Maverick
  1. Thanks for the response guys. and let me tell you the exact reason why I am seeking help for Wiring pi. So basically we have developed baseboard for banana pi cm4 which has on board: WS2812B LEDs Real-time clock (RTC) RF transceiver IR transceiver XBee module SD card slot MPU6030 motion sensor. WiringPi's extensive Python libraries offer a convenient way to interact with these peripherals. While Raspberry Pi/Other supported board enjoys mature GPIO (support through WiringPi, similar functionality remains limited for Banana Pi CM4. I am Seeking Guidance, Not a Complete Solution, Let me clarifies my objective: My aim to gain knowledge and navigate the process independently. Sharing my findings and experiences with the community is intended. I welcome any insights or alternative solutions that the community might possess. I appreciate the previous responses and support. Again I require assistance in utilizing WiringPi for Banana Pi CM4. Limited GPIO support on Banana Pi CM4 hinders the direct use of WiringPi. I am seeking guidance and knowledge to overcome this obstacle. Thank you again.
  2. @usual user is not compiling on banana pi cm4 board.
  3. @Igor Thank you for response. I have used this solution. but I want some python library to use it directly with python.
  4. unable to access gpio using wiringpi python. I have tried steps available on banana pi wiki. but it throws error "/dev/gpiomem" is not available and then "This board is not odroid". did anyone successfully implemented this?
