b 0x2b 0x29 0x2b , max :0x46 0x48 0x49 0x47 0x38 0x3d 0x3f 0x3d ,0x42 0x40 0x39 0x3b 0x44 0x40 0x44 0x41 , 0x49 0x4c 0x44 0x44 0x3a 0x38 0x38 0x3c ,0x45 0x41 0x3f 0x3a 0x48 0x47 0x45 0x47 , range:0x38 0x38 0x35 0x38 0x36 0x38 0x35 0x38 ,0x38 0x38 0x36 0x38 0x38 0x36 0x37 0x3a , 0x34 0x38 0x36 0x37 0x37 0x37 0x35 0x37 ,0x38 0x37 0x36 0x38 0x39 0x38 0x38 0x38 , the write training result: DQS0:0x26, DQS1:0xf, DQS2:0x21, DQS3:0xa, min :0x6c 0x6f 0x73 0x70 0x62 0x66 0x66 0x68 0x68 ,0x53 0x51 0x4c 0x4b 0x57 0x55 0x54 0x55 0x4f , 0x7a 0x79 0x74 0x76 0x6b 0x69 0x69 0x6f 0x6f ,0x63 0x60 0x60 0x5c 0x68 0x68 0x63 0x6b 0x61 , mid :0x88 0x8a 0x8d 0x8a 0x7a 0x7f 0x80 0x80 0x81 ,0x6d 0x6c 0x64 0x64 0x70 0x6d 0x6d 0x6d 0x6a , 0x94 0x93 0x8c 0x8e 0x84 0x82 0x82 0x86 0x88 ,0x7c 0x7a 0x76 0x74 0x81 0x81 0x7c 0x81 0x79 , max :0xa4 0xa6 0xa8 0xa4 0x93 0x99 0x9b 0x99 0x9b ,0x87 0x87 0x7c 0x7d 0x89 0x85 0x87 0x85 0x85 , 0xaf 0xae 0xa5 0xa6 0x9d 0x9b 0x9b 0x9d 0xa2 ,0x95 0x94 0x8d 0x8c 0x9a 0x9b 0x95 0x98 0x91 , range:0x38 0x37 0x35 0x34 0x31 0x33 0x35 0x31 0x33 ,0x34 0x36 0x30 0x32 0x32 0x30 0x33 0x30 0x36 , 0x35 0x35 0x31 0x30 0x32 0x32 0x32 0x2e 0x33 ,0x32 0x34 0x2d 0x30 0x32 0x33 0x32 0x2d 0x30 , CA Training result: cs:0 min :0x45 0x45 0x3a 0x3a 0x3f 0x37 0x3f ,0x48 0x41 0x3f 0x38 0x3c 0x35 0x40 , cs:0 mid :0x84 0x83 0x78 0x77 0x7c 0x74 0x6e ,0x86 0x80 0x7b 0x75 0x79 0x73 0x6e , cs:0 max :0xc4 0xc2 0xb7 0xb5 0xba 0xb1 0x9d ,0xc5 0xc0 0xb7 0xb3 0xb7 0xb2 0x9d , cs:0 range:0x7f 0x7d 0x7d 0x7b 0x7b 0x7a 0x5e ,0x7d 0x7f 0x78 0x7b 0x7b 0x7d 0x5d , out U-Boot SPL board init U-Boot SPL 2017.09-armbian (Aug 22 2023 - 15:21:07) unknown raw ID phN unrecognized JEDEC id bytes: 00, 00, 00 Trying to boot from MMC2 MMC error: The cmd index is 1, ret is -110 Card did not respond to voltage select! mmc_init: -95, time 10 spl: mmc init failed with error: -95 Trying to boot from MMC1 ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(fe4f274c06...) + OK ## Checking uboot 0x00a00000 ... sha256(11a12d7d28...) + OK ## Checking fdt 0x00b2e700 ... sha256(4bdde2de3f...) + OK ## Checking atf-2 0x00068000 ... sha256(8d44036095...) + OK ## Checking atf-3 0xfdcd0000 ... sha256(e410275b51...) + OK ## Checking atf-4 0xfdcc9000 ... sha256(990c53fc01...) + OK ## Checking atf-5 0x00066000 ... sha256(315a4195a9...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 224.553 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl NOTICE: BL31: Built : 10:55:41, Oct 18 2021 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09-armbian (Aug 22 2023 - 15:21:07 +0000) Model: Radxa ROCK3 Model A PreSerial: 2, raw, 0xfe660000 DRAM: 2 GiB Sysmem: init Relocation Offset: 7d34a000 Relocation fdt: 7b9f73e0 - 7b9fece0 CR: M/C/I Using default environment PCIe-0 Link Fail dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0 Bootdev(atags): mmc 0 MMC0: HS200, 200Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition No resource partition No resource partition Failed to load DTB, ret=-19 Failed to get kernel dtb, ret=-19 I2c0 speed: 100000Hz vsel-gpios- not found! Error: -2 vdd_cpu init 900000 uV PMIC: RK8090 (on=0x40, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Model: Radxa ROCK3 Model A rockchip_set_serialno: could not find efuse/otp device CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 780000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz No misc partition Net: eth1: ethernet@fe010000 Hit key to stop autoboot('CTRL+C'): 0 failed to find reset-gpios property Device 0: unknown device MMC error: The cmd index is 1, ret is -110 Card did not respond to voltage select! mmc_init: -95, time 9 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2666 bytes read in 111 ms (23.4 KiB/s) ## Executing script at 00c00000 339 bytes read in 94 ms (2.9 KiB/s) 29792768 bytes read in 437 ms (65 MiB/s) 12140909 bytes read in 282 ms (41.1 MiB/s) 118168 bytes read in 662 ms (173.8 KiB/s) Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 12140845 Bytes = 11.