digicroxx
  1. Thank you @Carlos Ervedoso, it works. My fault I didn't follow with trust @jock's detailed installation manual. When I tried for the first time armbian and librelec images on h20 box, none of them was booting. Only the multitool worked. But after resetting the eMMC, even the multitool was no longer booting. The Armbian image still seemed not to boot (due to the absence of LEDs and HDMI of the default dtb; at that time I had not yet connections to the serial interface) so I (erroneously) deduced that for the h20 box the eMMC reset was a wrong step to take. My fault. Now it works fine: thanks again for your great job and for sharing it.
  2. Got it: you erased the internal flash. I will try the same, thank you for the clarification.
  3. Thank you for your feedback. Can you please explain me better this step?
  4. Hi @Carlos Ervedoso, so you are running Armbian on H20 tv box? Can you please summarize me what kernel version are you using, and what option you selected when you compiled the image? @jock; unfortunately adding overlays=led-conf7 in /boot/armbianEnv.txt didn't help in my case. I have to do more tests. Thanks a lot.
  5. Hi @NiTr0, it seems you were able to successfully boot Armbian on a Hongtop H20 tvbox. I'm trying to the same with Librelec, but I have similar issues as you had (boot stops after loading trustos). Can you please summarize briefly me what have you done to solve the issue? Thanks a lot.
