billhu199
Validating-
1 -
The latest version Bookworm cannot start up when use udisk
billhu199 replied to stonetv's topic in Amlogic CPU Boxes
Same issue. Mine is also a similar g12a device. I tested from 23.8.1 - 23.11.1 and all have problems. But works fine on my gxl device. G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:0;READ:0;0.0; bl2_stage_init 0x01 bl2_stage_init 0x81 hw id: 0x0000 - pwm id 0x01 bl2_stage_init 0xc1 bl2_stage_init 0x02 L0:00000000 L1:00000703 L2:00008267 L3:04000000 S1:00000000 B2:00002000 B1:e0f83180 TE: 96329 BL2 Built : 14:02:05, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz Board ID = 1 Set cpu clk to 24M Set clk81 to 24M CPU clk: 1200 MHz Set clk81 to 166.6M eMMC boot @ 0 sw8 s board id: 1 Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0 fw parse done PIEI prepare done 00000000 emmc switch 1 ok ddr saved addr:00016000 Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0 00000000 emmc switch 0 ok fastboot data verify result: 255 Cfg max: 12, cur: 1. Board id: 255. Force loop cfg LPDDR4 probe LPDDR4_PHY_V_0_1_22-Built : 15:59:30, May 25 2020. g12a gb6bfa83 - gongwei.chen@droid11-sz ddr clk to 1176MHz dmc_version 0000 Check phy result INFO : End of CA training INFO : End of initialization INFO : Training has run successfully! Check phy result INFO : End of initialization INFO : End of read enable training INFO : End of fine write leveling INFO : End of read dq deskew training INFO : End of MPR read delay center optimization INFO : End of Write leveling coarse delay INFO : End of read delay center optimization INFO : Training has run successfully! Check phy result INFO : End of initialization INFO : End of MPR read delay center optimization INFO : End of write delay center optimization INFO : End of read delay center optimization INFO : End of max read latency training INFO : Training has run successfully! 1D training succeed Check phy result INFO : End of initialization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D read delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : End of 2D write delay Voltage center optimization INFO : Training has run successfully! soc_vref_reg_value 0x 00000024 00000024 00000026 00000025 00000024 00000027 00000026 00000025 00000024 00000025 00000025 00000024 00000026 00000025 00000025 00000026 00000025 00000027 00000027 00000024 00000026 dram_vref_reg_value 0x 00000060 2D training succeed auto size-- 65535DDR cs0 size: 1024MB DDR cs1 size: 1024MB DMC_DDR_CTRL: 00e0001bDDR size: 2048MB cs0 DataBus test pass cs1 DataBus test pass cs0 AddrBus test pass cs1 AddrBus test pass non-sec scramble use zero key ddr scramble enabled 100bdlr_step_size ps== 447 result report boot times 1Enable ddr reg access 00000000 emmc switch 3 ok Authentication key not yet programmed get rpmb counter error 0x00000007 00000000 emmc switch 0 ok Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0 Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000dac00, part: 0 BL33 CHK: 0x000000ff ADDR 017a7170 Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 1 00000000 emmc switch 1 ok Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000dac00, part: 1 0.0;M3 CHK:0;cm4_sp_mode 0 [Image: g12a_v1.1.3394-7d43064d5 2020-05-07 15:37:06 gongwei.chen@droid11-sz] OPS=0x70 ring efuse init 28 0c 70 00 01 15 11 00 00 09 35 38 39 41 48 50 [1.072094 Inits done] secure task start! high task start! low task start! boot bl31 NOTICE: BL31: v1.3(release):079690f10 NOTICE: BL31: Built : 16:11:33, Nov 8 2021 NOTICE: BL31: G12A normal boot! NOTICE: BL31: BL33 decompress pass ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01 (Dec 30 2021 - 18:08:05) DRAM: 2 GiB Relocation Offset is: 76e3b000 mmu cfg end: 0x80000000 mmu cfg end: 0x80000000 spi_post_bind(spifc): req_seq = 0 register usb cfg[0][1] = 0000000077f387e8 NAND: get_sys_clk_rate_mtd() 292, clock setting 200! bus cycle0: 6,timing: 7 NAND device id: 0 ff ff ff ff ff No NAND device found!!! nand init failed: -6 get_sys_clk_rate_mtd() 292, clock setting 200! bus cycle0: 6,timing: 7 NAND device id: 0 ff ff ff ff ff No NAND device found!!! nand init failed: -6 MMC: aml_priv->desc_buf = 0x0000000073e2bd90 aml_priv->desc_buf = 0x0000000073e2e0d0 SDIO Port B: 0, SDIO Port 😄 1 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x1ff2800 emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x1ff2800 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 40000000 [set_emmc_calc_fixed_adj][875]find fixed adj_delay=20 init_part() 297: PART_TYPE_AML [mmc_init] mmc init success Amlogic multi-dtb tool GZIP format, decompress... Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: g12a platform: u212 variant: 2g dtb 0 soc: g12a plat: u212 vari: 1g dtb 1 soc: g12a plat: u212 vari: 2g dtb 2 soc: sm1 plat: ac213 vari: 2g Find match dtb: 1 start dts,buffer=0000000073e30920,dt_addr=0000000073e30920 get_partition_from_dts() 92: ret 0 Amlogic multi-dtb tool Single dtb detected parts: 18 00: logo 0000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000000000800000 1 03: dtbo 0000000000800000 1 04: cri_data 0000000000800000 2 05: param 0000000001000000 2 06: boot 0000000001000000 1 set has_boot_slot = 0 07: rsv 0000000001000000 1 08: metadata 0000000001000000 1 09: vbmeta 0000000000200000 1 10: tee 0000000002000000 1 11: vendor 0000000014000000 1 12: odm 0000000008000000 1 13: system 0000000050000000 1 14: product 0000000008000000 1 15: cache 0000000040000000 2 16: backup 0000000040000000 2 17: data ffffffffffffffff 4 init_part() 297: PART_TYPE_AML eMMC/TSD partition table have been checked OK! crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!! crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!! crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!! mmc env offset: 0x47400000 In: serial Out: serial Err: serial board_late_init: boardid = 0x1 reboot_mode=normal [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-3476: calc eef30c2, store eef30c2 _verify_dtb_checksum()-3476: calc eef30c2, store eef30c2 dtb_read()-3691: total valid 2 update_old_dtb()-3672: do nothing Amlogic multi-dtb tool GZIP format, decompress... Multi dtb detected Multi dtb tool version: v2 . Support 3 dtbs. aml_dt soc: g12a platform: u212 variant: 2g dtb 0 soc: g12a plat: u212 vari: 1g dtb 1 soc: g12a plat: u212 vari: 2g dtb 2 soc: sm1 plat: ac213 vari: 2g Find match dtb: 1 amlkey_init() enter! [EFUSE_MSG]keynum is 4 vpu: driver version: v20190313 vpu: detect chip type: 8 vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz) vpu: clk_level in dts: 7 vpu: vpu_power_on vpu: set_vpu_clk vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100) vpu: set_vpu_clk finish vpu: vpu_module_init_config vpp: vpp_init vpp: vpp osd2 matrix rgb2yuv.............. hdr_func 4, hdr_process_select 0x1 cvbs: cpuid:0x28 vdac_gsw_init: 0x0 cvbs: find clk_path: 0x0 cvbs: find performance_pal config cvbs: find performance_ntsc config hpd_state=0 do_hpd_detect: hdmimode=1080p60hz do_hpd_detect: colorattribute=rgb,8bit Saving Environment to aml-storage... mmc env offset: 0x47400000 Writing to MMC(1)... done aml_config_dtb 633 aml_config_dtb 663 co_phase = <0x00000003> caps2 = "??"_CAP2_HS200" status = "disabled" status = "okay" Net: dwmac.ff3f0000amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 wipe_data=successful wipe_cache=successful upgrade_step=2 reboot_mode:::: normal ext4logoLoadCmd=ext4load mmc 1:${logoPart} ${logoLoadAddr} ${ext4LogoPath} 6220854 bytes read in 180 ms (33 MiB/s) [imgread]load bmp from ext4 part okay bmp pixel: 24 [OSD]load fb addr from dts:/meson-fb [OSD]set initrd_high: 0x7f800000 [OSD]fb_addr for logo: 0x7f800000 [OSD]load fb addr from dts:/meson-fb [OSD]fb_addr for logo: 0x7f800000 [OSD]VPP_OFIFO_SIZE:0xfff01fff [CANVAS]canvas init [CANVAS]addr=0x7f800000 width=5760, height=2160 [OSD]osd_hw.free_dst_data: 0,719,0,575 [OSD]osd1_update_disp_freescale_enable vpp: vpp_matrix_update: 2 cvbs_performance_enhancement cvbs_config_hdmipll_g12a cvbs_set_vid2_clk vdac_enable: 1, module_sel:0x8 hdr_packet vpp: hdr_policy = 1 vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [KM]Error:f[key_manage_query_size]L515:key[oemkey] not programed yet Command: bcb uboot-command Start read misc partition datas! BCB hasn't any datas,exit! time_out = 7a120 key[0] = b8471420 key[1] = b847ff00 key[2] = 6699dd22 key[3] = 66994cb3 irkey - irkey <timeout> <key1> ...