jerrytincanz
  1. Hi i also have this problem, im running on an Orange Pi One, it uses armv7, could not install these. Im trying to format my external drive into zfs, im running Armbian_24.2.1_Orangepione_bookworm_current_6.6.16.img. Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: zfsutils-linux : Depends: libnvpair3linux (= 2.2.3-2) but it is not going to be installed Depends: libzfs4linux (= 2.2.3-2) but it is not going to be installed Depends: libzpool5linux (= 2.2.3-2) but it is not going to be installed Depends: libssl3t64 (>= 3.0.0) but it is not installable E: Unable to correct problems, you have held broken packages. Trying to install the armhf give me it wants an updates libc6: dpkg: dependency problems prevent configuration of libzpool5linux: libzpool5linux depends on libc6 (>= 2.38); however: Version of libc6:armhf on system is 2.36-9+deb12u7.
