Tomogo
14 -
Armbian doesnt seem to see sata harddrives.
Tomogo replied to DontMindMe's topic in Radxa Rock 5 ITX
Hi, I've tried it and it works great! Many thanks! But my eyes almost didn't see it. I had to use my glasses and magnifying glass together 😉 -
Hi, has anybody info if the new official kerenl 6.1.84-vendor-rk35xx works fine with SATA disks? Thanks... -
OK, so if anybody want working kernel it can be downloaded on my web pages: https://files.tomogo.cz/rock/linux.tar.gz -
I don't know if this can help, but here are differences between not working and working kernel config config-6.1.75-vendor-rk35xx: config-6.1.75-vendor-rk35xx.diff.txt -
I had the same. -
Hi, I have still problems also with rolling release so I'm using one older kernel with vmlinuz-6.1.75-vendor-rk35xx. -
Hi Igor. Many thanks, I've did it by beta.armbian.com and SATA disk was present in all of three reboots! -
Hi all, only info: After connecting 4 SATA disks it is almost impossible to start SBC to see disks. Linux rock-5-itx 6.1.75-vendor-rk35xx #1 SMP Wed Aug 21 11:45:59 UTC 2024 aarch64 GNU/Linux VERSION=24.8.2 REVISION=24.8.2 -
Hi, I have the same issue with 3 SATA drivers, sometimes it doesn't see any of SATA disks, sometimes it does. Kernel 6.1.75-vendor-rk35xx. I've tried several 12 V power suply, no effect. So I've tried ATX suply also no effect. Still same issue. Board with 24 GB RAM. -
Hi, it is strange, I'm in Czech republic on Vodafone network. It really doesn't work. So I have tried to connect over my mobile phone and now it work fine. Can be some problem with routing on my provider? apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://security.debian.org bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Ign:5 http://imola.armbian.com/apt bookworm InRelease Err:5 http://imola.armbian.com/apt bookworm InRelease Could not connect to imola.armbian.com:80 (93.103.15.56), connection timed out Reading package lists... Done Building dependency tree... Done Reading state information... Done 11 packages can be upgraded. Run 'apt list --upgradable' to see them. W: Failed to fetch http://apt.armbian.com/dists/bookworm/InRelease Could not connect to imola.armbian.com:80 (93.103.15.56), connection timed out W: Some index files failed to download. They have been ignored, or old ones used instead.
All Armbians with Kernel 6.8.x woun't start on Radaxa Rock 5b
Tomogo replied to Tomogo's topic in Radxa Rock 5B
Hi, I hate you (sorry just joke) 🙂 I have no UART to USB cable so I found old Teensy 3.2 board. Made program for Serial to USB bridge. Updated SPI flash with new firmware with debug mode. And.... It works now! Dam or huray... 😉 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=4096MB Manufacturer ID:0x6 CH0 RX Vref:27.5%, TX Vref:25.8%,25.8% CH1 RX Vref:25.8%, TX Vref:25.8%,25.8% CH2 RX Vref:27.9%, TX Vref:24.8%,24.8% CH3 RX Vref:27.1%, TX Vref:24.8%,24.8% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28) Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MTD2 Trying fit image at 0x4000 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK ## Checking uboot 0x00200000 ... sha256(25a398ffe0...) + OK ## Checking fdt 0x0031e9f8 ... sha256(5bee414074...) + OK ## Checking atf-2 0xff100000 ... sha256(4b2065349b...) + OK ## Checking atf-3 0x000f0000 ... sha256(aa71013e72...) + OK Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000) Total: 489.724/719.766 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45 NOTICE: BL31: Built : 10:11:21, Dec 27 2023 INFO: spec: 0x1 INFO: code: 0x88 INFO: ext 32k is not valid INFO: ddr: stride-en 4CH INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0 INFO: l3 cache partition cfg-0 INFO: system boots from cpu-hwid-0 INFO: disable memory repair INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001 INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz INFO: BL31: Initialising Exception Handling Framework INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2017.09-gd1cf49135ee-220414-dirty #stephen (May 23 2024 - 19:39:28 +0800) Model: Radxa ROCK 5B MPIDR: 0x81000000 PreSerial: 2, raw, 0xfeb50000 DRAM: 16 GiB Sysmem: init Relocation