jan_axhell
  1. After hours of struggle I've managed to upgrade to OMV7 (too many passages to track) and now it works, except - one of the containers (Homarr) now points at "orangepi3lts:7575" instead of 192.168.1.168:7575 - none of the proxy hosts in Nginx Proxy Manager is resolved to Cloudflare domain. They are there on CF, looking good, the cloudflareddns service updates my public IP, but I keep getting error 523. I haven't touched anything net-related while upgrading, but something broke. Any idea? /etc/resolv.conf shows 192.168.1.1 search . 192.168.1.1 is my fritz.box which points at my 2 piholes, one of which is on the orangepi3lts itself
  2. I have the same exact problem on Orange Pi 3LTS. I was trying to update OMV6 to OMV7 and now I get that error. Also every time a do an apt update, I get N: Ignoring file 'key' in directory '/etc/apt/sources.list.d/' as it has no filename extension OMV UI now says there is an update for armbian-config, but if I try to install, it says 500 - Internal Server Error Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; export DEBIAN_FRONTEND=noninteractive; apt-get --yes --allow-downgrades --allow-change-held-packages --fix-broken --fix-missing --auto-remove --allow-unauthenticated --show-upgraded --option DPkg::Options::="--force-confold" dist-upgrade 2>&1' with exit code '100': Reading package lists... Building dependency tree... Reading state information... Calculating upgrade... The following packages will be upgraded: armbian-config N: Ignoring file 'key' in directory '/etc/apt/sources.list.d/' as it has no filename extension 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/119 kB of archives. After this operation, 612 kB disk space will be freed. dpkg-deb: error: archive '/var/cache/apt/archives/armbian-config_25.2.0-trunk.98.1128.095534_all.deb' uses unknown compression for member 'control.tar.zst', giving up dpkg: error processing archive /var/cache/apt/archives/armbian-config_25.2.0-trunk.98.1128.095534_all.deb (--unpack): dpkg-deb --control subprocess returned error exit status 2 Errors were encountered while processing: /var/cache/apt/archives/armbian-config_25.2.0-trunk.98.1128.095534_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
  3. I don't even remember if there was an original SD card when I bought it. I just remember that the USB hat never worked even changing some config settings. Anyway I have flashed a new one and reinstalled Pihole/Unbound/Gravity-Sync from scratch and it works fine. The previous SD is perfectly fine, so no failing/corruption problem there. It just stopped working from one day to another, after about a year of "piholeing". This time I have flashed Armbian_24.5.3_Orangepizero2_bookworm_current_6.6.31_minimal
  4. Hello, I've been using OPiZ2 for about 2 years as Pi-hole in gravity-sync with another one (Orange Pi 3 LTS running Open Media Vault with no problem). Today I found out it was dead, no connection and just a blank screen. It must have happened in the past few days, because I checked it on sunday and it was up and running. I'm almost sure I was using it with Armbian_22.11.0-trunk_Orangepizero2_sid_edge_6.0.6. i have extracted the sd card and checked it on Windows with Diskinternals reader and Minitool Partition Wizard, no problem found. The most recent files and folders have been modified on 2024-07-12, eleven days ago, much prior to my checking, so there is no info about the last hours/days. When I first installed Armbian, I used a version that would brick the OpiZ2 with apt upgrade, but a long time has passed and I don't remember if that issue was fixed. Now, can I somehow resuscitate this install? If not, can I clone/recover at least the pi-hole/unbound/gravitysinc settings? And what version of Armbian should I use? I've downloaded Armbian_24.5.3_Orangepizero2_bookworm_current_6.6.31_minimal, but I came here to ask before doing something.
