Jaisere
13 -
How do I do this? I burned the working image to a usb, took the boot folder from it, I then burned the linaro img to a usb, when I plug the usb into my system it doesn't get detected, I did get an error during the burning, something to do with the linaro img file not containing valid partitions, im trying to reproduce the error to paste it verbatim, i have been using Etcher to burn these usbs edit: the error
cool, thank you so much for the help
if im understanding this correctly, if I burn the images too a usb / sd card, load into linux I should be able to move the 4.4 kernel into the rootfs, then turn that into its own image that I can burn to the on board nand with multitool? please correct me if im not quite understanding
@fabiobassa Hate to be a bother, but how exactly do I use the rootfs that you provided? the same way with multitool or some other process?
this sounds all good to me, thanks
awesome, its alright if I cant use Lima specifically (and I did suspect panfrost wouldnt be of use to me, I was just grasping at straws for a while) but if I can the graphics chip work at all would be a huge step forward, thanks
@fabiobassa and @RaptorSDS the issue isnt due to the desktop environment or it not booting, My system works with the 4.4 legacy, it just doesn't use the Mali400 chip for graphics. I provided the image of what happens when I use anything other than the legacy kernal as extra context, that doesnt happen when I update or upgrade, when I set up a desktop environment myself it works fine. I will try @fabiobassa's rootfs just to see what its about, and if it some how allows me to used the Lima, panfrost, or built in Mali drivers I will stick with it, thanks!
@jock yes it is indeed NAND, I have also read through the first page a few times when I first came across it, (thanks for the Quick installation instructions on NAND btw) I do want to use the internal flash rather than an external sd card or usb, (just for the fun of it tbh as its not like this is a mission critical device), I assume this basically has me locked off to the lima or panfrost drivers then? is it possible to compile my own on the device itself?
@jock the reason im using an image with the legacy 4.4 kernel is that when I use anything other than those images I get the results of the picture I sent
Hi, im having some GPU driver issues - RK-3229 - 4.4.194-legacy-rk322x some info: The image I am using on my device is; Armbian_22.02.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img I chose this, as any of the other images from here; https://users.armbian.com/jock/rk322x/armbian/stable/ other than the xfce desktop image would lead to this happening: (if there's a fix for this I'd rather use one of the more up to date images) with the bullseye legacy minimal image set up on my device I then did this: yes | sudo apt update yes | sudo apt dist-upgrade yes | sudo apt --fix-missing yes | sudo apt install neofetch chromium xorg xfce4 lightdm sudo reboot heres the neofetch output if it helps with anything: user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/drm/rockchip$ neofetch _,met$$$$$gg. user@rk322x-box ,g$$$$$$$$$$$$$$$P. --------------- ,g$$P" """Y$$.". OS: Debian GNU/Linux 11 (bullseye) armv7l ,$$P' `$$$. Host: Generic RK322x TV Box board ',$$P ,ggs. `$$b: Kernel: 4.4.194-legacy-rk322x `d$$' ,$P"' . $$$ Uptime: 58 mins $$P d$' , $$P Packages: 564 (dpkg) $$: $$. - ,d$$' Shell: bash 5.1.4 $$; Y$b._ _,d$P' Resolution: 1920x1080p60 Y$$. `.`"Y$$$$P"' Terminal: /dev/pts/0 `$$b "-.__ CPU: Generic DT based system (4) @ 1.200GHz `Y$$ Memory: 228MiB / 962MiB `Y$$. `$$b. `Y$$b. `"Y$b._ `""" when looking into the drivers I can find these: user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/arm/mali400/mali$ ls mali.ko user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/drm/rockchip$ ls rockchip_drm_tve.ko this is expected. I am aware from other posts and threads in the forums that for Mali400 I should install the Lima driver for it; when trying to use mesa to set up both Lima and Panfrost it typically fails because of missing dependencies (that when I try to manually install cannot be found) or has no issues but when I look into the drivers/gpu/(arm or drm) directories there is