Hi, I have tried that and the burn tool errors out
Uboot/Get Result/ Disk initial error
And this is the serial output
Attempt 1:
ATA transfer complete...
PIEI prepare done
DDR4 probe
ddr clke
DATA transfer complete...
AML DDR FW load done
DATA transfeone
DATA transization
INFO : End of write delay center optimization
INFO : Elly!
1D init succeed
Check phy resu 00000019 00000019 0000001a 00000017 00000019 00000017 00000018 00000018 00000019 dram_vref_reg_value 0x 0000006 1024MB
DMC_DDR_CTRL: 00e0001bDDR size: 2048MB
cs0 DataBus tesspi_post_bind(spifc): req_seq = 0
[MSG]MMC init in usb
aml_priSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:82;SD?:20000;USB:8; cfg
ddr probe id done
fw parse donCheck phy result
INFO : End of initialization
INFO : ERROR : Tlt
0.0;C
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:15000020
S1:00000000
B2:20282000
B1:a0f83180
TE: 2781386
BL2 Built : 20:29:41, Jun 18 2019. g12a ga659aac - luan.yuan@droid15-sz
Board ID = 12
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
DDR driver_vesion: LPDDR4_PHY_V_0_1_15 build time: Junfg
ddr probe id done
fw parse done
PIEI prepare done
DDR3 probe
ddr
dmc_version 0001
2MHz
dmc_version 0001
Check phy rnd of read delay center optimization
INFO : End of max read latINFO : End of 2D read delay Voltage center optimization
018 00000019 00000019 00000018 00000017 00000019 00000016 000000t
aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 201-2: Chip: SM1 Rev: C (2B:C - 10:2)
INFO: BL3-2: crypto enginv->desc_buf = 0x0000000073e40a70
aml_priv->desc_buf = 0x0000000[MSG]sof
Set Addr 10
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
b 3 soc: sm1 plat: ac213 vari: 4g
Find match dtb: 2
clock 400000
emmc/sd response timeout, cmd8, status=0x1ff2800
found!!!
nand init failed: -6
get_sys_clk_rate_mtd() 290, clocg
cmd [store init 3] init failed
[info]failed:
001000000, sz=0x14552
[MSG]Burn complete
BULKcmd[download get_BULKcmd[disk_initial 1]
Amlogic multi-dtb tool
GZI0
co-phase 0x3, tx-dly 0, clock 400000
co-phase 0x3, tx-dly 0,, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, statuscess
BULKcmd[ low_power]
[info]success
ID[16]
tplcmd[ P format, decompress...
Multi dtb detected
Multi d
emmc/sd response timeout, cmd55, status=0x1ff2800
co-phase 0x3k setting 200!
NAND device id: 0 ff ff ff ff ff
No NAND devicSM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:800;NAND:82;SD?:20000;USB:8;55. Force loop cfg
fw parse done
DAining
INFO : End of MPR read delay center optimization
INFO : INFO : End of 2D write delay Voltage center optimization
INFO : Training has run successfully!
channel==0
RxClkDly_Margin_A0==149 ps 11
TxDqDly_Margin_A0==149 ps 11
RxClkDly_Margin_A1==rainedVREFDQ_A1==74
VrefDac_Margin_A0==29
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==28
DeviceVref_Margin_A1==40
channel==1
RxClkDly_Margin_A0==135 ps 10
TxDqDly_Margin_A0==149 ps fDac_Margin_A0==27
VrefDac_Margin_A1=t
aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2012241b5 2019-07-02 17:22:49 luan.yuan@droid15-sz]
OPS=0x10
ri073e42db0
SDIO Port B: 0, SDIO Port C: 1
Cfg max: 5, cur: 2. Board id: 255. Force loop cfg
ddr probe idid done
fw parse done
DATA transfere id done
fw parse done
DATA transftage center optimization
=28
dwc_ddrphy_apb_wr((0<<20)|(2<<4
2D init succeed
ddr init done, boot next stage
result reporng efuse init
2b 0c 10 00 01 19 15 00 00 18 37 31 56 52 52 50 iver_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2019 20:29:37
board id: 12
Cfg max: 5, cur: 1. Board id: 2er complete...
INFO : End of read dq deskew traINFO : End of 2D read delay Voltage center optimization
149 ps 11
TxDqDly_Margin_A1==135 ps 10
TrainedVREFDQ_A0==74
T11
RxClkDly_Margin_A1==135 ps 10
TxDqDly_Margin_A1==149 ps 11
TrainedVREFDQ_A1==74
Vre16)|(0<<12)|(0xb0):0004
soc_vref_reg_value 0x 0000001a 00000 00000018 00000019 00000019 00000016 00000018 00000017 00000018 00000017 00000018 dram_vref_reg_value 0x 0000006t pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBu
[0.017355 Inits done]
secure task start!
high task start!
[MSG]Burn complete
BULKcmd[download get_ 0000000000200000 1
10: tee 0000000002000e 0x3, tx-dly 0, clock 400000
co-phase 0x3, tx-dly 0, clock 400[info]success
[MSG]Burn Start...