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x0a100000 Booting using the fdt blob at 0x0a100000 Using Device Tree in place at 000000000a100000, end 000000000a11fd97 can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory Adding bank: 0x00200000 - 0x80000000 (size: 0x7fe00000) Total: 3404.547 ms Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050] [ 0.000000] Linux version 6.1.50-current-rockchip64 (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #3 SMP PREEMPT Wed Aug 30 14:11:13 UTC 2023 [ 0.000000] Machine model: Radxa ROCK3 Model A [ 0.000000] efi: UEFI not found. [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x7fb62a80-0x7fb64fff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff] [ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges [ 0.000000] cma: Reserved 128 MiB at 0x0000000075a00000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 30 pages/cpu s82408 r8192 d32280 u122880 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009 [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Fallback order for Node 0: 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 515592 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: root=UUID=474b9cfe-db74-41d0-a8ff-9dc8a3d88769 rootfstype=ext4 rootwait console=ttyS2,1500000 console=tty1 consoleblank=0 coherent_pool=2M usb-storage.quirks= net.ifnames=0 [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] Memory: 1881304K/2095104K available (16512K kernel code, 2278K rwdata, 6172K rodata, 3968K init, 585K bss, 82728K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] trace event string verifier disabled [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 320 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: MBI range [296:319] [ 0.000000] GICv3: Using MBI frame 0x00000000fd410000 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000 [ 0.000000] ITS: No ITS available, not enabling LPIs [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001268] Console: colour dummy device 80x25 [ 0.001921] printk: console [tty1] enabled [ 0.002056] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.002098] pid_max: default: 32768 minimum: 301 [ 0.002220] LSM: Security Framework initializing [ 0.002275] Yama: becoming mindful. [ 0.002432] AppArmor: AppArmor initialized [ 0.002494] Stack Depot allocating hash table of 131072 entries with kvcalloc [ 0.002956] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.003002] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.004644] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 0.006120] cblist_init_generic: Setting adjustable number of callback queues. [ 0.006154] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.006354] cblist_init_generic: Setting adjustable number of callback queues. [ 0.006383] cblist_init_generic: Setting shift to 2 and lim to 1. [ 0.006830] rcu: Hierarchical SRCU implementation. [ 0.006855] rcu: Max phase no-delay instances is 1000. [ 0.011245] EFI services will not be available. [ 0.012032] smp: Bringing up secondary CPUs ... [ 0.013219] Detected VIPT I-cache on CPU1 [ 0.013337] cacheinfo: Unable to detect cache hierarchy for CPU 1 [ 0.013358] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000 [ 0.013423] CPU1: Booted secondary processor 0x0000000100 [0x412fd050] [ 0.014682] Detected VIPT I-cache on CPU2 [ 0.014788] cacheinfo: Unable to detect cache hierarchy for CPU 2 [ 0.014807] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000 [ 0.014858] CPU2: Booted secondary processor 0x0000000200 [0x412fd050] [ 0.016201] Detected VIPT I-cache on CPU3 [ 0.016309] cacheinfo: Unable to detect cache hierarchy for CPU 3 [ 0.016329] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000 [ 0.016379] CPU3: Booted secondary processor 0x0000000300 [0x412fd050] [ 0.016554] smp: Brought up 1 node, 4 CPUs [ 0.016722] SMP: Total of 4 processors activated. [ 0.016741] CPU features: detected: 32-bit EL0 Support [ 0.016757] CPU features: detected: 32-bit EL1 Support [ 0.016775] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.016799] CPU features: detected: Common not Private translations [ 0.016817] CPU features: detected: CRC32 instructions [ 0.016835] CPU features: detected: RCpc load-acquire (LDAPR) [ 0.016853] CPU features: detected: LSE atomic instructions [ 0.016868] CPU features: detected: Privileged Access Never [ 0.016885] CPU features: detected: RAS Extension Support [ 0.016904] CPU features: detected: Speculative Store Bypassing Safe (SSBS) [ 0.017037] CPU: All CPU(s) started at EL2 [ 0.017060] alternatives: applying system-wide alternatives [ 0.023360] devtmpfs: initialized [ 0.053269] Registered cp15_barrier emulation handler [ 0.053328] Registered setend emulation handler [ 0.053678] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.053754] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.058252] pinctrl core: initialized pinctrl subsystem [ 0.059368] DMI not present or invalid. [ 