<keyN> - maximum value of N: 10 Usage: irkey - No additional help available. Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 card out (Re)start USB... USB0: USB3.0 XHCI init start Register 3000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... init_part() 282: PART_TYPE_DOS 1 Storage Device(s) found reading s905_autoscript 537 bytes read in 23 ms (22.5 KiB/s) ## Executing script at 01020000 start amlogic old u-boot ## Error: "bootfromsd" not defined card out ** Bad device mmc 0 ** reading boot_android ** Unable to read file boot_android ** card out ** Bad device mmc 0 ** reading u-boot.ext 740080 bytes read in 68 ms (10.4 MiB/s) ## Starting application at 0x01000000 ... U-Boot 2015.01-dirty (Aug 14 2020 - 19:56:34) DRAM: 2 GiB Relocation Offset is: 76eec000 spi_post_bind(spifc): req_seq = 0 register usb cfg[0][1] = 0000000077f83f48 MMC: aml_priv->desc_buf = 0x0000000073edc7c0 aml_priv->desc_buf = 0x0000000073edeb00 SDIO Port 😄 0, SDIO Port B: 1 Using default environment In: serial Out: serial Err: serial vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: driver version: v20190313 vpu: detect chip type: 8 vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz) vpu: clk_level = 7 vpu: vpu_power_on vpu: set_vpu_clk vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100) vpu: set_vpu_clk finish vpu: vpu_module_init_config vpp: vpp_init vpp: g12a/b osd1 matrix rgb2yuv .............. vpp: g12a/b osd2 matrix rgb2yuv.............. vpp: g12a/b osd3 matrix rgb2yuv.............. cvbs: cpuid:0x28 cvbs_config_hdmipll_g12a cvbs_set_vid2_clk co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x3, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x3, tx-dly 0, clock 400000 co-phase 0x1, tx-dly 0, clock 40000000 aml_sd_retry_refix[983]:delay = 0x0,gadjust =0x2000 [mmc_startup] mmc refix success [mmc_init] mmc init success Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** movi: not registered partition name, logo movi - Read/write command from/to SD/MMC for ODROID board Usage: movi <read|write> <partition|sector> <offset> <address> [<length>] - <read|write> the command to access the storage - <offset> the offset from the start of given partiton in lba - <address> the memory address to load/store from/to the storage device - [<length>] the size of the block to read/write in bytes - all parameters must be hexa-decimal only [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]set initrd_high: 0x3d800000 [OSD]fb_addr for logo: 0x3d800000 [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]VPP_OFIFO_SIZE:0xfff01fff [CANVAS]canvas init [CANVAS]addr=0x3d800000 width=5760, height=2160 cvbs: outputmode[1080p60hz] is invalid vpp: vpp_matrix_update: 2 set hdmitx VIC = 16 config HPLL = 5940000 frac_rate = 1 HPLL: 0x3b3a04f7 HPLL: 0x1b3a04f7 HPLLv1: 0xdb3a04f7 config HPLL done j = 6 vid_clk_div = 1 hdmitx phy setting done hdmitx: set enc for VIC: 16 enc_vpu_bridge_reset[1319] rx version is 1.4 or below div=10 Net: dwmac.ff3f0000MACADDR:02:00:00:11:15:01(from chipid) Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 (Re)start USB... USB0: USB3.0 XHCI init start Register 3000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 532 bytes read in 29 ms (17.6 KiB/s) 1: Armbian Retrieving file: /uInitrd reading /uInitrd 15122788 bytes read in 878 ms (16.4 MiB/s) Retrieving file: /Image reading /Image 27433472 bytes read in 1579 ms (16.6 MiB/s) append: root=UUID=b134c113-5cbe-4ccc-ab4a-6c24dde01dd3 rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymous Retrieving file: /dtb/amlogic/meson-g12a-u200.dtb reading /dtb/amlogic/meson-g12a-u200.dtb 72240 bytes read in 43 ms (1.6 MiB/s) [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed ## Loading init Ramdisk from Legacy Image at 03080000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15122724 Bytes = 14.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK active_slot is <NULL> Unknown command 'store' - try 'help' No dtbo patitions found load dtb from 0x1000000 ...... ERROR: Did not find a cmdline Flattened Device Tree load dtb from 0x0 ...... ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card out ** Bad device mmc 1 ** Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** odroidn2#
