jeanbat
  1. Hello again... How can I activate the wifi network? I have a nanopi neo plus 2 with wifi, but armbian don't find it. Ifconfig and nmtui don't find the wireless connection. Thank you
  2. I added uarts on the overlays in the file armbianEnv.txt. Now it's enabled I think but not working. My serial device work well with my raspberrys but not here? Maybe I need to manually set the baudrate?how to do that?
  3. Hello, I'm trying to connect a serial device on my nanopi neo plus2, but the gpio uart seems to be disable, please can you help me step by step? I found some things on forums but I understand nothing .... Thank you in advance
  4. Oh, I think I finally found the good armbian... I'm testing right now
  5. Hello, I bought 2 nanopi neo plus 2 and when I search for a compatible armbian, I only found a bullseye here https://fi.mirror.armbian.de/archive/ But I have problems with apt, I need to install some python stuff but I always got errors : Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: libpython3-stdlib python-pip-whl python3 python3-distutils python3-lib2to3 python3-minimal python3-pkg-resources python3-setuptools python3-wheel Suggested packages: python3-doc python3-tk python3-venv python-setuptools-doc Recommended packages: build-essential python3-dev The following NEW packages will be installed: python-pip-whl python3-distutils python3-lib2to3 python3-pip python3-pkg-resources python3-setuptools python3-wheel The following packages will be upgraded: libpython3-stdlib python3 python3-minimal 3 upgraded, 7 newly installed, 0 to remove and 117 not upgraded. Need to get 3,155 kB/3,179 kB of archives. After this operation, 7,208 kB of additional disk space will be used. Do you want to continue? [Y/n] y Err:1 http://deb.debian.org/debian bullseye/main arm64 python3-minimal arm64 3.9.1-1 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:2 http://deb.debian.org/debian bullseye/main arm64 python3 arm64 3.9.1-1 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:3 http://deb.debian.org/debian bullseye/main arm64 libpython3-stdlib arm64 3.9.1-1 404 Not Found [IP: 2a04:4e42:6a::644 80] Ign:4 http://deb.debian.org/debian bullseye/main arm64 python-pip-whl all 20.1.1-2 Ign:5 http://deb.debian.org/debian bullseye/main arm64 python3-lib2to3 all 3.9.1-2 Ign:6 http://deb.debian.org/debian bullseye/main arm64 python3-distutils all 3.9.1-2 Ign:7 http://deb.debian.org/debian bullseye/main arm64 python3-pkg-resources all 51.3.3-1 Ign:8 http://deb.debian.org/debian bullseye/main arm64 python3-setuptools all 51.3.3-1 Ign:9 http://deb.debian.org/debian bullseye/main arm64 python3-pip all 20.1.1-2 Err:4 http://deb.debian.org/debian bullseye/main arm64 python-pip-whl all 20.1.1-2 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:5 http://deb.debian.org/debian bullseye/main arm64 python3-lib2to3 all 3.9.1-2 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:6 http://deb.debian.org/debian bullseye/main arm64 python3-distutils all 3.9.1-2 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:7 http://deb.debian.org/debian bullseye/main arm64 python3-pkg-resources all 51.3.3-1 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:8 http://deb.debian.org/debian bullseye/main arm64 python3-setuptools all 51.3.3-1 404 Not Found [IP: 2a04:4e42:6a::644 80] Err:9 http://deb.debian.org/debian bullseye/main arm64 python3-pip all 20.1.1-2 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python3-defaults/python3-minimal_3.9.1-1_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python3-defaults/python3_3.9.1-1_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python3-defaults/libpython3-stdlib_3.9.1-1_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python-pip/python-pip-whl_20.1.1-2_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python3-stdlib-extensions/python3-lib2to3_3.9.1-2_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python3-stdlib-extensions/python3-distutils_3.9.1-2_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/s/setuptools/python3-pkg-resources_51.3.3-1_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/s/setuptools/python3-setuptools_51.3.3-1_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Failed to fetch http://deb.debian.org/debian/pool/main/p/python-pip/python3-pip_20.1.1-2_all.deb 404 Not Found [IP: 2a04:4e42:6a::644 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? I guess I need to change sources.list? But when I tried to add booworm sources I got the same error? What I need to do exactly? Thank you
