4 -
Thank you, looking more calmly, I found the headers marked as G, R, T. Would these be: ground, tx, rx? I think I'm confusing it with my second TVbox which has a slightly different PCB, if this is the UART interface, I'll solder headers and connect my USB adapter, at what baud rate should I listen? It worked, it was these pads, here is the output with booting from the SD card: DDR Version V1.10 20190926 In ID:0xFFF 660MHz DDR3 Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB mach:2 OUT U-Boot SPL 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Trying to boot from MMC2 I/TC: I/TC: Non-secure external DT found I/TC: Switching console to device: /serial@11030000 I/TC: OP-TEE version: 3.10.0-40-ga1d5c81f (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #6 Wed Sep 16 21:36:15 UTC 2020 arm I/TC: Primary CPU initializing M/TC: Not protecting region 1: 0x68400000-0x68600000 I/TC: Primary CPU switching to normal world boot U-Boot 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Model: Generic Rockchip rk322x TV Box board DRAM: 992 MiB MMC: dwmmc@30000000: 1, dwmmc@30020000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@11030000 Out: serial@11030000 Err: serial@11030000 Model: Generic Rockchip rk322x TV Box board Net: eth0: ethernet@30200000 starting USB... Bus usb@30040000: USB DWC2 Bus usb@30080000: USB EHCI 1.00 Bus usb@300c0000: USB EHCI 1.00 Bus usb@30100000: USB EHCI 1.00 scanning bus usb@30040000 for devices... 1 USB Device(s) found scanning bus usb@30080000 for devices... 1 USB Device(s) found scanning bus usb@300c0000 for devices... 1 USB Device(s) found scanning bus usb@30100000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 2909 bytes read in 5 ms (567.4 KiB/s) ## Executing script at 60000000 Boot script loaded from mmc 1 238 bytes read in 5 ms (45.9 KiB/s) 6094752 bytes read in 282 ms (20.6 MiB/s) 8771448 bytes read in 475 ms (17.6 MiB/s) 50042 bytes read in 10 ms (4.8 MiB/s) 786 bytes read in 7 ms (109.4 KiB/s) Applying kernel provided DT overlay rk322x-emmc.dtbo 1286 bytes read in 7 ms (178.7 KiB/s) Applying kernel provided DT overlay rk322x-led-conf1.dtbo 232 bytes read in 7 ms (32.2 KiB/s) Applying kernel provided DT fixup script (rk322x-fixup.scr) ## Executing script at 600f0000 ## Loading init Ramdisk from Legacy Image at 64000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 6094688 Bytes = 5.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 61f00000 Booting using the fdt blob at 0x61f00000 EHCI failed to shut down host controller. EHCI failed to shut down host controller. Using Device Tree in place at 61f00000, end 61f74fff Starting kernel ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot I/TC: Secondary CPU 2 initializing I/TC: Secondary CPU 2 switching to normal world boot I/TC: Secondary CPU 3 initializing I/TC: Secondary CPU 3 switching to normal world boot Armbian 24.2.1 bookworm ttyS2 rk322x-box login: this is the emmc boot output running the same image from the sd card written on it: ⸮⸮DDR Version V1.10 20190926 In ID:0xFFF 660MHz DDR3 Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB mach:2 OUT U-Boot SPL 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Trying to boot from MMC2 I/TC: I/TC: Non-secure external DT found I/TC: Switching console to device: /serial@11030000 I/TC: OP-TEE version: 3.10.0-40-ga1d5c81f (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #6 Wed Sep 16 21:36:15 UTC 2020 arm I/TC: Primary CPU initializing M/TC: Not protecting region 1: 0x68400000-0x68600000 I/TC: Primary CPU switching to normal world boot U-Boot 2021.04-armbian (May 06 2021 - 19:15:25 +0000) Model: Generic Rockchip rk322x TV Box board DRAM: 992 MiB MMC: dwmmc@30000000: 1, dwmmc@30020000: 0 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@11030000 Out: serial@11030000 Err: serial@11030000 Model: Generic Rockchip rk322x TV Box board Net: eth0: ethernet@30200000 starting USB... Bus usb@30040000: USB DWC2 Bus usb@30080000: USB EHCI 1.00 Bus usb@300c0000: USB EHCI 1.00 Bus usb@30100000: USB EHCI 1.00 scanning bus usb@30040000 for devices... 1 USB Device(s) found scanning bus usb@30080000 for devices... 1 USB Device(s) found scanning bus usb@300c0000 for devices... 1 USB Device(s) found scanning bus usb@30100000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 Card did not respond to voltage select! : -110 Device 0: unknown device switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... libfdt fdt_check_header(): FDT_ERR_BADMAGIC 7[r[999;999H[6n8Card did not respond to voltage select! : -110 Scanning disk dwmmc@30000000.blk... Disk dwmmc@30000000.blk not ready Scanning disk dwmmc@30020000.blk... Found 2 disks No EFI system partition BootOrder not defined EFI boot manager: Cannot load any image ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-8e-44-db-3b-e1-5d ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/0 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rk322x-rk322x-box ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rk322x ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 missing environment variable: bootfile Retrieving file: pxelinux.cfg/default ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 Config file not found ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 ethernet@30200000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@30200000 =>
unfortunately I don't have access to the serial UART of the TV box, I didn't find any pad with the tx rx labels on the PCB, I'm going to try to replace the rootfs, in the functional Armbian image, with the exception of the boot directory, then write it using multitool , I'll post here if this works. Thank you very much for the tips and quick responses
Hi, thanks for the answer, you're right, I should have done that, but in theory, it should work to copy a bootable image from the sd card to the emmc, right? Where should I start looking to find out why it won't boot? I don't have a lot of experience on the subject, do you think I should do a clean installation on emmc using multitool? I would really like not to lose the settings and apps from my current system, would copying the rootfs to the new installation work?
Hi, I've been using Armbian on TVBox RK322x for some time. Basically a test that went wrong broke my system and I was forced to reinstall Armbian and all the programs I had before. To prevent something similar from happening again, I thought about saving the image to the SD card, configuring everything, installing all the programs and finally, creating a backup image of the SD card and writing Armbian to the internal EMMC. However, when I tried to write the system in the internal emmc, only the option to write the bootloader in sd/emmc appeared, thinking it was something related to the legacy kernel I was using, I upgraded to the mainline, and even then the option to write the system to emmc didn't show up. The legacy kernel is essential because I need the onboard wifi drivers, the plan was to upgrade the kernel, write to emmc, and then downgrade the kernel. The armbian that is running from the sd card was a debian buster version with a legacy kernel, so I froze the firmware and kernel, and upgraded to bookworm by changing the apt repositories and performing a full upgrade. My question is: from this bootable system via sd card, how can I install it on the internal emmc? I have already tried writing the sd card image to emmc using multitool but the box does not boot.