Offset: eda3f000 Relocation fdt: eb9f96c0 - eb9fecc8 CR: M/C/I Using default environment DM: v2 mmc@fe2c0000: 1, mmc@fe2e0000: 0 Bootdev(assign): mmc 0 MMC0: HS400 Enhanced Strobe, 200Mhz PartType: EFI No misc partition boot mode: None FIT: No boot partition Failed to load DTB, ret=-2 No valid DTB, ret=-22 Failed to get kernel dtb, ret=-22 Model: Radxa ROCK 5B MPIDR: 0x81000000 CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A) b0pll 24000 KHz b1pll 24000 KHz lpll 24000 KHz v0pll 24000 KHz aupll 24000 KHz cpll 1500000 KHz gpll 1188000 KHz npll 24000 KHz ppll 1100000 KHz aclk_center_root 702000 KHz pclk_center_root 100000 KHz hclk_center_root 396000 KHz aclk_center_low_root 500000 KHz aclk_top_root 750000 KHz pclk_top_root 100000 KHz aclk_low_top_root 396000 KHz Net: No ethernet found. Hit key to stop autoboot('CTRL+C'): 0 starting USB... No working controllers found USB is stopped. Please issue 'usb start' first. MMC: no card present mmc_init: -123, time 0 pcie@fe150000: PCIe Linking... LTSSM is 0x0 pcie@fe150000: PCIe Linking... LTSSM is 0x0 pcie@fe150000: PCIe Linking... LTSSM is 0x6 pcie@fe150000: PCIe Linking... LTSSM is 0x210023 pcie@fe150000: PCIe Link up, LTSSM is 0x230011 pcie@fe150000: PCIE-0: Link up (Gen3-x2, Bus0) pcie@fe150000: invalid flags type! Device 0: unknown device Device 1: unknown device switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3920 bytes read in 8 ms (478.5 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0:1 172 bytes read in 8 ms (20.5 KiB/s) 26373283 bytes read in 112 ms (224.6 MiB/s) 32436736 bytes read in 142 ms (217.8 MiB/s) 163397 bytes read in 28 ms (5.6 MiB/s) Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Fdt Ramdisk skip relocation No misc partition ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 26373219 Bytes = 25.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0x08300000 Booting using the fdt blob at 0x08300000 reserving fdt memory region: addr=8300000 size=8e000 Using Device Tree in place at 0000000008300000, end 0000000008390fff can't found rockchip,drm-logo, use rockchip,fb-logo WARNING: could not set reg FDT_ERR_BADOFFSET. failed to reserve fb-loader-logo memory WARNING: could not set reg FDT_ERR_BADOFFSET. Adding bank: 0x00200000 - 0xf0000000 (size: 0xefe00000) Adding bank: 0x100000000 - 0x3fc000000 (size: 0x2fc000000) Adding bank: 0x3fc500000 - 0x3fff00000 (size: 0x03a00000) Adding bank: 0x4f0000000 - 0x500000000 (size: 0x10000000) Total: 2321.467/3095.859 ms Starting kernel ... -
Hi, I do not konow, it this is the right place to raise this ticket. But in stable releases of Armbian it works fine, but there is no video acceleration. I have tried Kodi on Armbian Noble Gnome + trunk MESA/VPU: Armbian_24.8.0-trunk.85_Rock-5b_noble_vendor_6.1.43_gnome-oibaf_desktop.img Kodi falling when I'm trying to install some of extensions. For example https://repo.sc2.zone/ Crash log in the attachment. System log: 2024-06-05T12:01:28.534687+02:00 rock-5b kodi.desktop[3739]: Fatal Python error: PyImport_AppendInittab: PyImport_AppendInittab() may not be called after Py_Initialize() 2024-06-05T12:01:28.535024+02:00 rock-5b kodi.desktop[3739]: Python runtime state: initialized 2024-06-05T12:01:28.535112+02:00 rock-5b kodi.desktop[3739]: Thread 0x0000ffff3afde0c0 (most recent call first): 2024-06-05T12:01:28.535191+02:00 rock-5b kodi.desktop[3739]: <no Python frame> 2024-06-05T12:01:28.612980+02:00 rock-5b kodi.desktop[3732]: Aborted 2024-06-05T12:01:28.640388+02:00 rock-5b kodi.desktop[3732]: Crash report available at /home/tomogo/kodi_crashlog-20240605_120128.log kodi_crashlog-20240605_115433.log
Hi, I've installed Armbian_24.5.1_Rock-5b_bookworm_vendor_6.1.43_cinnamon_desktop.img on my Rock 5b and when I have tried to do apt update get error message with armbian.com url. (timeout error) I did all necessary and now it work fine. But for dev info, there is some problem probably with all Stable images.
Tomogo posted a topic in Radxa Rock 5B
Hi, I have tried Rock 5b images with Kernel 6.8.10. Any of image I've tested will not start. No LED flashing, no HDMI signal.. nothing. The others with Kernel 6.1.43 starts fine.