0.060345] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.063095] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.064324] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.065558] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.065680] audit: initializing netlink subsys (disabled) [ 0.066045] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1 [ 0.068908] thermal_sys: Registered thermal governor 'fair_share' [ 0.068924] thermal_sys: Registered thermal governor 'bang_bang' [ 0.068953] thermal_sys: Registered thermal governor 'step_wise' [ 0.068972] thermal_sys: Registered thermal governor 'user_space' [ 0.069105] cpuidle: using governor menu [ 0.069527] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.069767] ASID allocator initialised with 65536 entries [ 0.071893] Serial: AMBA PL011 UART driver [ 0.093475] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000 [ 0.138528] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000 [ 0.139558] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000 [ 0.140548] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000 [ 0.141718] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000 [ 0.142678] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000 [ 0.148572] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /hdmi-con [ 0.171853] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.171899] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.171922] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.171940] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.171960] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.171978] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.171997] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.172015] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.173542] cryptd: max_cpu_qlen set to 1000 [ 0.240761] raid6: neonx8 gen() 1372 MB/s [ 0.308973] raid6: neonx4 gen() 1406 MB/s [ 0.377241] raid6: neonx2 gen() 1219 MB/s [ 0.445348] raid6: neonx1 gen() 1020 MB/s [ 0.513491] raid6: int64x8 gen() 932 MB/s [ 0.581637] raid6: int64x4 gen() 1055 MB/s [ 0.649778] raid6: int64x2 gen() 936 MB/s [ 0.717932] raid6: int64x1 gen() 671 MB/s [ 0.717958] raid6: using algorithm neonx4 gen() 1406 MB/s [ 0.786064] raid6: .... xor() 1056 MB/s, rmw enabled [ 0.786088] raid6: using neon recovery algorithm [ 0.793082] iommu: Default domain type: Translated [ 0.793124] iommu: DMA domain TLB invalidation policy: strict mode [ 0.794252] SCSI subsystem initialized [ 0.795014] usbcore: registered new interface driver usbfs [ 0.795114] usbcore: registered new interface driver hub [ 0.795191] usbcore: registered new device driver usb [ 0.796353] pps_core: LinuxPPS API ver. 1 registered [ 0.796380] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.796432] PTP clock support registered [ 0.796897] EDAC MC: Ver: 3.0.0 [ 0.797703] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16 [ 0.797932] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled. [ 0.798034] arm-scmi firmware:scmi: Malformed reply - real_sz:8 calc_sz:4 (loop_num_ret:3) [ 0.798069] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0 [ 0.800154] NetLabel: Initializing [ 0.800186] NetLabel: domain hash size = 128 [ 0.800204] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 0.800311] NetLabel: unlabeled traffic allowed by default [ 0.800578] vgaarb: loaded [ 0.801309] clocksource: Switched to clocksource arch_sys_counter [ 0.802035] VFS: Disk quotas dquot_6.6.0 [ 0.802142] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.803306] AppArmor: AppArmor Filesystem Enabled [ 0.819100] NET: Registered PF_INET protocol family [ 0.819478] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.822234] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear) [ 0.822509] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.822610] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.822952] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear) [ 0.823489] TCP: Hash tables configured (established 16384 bind 16384) [ 0.823761] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.823856] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear) [ 0.824255] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.824338] NET: Registered PF_XDP protocol family [ 0.824372] PCI: CLS 0 bytes, default 64 [ 0.825253] Trying to unpack rootfs image as initramfs... [ 0.838849] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available [ 0.840241] kvm [1]: IPA Size Limit: 40 bits [ 0.840343] kvm [1]: GICv3: no GICV resource entry [ 0.840367] kvm [1]: disabling GICv2 emulation [ 0.840417] kvm [1]: GIC system register CPU interface enabled [ 0.840762] kvm [1]: vgic interrupt IRQ9 [ 0.841056] kvm [1]: VHE mode initialized successfully [ 0.845162] Initialise system trusted keyrings [ 0.845455] Key type blacklist registered [ 0.845934] workingset: timestamp_bits=44 max_order=19 bucket_order=0 [ 0.856377] zbud: loaded [ 0.859562] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.860985] fuse: init (API version 7.37) [ 0.865722] integrity: Platform Keyring initialized [ 0.919082] xor: measuring software checksum speed [ 0.924975] 8regs : 1721 MB/sec [ 0.931398] 32regs : 1577 MB/sec [ 0.938107] arm64_neon : 1508 MB/sec [ 0.938155] xor: using function: 8regs (1721 MB/sec) [ 0.938196] Key type asymmetric registered [ 0.938219] Asymmetric key parser 'x509' registered [ 1.777583] Freeing initrd memory: 11852K [ 1.812558] alg: self-tests for CTR-KDF (hmac(sha256)) passed [ 1.812733] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.813005] io scheduler mq-deadline registered [ 1.813037] io scheduler kyber registered [ 1.813465] io scheduler bfq registered [ 1.840271] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.840325] dma-pl330 fe530000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 1.843930] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.843973] dma-pl330 fe550000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16 [ 1.848525] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active. [ 1.849667] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 1.854665] printk: console [ttyS2] disabled [ 1.854793] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 29, base_baud = 1500000) is a 16550A [ 1.969367] printk: console [ttyS2] enabled [ 1.971519] Serial: AMBA driver [ 1.977406] rockchip-vop2 fe040000.vop: Adding to iommu group 2 [ 1.986034] cacheinfo: Unable to detect cache hierarchy for CPU 0 [ 1.998534] loop: module loaded [ 2.007233] tun: Universal TUN/TAP device driver, 1.6 [ 2.009424] thunder_xcv, ver 1.0 [ 2.009832] thunder_bgx, ver 1.0 [ 2.010201] nicpf, ver 1.0 [ 2.011922] e1000e: Intel(R) PRO/1000 Network Driver [ 2.012383] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 2.012996] igb: Intel(R) Gigabit Ethernet Network Driver [ 2.013534] igb: Copyright (c) 2007-2014 Intel Corporation. [ 2.014123] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 2.014694] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 2.015626] sky2: driver version 1.30 [ 2.016991] VFIO - User Level meta-driver version: 0.3 [ 2.030255] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.030780] ehci-platform fd800000.usb: EHCI Host Controller [ 2.030804] ohci-platform fd840000.usb: Generic Platform OHCI controller [ 2.030813] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 2.030873] ehci-platform fd880000.usb: EHCI Host Controller [ 2.030909] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2 [ 2.031026] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [ 2.031129] xhci-hcd xhci-hcd.0.auto: irq 33, io mem 0xfcc00000 [ 2.031164] ehci-platform fd880000.usb: irq 36, io mem 0xfd880000 [ 2.031339] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3 [ 2.031430] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.031451] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4 [ 2.031472] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 2.031781] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 2.031796] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.031807] usb usb1: Product: xHCI Host Controller [ 2.031815] usb usb1: Manufacturer: Linux 6.1.50-current-rockchip64 xhci-hcd [ 2.031823] usb usb1: SerialNumber: xhci-hcd.0.auto [ 2.032156] ohci-platform fd8c0000.usb: Generic Platform OHCI controller [ 2.032771] ehci-platform fd800000.usb: irq 35, io mem 0xfd800000 [ 2.032774] hub 1-0:1.0: USB hub found [ 2.042692] hub 1-0:1.0: 1 port detected [ 2.043724] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.044696] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 2.045487] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.046148] usb usb4: Product: xHCI Host Controller [ 2.046594] usb usb4: Manufacturer: Linux 6.1.50-current-rockchip64 xhci-hcd [ 2.047230] usb usb4: SerialNumber: xhci-hcd.0.auto [ 2.048447] hub 4-0:1.0: USB hub found [ 2.048860] hub 4-0:1.0: 1 port detected [ 2.049364] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00 [ 2.049835] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 5 [ 2.049860] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 6 [ 