[MSG]load dt.img to 0x000000000800000 1
01: recovery 0000000001800000 1
02: misc 0000, clock 400000
emmc/sd response timeout, cmd8, response timeout, cmd8, status=0x1ff2800
ID[16]
tplcmd[ echo 12345]
12345
[MSG]ret = 0
[info]sucstatus]
[info]success
oot 0000000001000000 1
set has_boot_slot = 0
07: rsv 000esponse timeout, cmd55, status=0x1ff2800
NAND init failed
deviceINFO : End of 2D read delay Voltage center optimization
INFO :149 ps 11
TDac_Margin_A0==28
VrefDac_Margin_A1==
aml_ddr_fw_vesion: LPDDR4_PHY_V_0_1_15 build time: Jun 18 2019c40b1
NOTICE: BL31: Built : 15:57:33, May 22 2019
NOTICE: BLEVICE_SECURE 0xb200000e
U-Boot 2015.01-g32cc24e (Aug 26 202SM1: transfer complete...
dmc_version 0001
Check phy result
INFd done
fw parse done
DATA transfer d!
Cfg max: 5, cur: 4. Board id: 255. Force loop cfg
ddr probend of initialization
INFO : End of read enable training
INFO : initialization
channel==0
RxClkDly_Margin_A27
dwc_ddrphy_apb_wr((0<<20)|(2<<1 pass
cs1 AddrBus
low task start!
run into bl31
NOTICE: BL31: v1.3(release):4fSet Addr 14
Get DT cfg
82000
B1:a0f83180
TE: 2727178
BL2 Built : 20:29:41, Jun 1lete...
PIEI prepare done
DDR4 probe
ddr clk to 1152MHz
DATATA transfer complete...
dmc_version 0001
Check phy result
IPIEI prepare done
LPDDR4 probe
ddr clk to 1152MHz
DATA transf End of fine write leveling
INFO : End of Write leveling coarse 00000018 00000019 0000001a 00000016 00000017 00000016 00000019 00018 00000018 00000019 00000019 dram_vref_reg_value 0x 00000063 test pass
RUN bl2 usb boot
MVN_1=0x00000000
MVN_2=0x00000000
[Image: g12a_v1.1.3389-9Get DT cfg
Get DT cfg
set CFG
[MSG]Burn complete
BULKcmd[download get_ 4g
dtb 2 soc: sm1 plat: ac213 vari: 2g
dto 0000000000800000 1
02: clock 400000
setting 200!
No NAND device 14552) fmt(normal)
[MSG]totalSlotNum = 0, nextWriteBackSlot 2
: sm1 platform: ac213 variant: 2g
dtb 0 soc: g12a plalti-dtb tool
Single dtb detected
parts: 17
00: log 0000000008000000 1
13: system 0000000080000000 1
14: proe found!!!
NAND init fail
ID[16]
tplcmd[ echo 12345]
12345
[MSG]ret = 0
[info]success
BULKcmd[ low_power]
[info]success
ID[16]
tplcmd[ status]
[info]success
Find match dtb: 2
rsv 0000000001000000 1
08: metadata 0000000001000000 1
09:0
co-phase 0x3, tx-dly 0,ut, cmd8, status=0x1ff2800
co-phase 0x3, tx-dly 0, clock 400000, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, statusþðüÿ<ø~
Attempt 2:
0.0;C
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 -plete...
PIEI prepare done
DDR4 probe
ddr clk to 1152MHz
DAT!
Cfg max: 5, cur: 3. Board id: 255. Force loop cfg
ddr probe
PIEI prepare done
LPDDR4 probe
ddr clk to 1152MHz
DATA transINFO : Training has run successfully!
Check phy result
INFO : f initialization
c40b1
NOTICE: BL-13-gc341bc0 #1 Thu Jun 27 19:33:34 2019 +0800 arm
INFO: BL3spi_post_bind(spifc): req_seq = 0
aml_priInUsbBurn
[MSG]sof
download mem dtb normal 83282]
[MSG]Down(mem) part(dtb) sz(0x000000800000 1
03: dtbo 0000000000800000 1
04: cri_data nand init failed: -6
get_sys_clk_rate_mtd() 290, clock setting BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;8 2019. g12a ga659aac - luan.yuan@droid15-sz
Board ID = 12
SCfg max: 5, cur: 2. Board id: 255. Force loop cfg
ddr probe id complete...
PIDATA transfer complete...
dmc_version 0001
Check phy result
of CA training
I delay
Check phy result
el==1
TxDqDly_Margin_A0==149 ps _A1==149 ps 11
Vrefa 00000018 00000016 00000018 00000016 0000001b 00000017 00000016 20:29:43
auto size-- 65535DDR cs0 size: 1024MB
DDR cs1 size: 31: G12A normal boot!
0 - 10:58:36)
DRAM: 2 GiB
Relocation Offset is: 76e50000
InUsbBurn
tb tool version: v2 .
Support 4 dtbs.
aml_dt soc cri_data 0000000000800000 2
05: param 0000000001000000 2
No NAND devic