nothing different from what I previously showed and if I look for lima or panfrost within lsmod the modules are not in the list. appears like this: user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/drm/rockchip$ lsmod Module Size Used by lz4 16384 4 lz4_compress 16384 1 lz4 gpio_ir_recv 16384 0 mali 233472 0 snd_soc_rk3228 16384 1 lzo 16384 4 zram 24576 2 fuse 94208 1 ip_tables 24576 0 autofs4 32768 2 as a side note: user@rk322x-box:~$ export "DISPLAY=:0" user@rk322x-box:~$ xset -dpms user@rk322x-box:~$ LIBGL_ALWAYS_SOFTWARE=1 glxinfo | grep "OpenGL vendor\|OpenGL renderer" OpenGL vendor string: Mesa/X.org OpenGL renderer string: llvmpipe (LLVM 11.0.1, 128 bits) (output is the same when the command does not contain LIBGL_ALWAYS_SOFTWARE=1) (this is how I would check the renderer, I typically check from ssh as its easier to type commands from my pc due to the small amount of space I have in my setup, however even when im using the terminal on the tv box without ssh the result it the same) any help would be appreciated. thank you
Jaisere replied to Jaisere's topic in Rockchip CPU Boxes
alright, thanks for letting me know -
@SteeMan Yeah I have followed the thread, read through it a couple times due to confusing results, as well as having issues with using builds other than the legacy images I mentioned -
some info: The image I am using on my device is; Armbian_22.02.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal.img I chose this, as any of the other images from here; https://users.armbian.com/jock/rk322x/armbian/stable/ other than the xfce desktop image would lead to this happening: (if there's a fix for this I'd rather use one of the more up to date images) with the bullseye legacy minimal image set up on my device I then did this: yes | sudo apt update yes | sudo apt dist-upgrade yes | sudo apt --fix-missing yes | sudo apt install neofetch chromium xorg xfce4 lightdm sudo reboot heres the neofetch output if it helps with anything: user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/drm/rockchip$ neofetch _,met$$$$$gg. user@rk322x-box ,g$$$$$$$$$$$$$$$P. --------------- ,g$$P" """Y$$.". OS: Debian GNU/Linux 11 (bullseye) armv7l ,$$P' `$$$. Host: Generic RK322x TV Box board ',$$P ,ggs. `$$b: Kernel: 4.4.194-legacy-rk322x `d$$' ,$P"' . $$$ Uptime: 58 mins $$P d$' , $$P Packages: 564 (dpkg) $$: $$. - ,d$$' Shell: bash 5.1.4 $$; Y$b._ _,d$P' Resolution: 1920x1080p60 Y$$. `.`"Y$$$$P"' Terminal: /dev/pts/0 `$$b "-.__ CPU: Generic DT based system (4) @ 1.200GHz `Y$$ Memory: 228MiB / 962MiB `Y$$. `$$b. `Y$$b. `"Y$b._ `""" when looking into the drivers I can find these: user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/arm/mali400/mali$ ls mali.ko user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/drm/rockchip$ ls rockchip_drm_tve.ko this is expected. I am aware from other posts and threads in the forums that for Mali400 I should install the Lima driver for it; when trying to use mesa to set up both Lima and Permafrost it typically fails because of missing dependencies (that when I try to manually install cannot be found) or has no issues but when I look into the drivers/gpu/(arm or drm) directories there is nothing different from what I previously showed and if I look for lima or permafrost within lsmod the modules are not in the list. appears like this: user@rk322x-box:/lib/modules/4.4.194-legacy-rk322x/kernel/drivers/gpu/drm/rockchip$ lsmod Module Size Used by lz4 16384 4 lz4_compress 16384 1 lz4 gpio_ir_recv 16384 0 mali 233472 0 snd_soc_rk3228 16384 1 lzo 16384 4 zram 24576 2 fuse 94208 1 ip_tables 24576 0 autofs4 32768 2 as a side note: user@rk322x-box:~$ export "DISPLAY=:0" user@rk322x-box:~$ xset -dpms user@rk322x-box:~$ LIBGL_ALWAYS_SOFTWARE=1 glxinfo | grep "OpenGL vendor\|OpenGL renderer" OpenGL vendor string: Mesa/X.org OpenGL renderer string: llvmpipe (LLVM 11.0.1, 128 bits) (output is the same when the command does not contain LIBGL_ALWAYS_SOFTWARE=1) (this is how I would check the renderer, I typically check from ssh as its easier to type commands from my pc due to the small amount of space I have in my setup, however even when im using the terminal on the tv box without ssh the result it the same) any help would be appreciated. thank you