2.050103] ohci-platform fd8c0000.usb: irq 38, io mem 0xfd8c0000 [ 2.050136] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.050549] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 2.050565] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.050577] usb usb2: Product: EHCI Host Controller [ 2.050584] usb usb2: Manufacturer: Linux 6.1.50-current-rockchip64 ehci_hcd [ 2.050593] usb usb2: SerialNumber: fd880000.usb [ 2.050805] ohci-platform fd840000.usb: irq 37, io mem 0xfd840000 [ 2.051418] hub 2-0:1.0: USB hub found [ 2.056258] hub 2-0:1.0: 1 port detected [ 2.057214] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7 [ 2.058157] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [ 2.059079] xhci-hcd xhci-hcd.1.auto: irq 34, io mem 0xfd000000 [ 2.059928] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.060447] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8 [ 2.061156] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed [ 2.062050] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 2.062809] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.063465] usb usb7: Product: xHCI Host Controller [ 2.063911] usb usb7: Manufacturer: Linux 6.1.50-current-rockchip64 xhci-hcd [ 2.064546] usb usb7: SerialNumber: xhci-hcd.1.auto [ 2.065342] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00 [ 2.065817] hub 7-0:1.0: USB hub found [ 2.066315] hub 7-0:1.0: 1 port detected [ 2.067333] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.068287] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01 [ 2.069046] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.069734] usb usb8: Product: xHCI Host Controller [ 2.070186] usb usb8: Manufacturer: Linux 6.1.50-current-rockchip64 xhci-hcd [ 2.070823] usb usb8: SerialNumber: xhci-hcd.1.auto [ 2.072049] hub 8-0:1.0: USB hub found [ 2.072455] hub 8-0:1.0: 1 port detected [ 2.073643] usbcore: registered new interface driver usb-storage [ 2.073685] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01 [ 2.074942] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.075600] usb usb3: Product: EHCI Host Controller [ 2.076046] usb usb3: Manufacturer: Linux 6.1.50-current-rockchip64 ehci_hcd [ 2.076681] usb usb3: SerialNumber: fd800000.usb [ 2.078018] hub 3-0:1.0: USB hub found [ 2.078092] mousedev: PS/2 mouse device common for all mice [ 2.078434] hub 3-0:1.0: 1 port detected [ 2.080623] i2c_dev: i2c /dev entries driver [ 2.083850] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected! [ 2.092357] rk808 0-0020: chip id: 0x8090 [ 2.113639] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 2.114415] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.115072] usb usb6: Product: Generic Platform OHCI controller [ 2.115609] usb usb6: Manufacturer: Linux 6.1.50-current-rockchip64 ohci_hcd [ 2.116245] usb usb6: SerialNumber: fd8c0000.usb [ 2.117542] hub 6-0:1.0: USB hub found [ 2.117969] hub 6-0:1.0: 1 port detected [ 2.119169] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01 [ 2.119931] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.120588] usb usb5: Product: Generic Platform OHCI controller [ 2.121126] usb usb5: Manufacturer: Linux 6.1.50-current-rockchip64 ohci_hcd [ 2.121971] usb usb5: SerialNumber: fd840000.usb [ 2.123138] hub 5-0:1.0: USB hub found [ 2.123543] hub 5-0:1.0: 1 port detected [ 2.137987] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 2.138600] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 2.139166] rk808-regulator rk808-regulator: max buck steps per change: 8 [ 2.204367] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0 [ 2.218145] rk808-rtc rk808-rtc: registered as rtc0 [ 2.221358] rk808-rtc rk808-rtc: setting system clock to 2017-08-05T09:00:06 UTC (1501923606) [ 2.230411] rtc-hym8563 5-0051: no valid clock/calendar values available [ 2.231340] rtc-hym8563 5-0051: registered as rtc1 [ 2.241781] sdhci: Secure Digital Host Controller Interface driver [ 2.242369] sdhci: Copyright(c) Pierre Ossman [ 2.242828] Synopsys Designware Multimedia Card Interface Driver [ 2.245199] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.246674] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode. [ 2.246679] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode. [ 2.246728] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller. [ 2.247363] dwmmc_rockchip fe000000.mmc: Using internal DMA controller. [ 2.247978] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a [ 2.248079] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 70,32 bit host