svarog
  1. Hi, I am new here so please apologize if I am asking already asked question, but I couldn't find the solution. I am trying to install docker on my orange pi zero 3 which is running Armbian (24.2.0-trunk.519) aarch64, kernel version 6.6.15-current-sunxi64. I have found this post, but I was not able to install docker because I found 2 problem that I don't know how to solve. 1. Installing docker using armbian-config does not work. I install armbian-config, run it as su/sudo, choose docker and install. The installer does something and after it's done it returns me to the same screen where I have chosen docker to be installed. So, no confirmation that I have installed the software, even star is omitted near docker(if you know what I mean). 2. Following the instructions from docker page, I follow every single step, but when it comes to the command svarog@orangepizero3:~$ sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin Reading package lists... Done Building dependency tree... Done Reading state information... Done Package docker-ce is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package docker-ce-cli is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'docker-ce' has no installation candidate E: Package 'docker-ce-cli' has no installation candidate E: Unable to locate package containerd.io E: Couldn't find any package by glob 'containerd.io' E: Couldn't find any package by regex 'containerd.io' E: Unable to locate package docker-buildx-plugin E: Unable to locate package docker-compose-plugin this is the response that I get. Maybe I am missing something or I am total noob, but I am pretty sure that the installer is done correctly(I mean the documentation) and the only thing that could be wrong is me... Can you please help me to figure out why I cannot install docker and what am I doing wrong in the process? thanks
