Hello how are you? I have exactly the same problem, when I ran armbian from SD it works perfectly but when I install in emmc with the script, it takes 15 minutes, it ends ok but when I turn off and remove the SD memory to boot from emmc the same thing happens to me, I put it again the SD and it works perfectly, I don't know what else to try, I tried with different versions of armbian, I tried to change the Android version so the boot changes and then I press it with armbian and there is no case, I would appreciate if someone knows something
