For Ward
  1. Hello...I successfully installed Trixie on the BBAI-64. It is a beagleboard.org board from earlier in the 2020s. https://www.beagleboard.org/blog/2025-04-18-armbian-support-is-here Anyway, I was wondering if there was some way to handle installing and configuring Wifi access to the BBAI-64 that anyone around here knew of currently. Ethernet works. I can get online. Also, there is a set up in `armbian-config` that may allow OctoPrint to be installed. It seems one needs to add support for Docker first. The Docker install from Trixie is not available on kernel 6.6.x so far. Seth P.S. Um, I understand that some people now are short handed on replies and adding additional support without compensation. I understand completely. Things are not free in life. Maybe just a couple ideas and/or placements of ideas directing could help. For instance, is there a particular SS (subsystem) in Linux where I would need to gather specific files to handle the available configuration on the e-key M2 that makes Wifi available on the BBAI-64? Any and all ideas are welcomed.
  2. Hello, hastebin - iqolofuzis (armbian.com) That is my hastebin paste made from a recently built BeagleV-Ahead board that has a four core, RISCV processor. The TH1520 or four c910 processors make up the bulk of the board with some extra functionality. I have been trying to build for this board recently and again. Anyway, there is a u-boot function in the mix of building an Armbian Jammy image that is called /dev/loop. It seems this is where my current errors are located in the build. Please send some advice. Seth P.S. Here is what I think makes up the main issue: [💲|🌱] Writing u-boot bootloader [ /dev/loop2 ] /home/karlth/build_armbian/lib/functions/image/loop.sh: line 89: write_uboot_platform: command not found
  3. ``` [🐳|🔨] [🐳|🔨] The following packages have unmet dependencies: [🐳|🔨] mtd-utils : Depends: libssl3 (>= 3.0.0) but it is not installable [🐳|🔨] E: Unable to correct problems, you have held broken packages. ``` This seems to be an issue of mine so far... I can build up to this point and it errors out? Seth
  4. hastebin - gitinavahi (armbian.com) That is my current dilemma... @KREYREN, do you see what I did that is incorrect? No board file? I am not sure exactly how to approach this build yet... Seth
  5. @KREYREN, Do not worry about it. I am way off as usual. I will attempt another build soon... Seth
  6. This is the error: `find: ‘Module.symvers’: No such file or directory` . Seth P.S. I remember I made it this far once and there were options to handle the issue.
  7. hastebin - ejojenuqib (armbian.com) Seth
  8. @KREYREN Seth here. I changed names and email addresses. Anyway, I fell off and I am going to retry. Seth P.S. I am way underdeveloped to handle it right now, e.g. still building to bring upon good times on my end. Anyway, I will update you shortly in the next few weeks or so.
