7 -
Raspberry Pi4 apt-get update problems
Sid Boyce replied to Sid Boyce's topic in Software, Applications, Userspace
My problem was due to IPS (Intrusion Prevention System) being enabled on my IPFire firewall box. When I did a search on the IPFire forum I found I had raised an issue some time ago -- not able to access only www.arduino.cc and that was due to IPS being enabled. Recent IPFire upgrades automatically turned it on. -
Fixed by disabling Intrusion Prevention Service (IPS) in IPFire. Strangely I found a topic I submitted a long time ago where I couldn't get to arduino.cc in a browser which was fixed by disabling IPS. When upgrading IPFire, IPS got enabled by default. -
Searches suggest a USB reset script will fix but that says nothing found. It comes up after unplugging and replugging the dongle. Already configured with "nmcli c add type ethernet ifname enx00e04c68080d con-name HiQSDR autoconnect yes save yes ip4 192.168.2.196/24" After boot, nothing in lsusb for it and dmesg -T does not show it. Bus 001 Device 014: ID 0bda:8152 Realtek Semiconductor Corp. RTL8152 Fast Ethernet Adapter Things tried:- root@rpi4b:~# cat /etc/os-release PRETTY_NAME="Armbian 24.2.1 jammy" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04.3 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=jammy ARMBIAN_PRETTY_NAME="Armbian 24.2.1 jammy" root@rpi4b:~# cat /etc/udev/rules.d/40-modeswitch.rules # Copyright (C) 2009-2014 Stephan Raue (stephan@openelec.tv) ACTION!="add|change", GOTO="end_modeswitch" KERNEL!="sr[0-9]*", GOTO="end_modeswitch" SUBSYSTEM!="block", GOTO="end_modeswitch" root@rpi4b:~# vcgencmd bootloader_config [all] BOOT_UART=0 WAKE_ON_GPIO=1 POWER_OFF_ON_HALT=0 # Realtek RTL8152 chipset USB lan NIC # initial cdrom mode 0bda:8152, lan mode 0bda:8153 ATTRS{idVendor}=="0bda", ATTRS{idProduct}=="8152", RUN+="/tmp/setupusblanadapter.sh" LABEL="end_modeswitch" https://forums.raspberrypi.com/viewtopic.php?t=336517 doesn't help --- didn't try installing the suggested firmware root@rpi4b:~# raspi-config nonint do_boot_rom E1 /usr/bin/raspi-config: 1506: [: Illegal number: BOOTLOADER: up to date CURRENT: Thu May 11 06:26:03 AM UTC 2023 (1683786363) LATEST: Thu May 11 06:26:03 AM UTC 2023 (1683786363) RELEASE: stable (/lib/firmware/raspberrypi/bootloader-2711/stable) Use raspi-config to change the release. VL805_FW: Dedicated VL805 EEPROM VL805: up to date CURRENT: 000138c0 LATEST: 000138c0
Found a similar problem and fix with arduino.cc on the IPFire firewall forum ... Disabling "Intrusion Prevention System" in IPFire has fixed it. -
root@rpi4b:/etc/apt# cat /etc/resolv.conf # Generated by NetworkManager search cable.virginm.net localdomain nameserver 194.168.4.100 nameserver 194.168.8.100 nameserver 192.168.10.103 Changed the first nameserver to 8.8.8.8 root@rpi4b:/etc/apt# apt-get update Ign:1 http://ports.ubuntu.com jammy InRelease Ign:2 http://cli.github.com/packages stable InRelease Ign:3 http://apt.armbian.com jammy InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:5 http://ports.ubuntu.com jammy-security InRelease Ign:2 http://cli.github.com/packages stable InRelease Ign:3 http://apt.armbian.com jammy InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:6 http://ports.ubuntu.com jammy-updates InRelease Ign:2 http://cli.github.com/packages stable InRelease Ign:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Ign:3 http://apt.armbian.com jammy InRelease Ign:7 http://ports.ubuntu.com jammy-backports InRelease Err:2 http://cli.github.com/packages stable InRelease Connection failed [IP: 185.199.109.153 80] Err:3 http://apt.armbian.com jammy InRelease Connection failed [IP: 130.185.239.78 80] Err:4 http://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease Connection failed [IP: 35.185.44.232 80] 0% [Waiting for headers]^C root@rpi4b:/etc/apt I am running my network through IPFire firewall. I'll check to see if there is a recent change with the latest version that may be causing this to happen -
root@rpi4b:/etc/apt# ping 130.185.239.78 80 PING 130.185.239.78 (130.185.239.78): 56 data bytes 64 bytes from 130.185.239.78: icmp_seq=0 ttl=49 time=107.169 ms 64 bytes from 130.185.239.78: icmp_seq=1 ttl=49 time=107.792 ms 64 bytes from 130.185.239.78: icmp_seq=2 ttl=49 time=106.246 ms 64 bytes from 130.185.239.78: icmp_seq=3 ttl=49 time=107.586 ms 64 bytes from 130.185.239.78: icmp_seq=4 ttl=49 time=106.834 ms 64 bytes from 130.185.239.78: icmp_seq=5 ttl=49 time=107.063 ms http to the site doesn't work, https gives a warning and I can connect clicking on "Accept risk and Continue" -
What ever I try I get Ign or Errors. Happens also on all Pi4's that had been working for years as well as for a new install I am attempting using Armbian_24.2.1_Rpi4b_jammy_current_6.6.16_xfce_desktop.img.xz root@rpi4b:/etc/apt# apt --allow-unauthenticated upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages have been kept back: gir1.2-gdm-1.0 iptables libgdm1 libip4tc2 libip6tc2 libxtables12 The following packages will be upgraded: coreutils gir1.2-javascriptcoregtk-4.0 gir1.2-webkit2-4.0 libjavascriptcoregtk-4.0-18 libwebkit2gtk-4.0-37 linux-libc-dev 6 upgraded, 0 newly installed, 0 to remove and 6 not upgraded. Need to get 32.2 MB of archives. After this operation, 269 kB disk space will be freed. Do you want to continue? [Y/n] Ign:1 http://ports.ubuntu.com jammy-updates/main arm64 coreutils arm64 8.32-4.1ubuntu1.1 Ign:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Ign:3 http://ports.ubuntu.com jammy-security/main arm64 gir1.2-webkit2-4.0 arm64 2.42.5-0ubuntu0.22.04.2 Ign:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Ign:4 http://ports.ubuntu.com jammy-security/main arm64 gir1.2-javascriptcoregtk-4.0 arm64 2.42.5-0ubuntu0.22.04.2 Ign:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Ign:5 http://ports.ubuntu.com jammy-security/main arm64 libwebkit2gtk-4.0-37 arm64 2.42.5-0ubuntu0.22.04.2 Err:2 http://apt.armbian.com jammy/main arm64 linux-libc-dev arm64 23.02.2 Connection failed [IP: 130.185.239.78 80] Ign:6 http://ports.ubuntu.com jammy-security/main arm64 libjavascriptcoregtk-4.0-18 arm64 2.42.5-0ubuntu0.22.04.2
