Hello @jock, hope you're ok!
Seven months ago, I successfully installed Armbian (Armbian_community_24.5.0-trunk.563_Rk322x-box_bookworm_current_6.6.30_minimal) and RetroPie on my RK3229 TV box (MXQ-4K-5G) using an 8 GB USB drive. Following the instructions from this forum, the entire compilation process took me approximately 15 hours. I saved everything as an IMG file using Win32DiskManager.
NOTE : I’m aware that the internal Wi-Fi module (SV6256P, which is my internal wifi module) doesn’t work with this setup, but I know that the Armbian Legacy version with kernel 4.4.194 offers an option in rk322x-config to enable this module.
Since then, I’ve created multiple 8 GB images with this configuration.
This time, I decided to make a different procedure: Install from scratch an updated Armbian bookworm, then sudo apt install LXDE in order to GUI-access and copy my files from Retropie (via sh script) without needing to remove the SD card and insert it into a separate Linux OS. I used the latest available community image, Armbian_community_25.2.0-trunk.86_Rk322x-box_bookworm_current_6.6.63_minimal.img.xz, and successfully installed LXDE without any issues.
However, after installing RetroPie, the menu runs very slow. Somehow, I sense GPU Video driver is not responding or somehow LXDE messed up video drivers.
What do you think might be causing this? Perhaps there is a process running in background, and therefore making things going slow
I know a screenshot could explain better, but i'm not at home at this moment.
Hope you can help me on this.
Regards
D
