9 -
Hi Javelin, below are some of the tests I completed yesterday, but I could not capture the logs. It seems that this was working on the (very) old armbian version Armbian_24.8.1_Odroidhc4_bookworm_current_6.6.47.img · No changes - starts, soft reboot is not working – voltage issue · <0x44 0x06 0x03> - starts, soft reboot is not working – voltage issue · <0x44 0x06 0x06> - does not boot Armbian_23.8.1_Odroidhc4_bookworm_current_6.1.50_minimal.img · No changes - starts, soft reboot is not working – voltage issue · <0x43 0x06 0x03> - starts, soft reboot is not working – voltage issue · <0x43 0x06 0x06> - does not boot Note, that the first value differs (by default) comparing to the latest version. Armbian_23.02.2_Odroidhc4_bullseye_current_6.1.11_minimal.img · No changes - starts, soft reboot is not working - black screen · <0x42 0x06 0x03> - starts, soft reboot is not working - kernel panic · <0x42 0x06 0x06> - does not boot Note, that the first value differs (by default) comparing to the latest version. Armbian_22.08.7_Odroidhc4_bullseye_current_5.19.17_minimal.img · No changes – starts, soft reboot is not working - blank screen Armbian_21.02.4_Odroidhc4_buster_current_5.10.27.img · No changes – starts, reboots w/o issues
Well, I have the opposite experience. I was happily running Odroid HC4 with Transcend Premium 400X 16GB class 10 HC-I SDHC card for a few years w/o worrying about the reboot issue until I decided to change the SD card, as the old one started slowing down. I have tried Sandisk Ultra XC 64GB A1, as well as Transcend 16GB SDHC Ultimate 600x, but they both have issues with soft reboot. I have also tried cloning Armbian from the old card to one of the new cards, but I was still facing issues with the new card. I have also tried doing a fresh install on the old card, and then I was not facing issues, so apparently this is related to SD card compatibility. I have connected a monitor to capture the logs after I hit reboot, and this is what I get: I hope someone will have a working solution for this, as all the advices I have found so far on this forum are not helping, and it seems that my HDD started having issues after the forceful shut-downs. 😕
I am rebuilding my armbian+OMV on Odroid HC4 and now I am facing the issue with the hot reboot as well. I am on Armbian v24.8.4 running Armbian Linux 6.6.47-current-meson64 using Sandisk Ultra 64GB A1 class 10 XC-I. Can you advise, what value I should use in meson-sm1-odroid-hc4.dts? gpio-regulator-tf_io { compatible = "regulator-gpio"; regulator-name = "TF_IO"; regulator-min-microvolt = <0x1b7740>; regulator-max-microvolt = <0x325aa0>; vin-supply = <0x0e>; enable-gpios = <0x44 0x0e 0x06>; enable-active-high; regulator-always-on; gpios = <0x44 0x06 0x02>; gpios-states = <0x00>; states = <0x325aa0 0x00 0x1b7740 0x01>; phandle = <0x29>; }; I am attaching the full file for the reference as well. By the way, I am not facing this issue with my older SD card Transcend Premium 400X 16GB class 10 HC-I (6.6.47-current-meson64). meson-sm1-odroid-hc4.dts