data width,256 deep fifo [ 2.248572] dwmmc_rockchip fe000000.mmc: Version ID is 270a [ 2.249536] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO [ 2.249900] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 69,32 bit host data width,256 deep fifo [ 2.252577] ledtrig-cpu: registered to indicate activity on CPUs [ 2.252914] dwmmc_rockchip fe000000.mmc: allocated mmc-pwrseq [ 2.253716] mmc_host mmc2: card is non-removable. [ 2.254348] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active. [ 2.255054] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 2.256129] hid: raw HID events driver (C) Jiri Kosina [ 2.256842] usbcore: registered new interface driver usbhid [ 2.257387] usbhid: USB HID core driver [ 2.266277] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.266376] drop_monitor: Initializing network drop monitor service [ 2.268594] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0) [ 2.268763] NET: Registered PF_INET6 protocol family [ 2.281129] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA [ 2.306513] Segment Routing with IPv6 [ 2.307009] In-situ OAM (IOAM) with IPv6 [ 2.307514] NET: Registered PF_PACKET protocol family [ 2.308194] 8021q: 802.1Q VLAN Support v1.8 [ 2.308676] Key type dns_resolver registered [ 2.310738] registered taskstats version 1 [ 2.311169] Loading compiled-in X.509 certificates [ 2.316705] zswap: loaded using pool zstd/z3fold [ 2.317836] Key type .fscrypt registered [ 2.318215] Key type fscrypt-provisioning registered [ 2.322009] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes [ 2.323296] Key type encrypted registered [ 2.323703] AppArmor: AppArmor sha1 policy hashing enabled [ 2.324961] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0) [ 2.333387] usb 3-1: new high-speed USB device number 2 using ehci-platform [ 2.396162] mmc1: new HS200 MMC card at address 0001 [ 2.398024] mmcblk1: mmc1:0001 D9D16G 14.5 GiB [ 2.404366] mmcblk1: p1 [ 2.405918] mmcblk1boot0: mmc1:0001 D9D16G 4.00 MiB [ 2.409483] mmcblk1boot1: mmc1:0001 D9D16G 4.00 MiB [ 2.412540] mmcblk1rpmb: mmc1:0001 D9D16G 4.00 MiB, chardev (242:0) [ 2.427606] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges: [ 2.428350] rockchip-dw-pcie 3c0000000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000 [ 2.429174] rockchip-dw-pcie 3c0000000.pcie: MEM 0x00f4200000..0x00f5ffffff -> 0x00f4200000 [ 2.430050] rockchip-dw-pcie 3c0000000.pcie: MEM 0x0300000000..0x033fffffff -> 0x0040000000 [ 2.431109] rockchip-dw-pcie 3c0000000.pcie: iATU unroll: enabled [ 2.431672] rockchip-dw-pcie 3c0000000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 2.490090] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 2.490848] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.491495] usb 3-1: Product: USB 2.0 Hub [ 2.492804] hub 3-1:1.0: USB hub found [ 2.493344] hub 3-1:1.0: 4 ports detected [ 2.637401] rockchip-dw-pcie 3c0000000.pcie: PCIe Gen.2 x1 link up [ 2.638177] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00 [ 2.638821] pci_bus 0000:00: root bus resource [bus 00-0f] [ 2.639330] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff]) [ 2.640192] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff] [ 2.640818] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff] (bus address [0x40000000-0x7fffffff]) [ 2.641838] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 [ 2.642431] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 2.643161] pci 0000:00:00.0: supports D1 D2 [ 2.643560] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.652676] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 2.653882] pci 0000:01:00.0: [8086:2725] type 00 class 0x028000 [ 2.654553] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit] [ 2.655752] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold [ 2.665563] pci 0000:00:00.0: BAR 14: assigned [mem 0xf4200000-0xf42fffff] [ 2.666204] pci 0000:00:00.0: BAR 6: assigned [mem 0xf4300000-0xf430ffff pref] [ 2.666873] pci 0000:01:00.0: BAR 0: assigned [mem 0xf4200000-0xf4203fff 64bit] [ 2.667591] pci 0000:00:00.0: PCI bridge to [bus 01-ff] [ 2.668078] pci 0000:00:00.0: bridge window [mem 0xf4200000-0xf42fffff] [ 2.671385] pcieport 0000:00:00.0: PME: Signaling with IRQ 75 [ 2.672475] pcieport 0000:00:00.0: AER: enabled with IRQ 75 [ 2.675007] phy phy-fe8c0000.phy.7: lane number 0, val 1 [ 2.675697] rockchip-dw-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges: [ 2.676420] rockchip-dw-pcie 3c0800000.pcie: IO 0x00f0100000..0x00f01fffff -> 0x00f0100000 [ 