DanOB
  1. I recently noticed my ODroid XU4 was reporting weird temperature readings: cat /sys/class/thermal/thermal_zone0/temp -22000 Is this a software issue or maybe hardware failing? Also, I would like to upgrade, is there another board I could just transfer my EMMC to and be up and running? Thanks
  2. It worked. I am back. Thank you !!!
  3. So, sorry for my ignorance but this still will not work? root@odroidxu4:~# apt update root@odroidxu4:~# apt upgrade root@odroidxu4:~# reboot
  4. So I should be able to update now without any issues?
  5. @Igor All good, I totally understand and appreciate what you do. I assumed with the update removed I would be ok to move forward updating my older backup but I got into a boot loop again. I am back up and running again from my backup so no big deal. I guess I should just standby until things are good on your end to move forward. thanks again, Dan
  6. Today unattended upgrades ran and installed the following: libtasn1-6 linux-dtb-current-odroidxu4 linux-image-current-odroidxu4 linux-u-boot-odroidxu4-current Afterward, the system automatically rebooted and went into a boot loop. I had a backup I was able to copy to the emmc and get back up and running but it is from October 2024 and I am not really sure what to do. coming here to see if anyone else has experienced the same. I tried to run armbianmonitor -U and it had some weird html. I am pretty good with Linux but everything is self taught. thank you in advance for any help Dan
