Dariy
  1. Hi! I'm sorry for the delay. Here you go: interface=wlan0 driver=nl80211 country_code=XX hw_mode=g channel=7 ssid=wifiAP wpa=2 auth_algs=1 wpa_passphrase=12345678 wpa_key_mgmt=WPA-PSK rsn_pairwise=CCMP wpa_pairwise=CCMP wmm_enabled=1
  2. Reporting: with the latest Armbian release from the OPi Zero3 "Armbian_community 24.5.0-trunk.248 Bookworm with Linux 6.6.22-current-sunxi64". The Network Manager is disabled, downloaded ifupdown, hostapd, and isc-dhcp-server (to make the experiment clean). The same configuration. Problem solved! No messages about buggy protocols, just works just fine. Thanks!
  3. @ag123Thanks for your response! I've googled it, and seen those posts (mainly on network routers forums). Unfortunately, did not find a way to debug this, or to fix. I've tried with different devices: 2 windows laptops, 2 android phones. I don't think they would send any goofy packages. Why would they? I don't know how to debug anyway. Thanks for pointing out the proper topic, will post a message there later. I'll try the latest armbian build with linux 6.6+ to check if the problem persists.
  4. Hi! So the problem is when I configure wifi hotspot using hostapd, isc-dhcp-server, and ifupdown, I'm able to start the AP, connect to it, and ping. However, the moment any device connects to the AP the serial console gets spammed with this message around once a second: protocol 0000 is buggy, dev wlan0 This happens on the unofficial Armbian build (from the Armbian OrangePi Zero3 page), DietPi, and the official OrangePi Debian build. The wireless band doesn't matter. Kernel version: 6.1.31-sun50iw9. I tried to set up the AP with NetworkManager, but couldn't manage to connect to it. Probably DHCP issues that I couldn't resolve. I haven't run the AP for a prolonged period, only like 1hour. So I'm not sure if this has any effect on the performance and stability. Could somebody suggest if this is something to worry about or just a harmless warning?