2.677245] rockchip-dw-pcie 3c0800000.pcie: MEM 0x00f0200000..0x00f1ffffff -> 0x00f0200000 [ 2.678117] rockchip-dw-pcie 3c0800000.pcie: MEM 0x0380000000..0x03bfffffff -> 0x0040000000 [ 2.687503] rockchip-dw-pcie 3c0800000.pcie: iATU unroll: enabled [ 2.688066] rockchip-dw-pcie 3c0800000.pcie: iATU regions: 8 ob, 8 ib, align 64K, limit 8G [ 2.901386] usb 3-1.2: new full-speed USB device number 3 using ehci-platform [ 3.131740] usb 3-1.2: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00 [ 3.132507] usb 3-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 3.793702] rockchip-dw-pcie 3c0800000.pcie: Phy link never came up [ 3.794480] rockchip-dw-pcie 3c0800000.pcie: PCI host bridge to bus 0002:00 [ 3.795122] pci_bus 0002:00: root bus resource [bus 00-0f] [ 3.795633] pci_bus 0002:00: root bus resource [io 0x100000-0x1fffff] (bus address [0xf0100000-0xf01fffff]) [ 3.796517] pci_bus 0002:00: root bus resource [mem 0xf0200000-0xf1ffffff] [ 3.797144] pci_bus 0002:00: root bus resource [mem 0x380000000-0x3bfffffff] (bus address [0x40000000-0x7fffffff]) [ 3.798177] pci 0002:00:00.0: [1d87:3566] type 01 class 0x060400 [ 3.798755] pci 0002:00:00.0: reg 0x10: [mem 0x00000000-0x3fffffff] [ 3.799338] pci 0002:00:00.0: reg 0x14: [mem 0x00000000-0x3fffffff] [ 3.799919] pci 0002:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref] [ 3.800661] pci 0002:00:00.0: supports D1 D2 [ 3.801058] pci 0002:00:00.0: PME# supported from D0 D1 D3hot [ 3.810163] pci_bus 0002:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f]) [ 3.811504] pci 0002:00:00.0: BAR 0: assigned [mem 0x380000000-0x3bfffffff] [ 3.812164] pci 0002:00:00.0: BAR 1: no space for [mem size 0x40000000] [ 3.812769] pci 0002:00:00.0: BAR 1: failed to assign [mem size 0x40000000] [ 3.813466] pci 0002:00:00.0: BAR 6: assigned [mem 0xf0200000-0xf020ffff pref] [ 3.814137] pci 0002:00:00.0: PCI bridge to [bus 01-ff] [ 3.817490] pcieport 0002:00:00.0: PME: Signaling with IRQ 77 [ 3.818585] pcieport 0002:00:00.0: AER: enabled with IRQ 77 [ 3.830565] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops) [ 3.833237] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.835259] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver [ 3.836653] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops) [ 3.838407] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [ 3.839274] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.840083] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.840805] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 3.842647] WCN: marlin_init entry! [ 3.843918] of_cfs_init [ 3.844210] of_cfs_init: OK [ 3.849611] Freeing unused kernel memory: 3968K [ 3.861440] Run /init as init process [ 5.153184] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found [ 5.154347] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator [ 5.155382] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input). [ 5.156043] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f). [ 5.156564] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26). [ 5.157098] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no). [ 5.161401] rk_gmac-dwmac fe010000.ethernet: clock input from PHY [ 5.167013] rk_gmac-dwmac fe010000.ethernet: init for RGMII [ 5.168095] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51 [ 5.168786] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5 [ 5.169264] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported [ 5.170037] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported [ 5.170731] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported [ 5.171368] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported [ 5.172106] rk_gmac-dwmac fe010000.ethernet: TSO supported [ 5.172628] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 5.176647] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10) [ 5.178920] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled [ 5.180076] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width [ 5.196308] spi-nor spi4.0: mx25u12835f (16384 Kbytes) [ 5.576937] EXT4-fs (mmcblk1p1): INFO: recovery required on readonly filesystem [ 5.577664] EXT4-fs (mmcblk1p1): write access will be enabled during recovery [ 5.591271] EXT4-fs (mmcblk1p1): recovery complete [ 5.592245] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Quota mode: none. [ 6.024912] systemd[1]: System time before build time, advancing clock. [ 6.058950] systemd[1]: Inserted module 'autofs4' [ 6.111559] systemd[1]: systemd 