Dave2024
12 -
Hi Nick. I'm on a business trip now, I'll be able to check on Monday. Maybe I'm just not assembling the firmware correctly? I’ll try to compile it again and publish the output of dmesg or whatever you suggest to understand the problem. Thank you very much for your time and help.
dtb dtb.0 dtb.0.dts dtb.0.dts.yamlThis is it?
I already understood this, what file is needed there? dtb.0.dts.yaml
I did not find the *.dtb file in the unpacked file. I'll try to do the same with vendor_boot_a
Thanks, renaming helped
Another problem appeared here is the result of ./gradlew unpack ./gradlew unpack Downloading https://services.gradle.org/distributions/gradle-8.7-rc-3-bin.zip ............10%.............20%.............30%.............40%............50%.............60%.............70%.............80%.............90%............100% Welcome to Gradle 8.7-rc-3! Here are the highlights of this release: - Compiling and testing with Java 22 - Cacheable Groovy script compilation - New methods in lazy collection properties For more details see https://docs.gradle.org/8.7-rc-3/release-notes.html Starting a Gradle Daemon (subsequent builds will be faster) > Task :helper:compileKotlin w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/CryptoHelper.kt:123:25 The value 'true' assigned to 'var bSuccess: Boolean defined in cfig.helper.CryptoHelper.KeyBox.Companion.parse4' is never used w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/CryptoHelper.kt:127:29 The value 'false' assigned to 'var bSuccess: Boolean defined in cfig.helper.CryptoHelper.KeyBox.Companion.parse4' is never used w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/CryptoHelper.kt:132:29 The value 'false' assigned to 'var bSuccess: Boolean defined in cfig.helper.CryptoHelper.KeyBox.Companion.parse4' is never used w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/CryptoHelper.kt:502:43 Variable 'obj' initializer is redundant w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/CryptoHelper.kt:521:29 Variable 'obj' is never used w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/CryptoHelper.kt:533:47 Variable 'obj' initializer is redundant w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/Launcher.kt:83:19 Variable 'cmd' is never used w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/ZipHelper.kt:120:37 'getter for nextZipEntry: ZipArchiveEntry!' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/ZipHelper.kt:162:13 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/helper/src/main/kotlin/cfig/helper/ZipHelper.kt:179:13 'constructor ZipFile(String!)' is deprecated. Deprecated in Java > Task :bbootimg:compileKotlin w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/avb/desc/HashDescriptor.kt:88:43 Parameter 'parent' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/bootimg/cpio/AndroidCpio.kt:227:33 'getter for nextCPIOEntry: CpioArchiveEntry!' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/bootimg/v3/BootV3.kt:258:17 Variable 'ai' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/init/BootReason.kt:8:66 Parameter 'subReason' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/init/BootReason.kt:8:86 Parameter 'detail' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/BrilloPropString.kt:55:22 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/BrilloPropString.kt:64:13 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/BrilloPropString.kt:105:9 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/BrilloPropString.kt:151:9 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/Common.kt:39:13 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/Payload.kt:125:41 Parameter 'sig_data' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/Payload.kt:125:63 Parameter 'pubkey' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/Payload.kt:125:79 Parameter 'sigHash' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/PayloadGenerator.kt:95:26 'constructor ZipFile(String!)' is deprecated. Deprecated in Java w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/ota/PayloadGenerator.kt:173:30 Unchecked cast: Pair<String, String?> to Pair<String, String> w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/packable/OTAzipParser.kt:68:34 Parameter 'fileName' is never used w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/rom/sparse/ErofsGenerator.kt:28:74 Unnecessary non-null assertion (!!) on a non-null receiver of type HashTreeDescriptor w: file:///home/user/tv/Android_boot_image_editor/bbootimg/src/main/kotlin/rom/sparse/SparseImage.kt:242:21 Variable 'ai' is never used > Task :unpack FAILED 16:05:57.128 [main] WARN cfig.packable.PackableLauncher - No handler is activated, DO NOTHING! FAILURE: Build failed with an exception. * What went wrong: Execution failed for task ':unpack'. > Process 'command '/usr/lib/jvm/java-17-openjdk-amd64/bin/java'' finished with non-zero exit value 2 * Try: > Run with --stacktrace option to get the stack trace. > Run with --info or --debug option to get more log output. > Run with --scan to get full insights. > Get more help at https://help.gradle.org. BUILD FAILED in 3m 35s 10 actionable tasks: 10 executed
Thanks, I figured it out. You just had to give the adb root command after adb connect. I'll post it when it's ready
dmitriy@dmitriy-UN62V:~/tvbox/Android_boot_image_editor$ adb -s 192.168.5.161:5555 pull /dev/block/platform/soc@3000000/4022000.sdmmc/by-name/boot_a adb: error: failed to copy '/dev/block/platform/soc@3000000/4022000.sdmmc/by-name/boot_a' to './boot_a': remote open failed: Permission denied
Good evening. Nick is similar but not quite the same. I have one like this. The seller called it QPLOVE Q18. Thanks for the WiFi tip. I'll try to slip this patch. And yes, I used the latest build with kernel 6.7. Here is a link to such a console https://www.amazon.com/dp/B09P9KL1XY
Hi Nick. I published a photo earlier in this thread. Board T95ZPlus. AllWinner H618 4/64. Here is the link ..... https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/?do=findComment&comment=183422
Good afternoon. Sorry, I'm just new to this and just learning. As a result, I was able to compile my own firmware to make only the network card work, and even then only for 100 MB. In Android it works on 1GB. Sound via HDMI does not work 😞 WiFi and bluetooth do not work. I have these modules on the AW869A chip. Is it possible to include support for this chip in the patches?
Hello I tried this image on my T95z plus. The system started, but there is no LAN, no WiFi, no bluetooth. I don't quite understand how to apply patches. Can I have some brief instructions? I'm new to this
