Hello,
	there is a lot of useful information on the whole forum and particular in this topic on a specific problem.
	I'm trying to restore a TV Box that I bricked myself by putting the wrong image inside (I didn't try if image boots before that).
	Hardware: MXQ PRO 5G (rk3228a, 1GB RAM, 8GB)
	I was able to get the device into MaskRom mode and successfully boot from SD card.
	I tried to flash an image using AndroidTool_Release_v2.69 but it gives errors for any type of device operations.
	My problems are:
	1.The memory of the device is eMCP and the latest version of multitool does not see it...
	In the forum I saw screenshots with a version of Multitool "build 52d0101 14 Mar 2021" which has more options (maybe support eMCP) but i can't find this version anywhere...
	2.After putting the device into MaskRom mode, I manage to launch Multitool or even start to launch Armbian, but after about 60 sec. the picture disappears (apparently, the device does not restart, but stops sending a signal via HDMI - and the LED continues to glow blue)
	I have found a version of Armbian that runs on this device and wanted to try installing it from the SD card into the eMCP, but this 60 sec problem catches me at the moment where I change my password.
	Have you had similar problems with these or any other type of devices?
	Can you advise me how to revive the device?
	Thank you in advance for your time.