252.17-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 6.114555] systemd[1]: Detected architecture arm64. [ 6.120431] systemd[1]: Hostname set to <Rock3A>. [ 6.280182] dw-apb-uart fe660000.serial: forbid DMA for kernel console [ 6.824999] systemd[1]: Queued start job for default target graphical.target. [ 6.849424] systemd[1]: Created slice system-getty.slice - Slice /system/getty. [ 6.854213] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 6.859027] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 6.860949] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch. [ 6.862869] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 6.865528] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point. [ 6.867368] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes. [ 6.868549] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes. [ 6.870018] systemd[1]: Reached target paths.target - Path Units. [ 6.871020] systemd[1]: Reached target remote-fs.target - Remote File Systems. [ 6.872064] systemd[1]: Reached target slices.target - Slice Units. [ 6.873106] systemd[1]: Reached target swap.target - Swaps. [ 6.874155] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes. [ 6.876398] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket. [ 6.878262] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 6.881257] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket. [ 6.883747] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 6.886263] systemd[1]: Listening on systemd-journald.socket - Journal Socket. [ 6.889441] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 6.891742] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 6.933969] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System... [ 6.942942] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 6.952345] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 6.962054] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System... [ 6.972999] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock... [ 6.983908] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 6.994357] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 7.005484] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 7.018275] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 7.030458] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 7.041202] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 7.052606] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 7.063581] systemd[1]: Starting systemd-fsck-root.service - File System Check on Root Device... [ 7.065739] device-mapper: uevent: version 1.0.3 [ 7.066859] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com [ 7.083184] systemd[1]: Starting systemd-journald.service - Journal Service... [ 7.100632] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 7.111112] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 7.128288] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System. [ 7.130615] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 7.132911] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 7.135265] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 7.138914] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock. [ 7.143586] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 7.148076] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 7.150757] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 7.155063] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 7.158691] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 7.163254] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 7.165982] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 7.170732] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 7.174685] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 7.179162] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 7.181772] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 7.230157] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 7.249088] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 7.259099] systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status. [ 7.261733] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 7.270939] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 7.273514] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 7.283758] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 7.325085] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 7.338053] systemd[1]: Finished systemd-fsck-root.service - File System Check on Root Device. DDR Version V1.13 20220218 ...
