Francisco_xf
  1. This is all the boot log when CONFIG_DRAM_CLK is set
  2. I just found the problem! I just commented the parameter CONFIG_DRAM_CLK from u-boot defconfig (sunxi_Gemei_G9_defconfig) and the problem is gone. Thank you very much for yours tips Gunjan!
  3. I built the kernel but the problem still remains. Maybe this is an issue with u-boot?
  4. Hi, guys. I'm using the last Armbian Cubieboard image (Armbian_23.11.1_Cubieboard_bookworm_current_6.1.63.img.xz) on my "Gemei G9" Allwinner A10 tablet. But via serial/UART the boot process stuck forever in "Starting kernel ...". Any tips on how to get the kernel to start? Thanks in advance Here is my boot log: U-Boot SPL 2023.10-armbian (Oct 13 2023 - 22:19:41 +0000) DRAM: 1024 MiB CPU: 1008000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2023.10-armbian (Oct 13 2023 - 22:19:41 +0000) Allwinner Technology CPU: Allwinner A10 (SUN4I) Model: Cubietech Cubieboard DRAM: 1 GiB Core: 68 devices, 23 uclasses, devicetree: separate WDT: Not starting watchdog@1c20c90 MMC: mmc@1c0f000: 0 Loading Environment from FAT... Unable to use mmc 0:1... Unknown monitor Unknown monitor In: serial,usbkbd Out: serial,vidconsole Err: serial,vidconsole Net: Could not get PHY for emac: addr 1 No ethernet found. 230454 bytes read in 12 ms (18.3 MiB/s) Unknown monitor starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 2 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 4121 bytes read in 2 ms (2 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 154 bytes read in 2 ms (75.2 KiB/s) 10691398 bytes read in 451 ms (22.6 MiB/s) 8420880 bytes read in 356 ms (22.6 MiB/s) Found mainline kernel configuration 33617 bytes read in 8 ms (4 MiB/s) Working FDT set to 43000000 4832 bytes read in 6 ms (786.1 KiB/s) Applying kernel provided DT fixup script (sun4i-a10-fixup.scr) ## Executing script at 45000000 Kernel image @ 0x42000000 [ 0x000000 - 0x807e10 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 10691334 Bytes = 10.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Working FDT set to 43000000 EHCI failed to shut down host controller. Loading Ramdisk to 495cd000, end 49fff306 ... OK Loading Device Tree to 4955c000, end 495ccfff ... OK Working FDT set to 4955c000 DE is present but not probed Starting kernel ...
