Blaize
  1. no not yet
  2. I found it. after searching I came across this repo on GitHub https://github.com/warpme/miniarch/releases/tag/20231112-6.6.8 I have not tried it yet, but I have realized for the h313 x96q, now I have not tried anything, but here are the supposed steps 1- Wrote img to SD card using Etcher 2- Inserted SD card in Device 3- Powered ON the device and it Booted from SD card 4- followed update instructions on GitHub Repo. 5- Rebooted after all updates, 6- Basic Arch was ready to be used Here USB keyboard , LAN, HDMI worked normally. After reboot, logged in as root, and ran "start" command, Now here selected option 5, which is install EndeavourOS Process just ask you Yes/No questions, then you can select your DE, location etc. Automated script downloaded bunch of files and started its installation. Got the message that installation is done successfully and came back to terminal. Rebooted from terminal After this point got only blank screen , dont know it is still booting without HDMI or not So need to revert back to step -1 writing basic image to SD card. And this time sticking to terminal only.
  3. So i have a x96q with a h313 coming soon. I got it from https://www.temu.com/goods.html?_bg_fs=1&goods_id=601099525915611 the specs are CPU: Allwinner H313 Quad Core ARM Cortex A53 GPU: G31 OPenGL3.2 OS: Android 10.0 RAM: 1GB/2GB ROM: 8GB/16GB Wi-Fi version: 802.11b, 802.11g, 802.11n Resolution standard: 4K How would I go about installing this. I read that bigtreetech-cb1 works, but no wifi. Is this the best option?
