P.S. Below is the initial output that I got on the serial port, before it asked me to reset the root password:
$ sudo bt -b 1500000
No port specified, using ttyUSB0 (last registered). Use -l to list ports.
Trying port ttyUSB0... Connected to ttyUSB0 at 1500000 bps.
Escape character is 'Ctrl-]'. Use escape followed by '?' for help.
DDR 9fffbe1e78 cym 24/02/04-10:09:20,fwver: v1.16
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0x1
CH0 RX Vref:28.3%, TX Vref:22.8%,21.8%
CH1 RX Vref:26.3%, TX Vref:19.8%,19.8%
CH2 RX Vref:26.7%, TX Vref:19.8%,19.8%
CH3 RX Vref:27.5%, TX Vref:20.8%,20.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-g1b1171b7c71-220418 #fa (Apr 18 2024 - 11:12:44)
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
No misc partition
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(a7d1d8d191...) + OK
## Checking u-boot 0x00a00000 ... sha256(235390ebc4...) + OK
## Checking fdt-1 0x00aa7e10 ... sha256(d25019e2ea...) + OK
## Checking atf-2 0x000f0000 ... sha256(aa71013e72...) + OK
## Checking atf-3 0xff100000 ... sha256(4b2065349b...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 368.979/520.85 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-682-g4ca8a8422:derrick.huang, fwver: v1.45
NOTICE: BL31: Built : 10:11:21, Dec 27 2023
INFO: spec: 0x13
INFO: code: 0x88
INFO: ext 32k is valid
INFO: ddr: stride-en 4CH
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: l3 cache partition cfg-0
INFO: system boots from cpu-hwid-0
INFO: disable memory repair
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
U-Boot 2024.07-rc4-armbian (Jun 17 2024 - 14:10:22 +0000)
Model: Generic RK3588S/RK3588
DRAM: 8 GiB
Core: 291 devices, 25 uclasses, devicetree: separate
MMC: mmc@fe2c0000: 1, mmc@fe2e0000: 0
Loading Environment from nowhere... OK
In: serial@feb50000
Out: serial@feb50000
Err: serial@feb50000
Hit any key to stop autoboot: 0
Scanning for bootflows in all bootdevs
Seq Method State Uclass Part Name Filename
Scanning global bootmeth 'efi_mgr':
No EFI system partition
Failed to persist EFI variables
0 efi_mgr ready (none) 0 <NULL>
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 1' failed
Loading Boot0001 'mmc 0' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
Scanning bootdev 'mmc@fe2c0000.bootdev':
1 script ready mmc 1 mmc@fe2c0000.bootdev.part /boot/boot.scr
** Booting bootflow 'mmc@fe2c0000.bootdev.part_1' with script
Boot script loaded from mmc 1:1
225 bytes read in 4 ms (54.7 KiB/s)
28236660 bytes read in 2365 ms (11.4 MiB/s)
32883200 bytes read in 2752 ms (11.4 MiB/s)
148215 bytes read in 22 ms (6.4 MiB/s)
Working FDT set to 12000000
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
## Loading init Ramdisk from Legacy Image at 12180000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 28236596 Bytes = 26.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Ramdisk to eb3d9000, end ecec6b34 ... OK
Loading Device Tree to 00000000eb34c000, end 00000000eb3d8fff ... OK
Working FDT set to eb34c000
Starting kernel ...
Loading, please wait...
Starting systemd-udevd version 252.22-1~deb12u1
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... [FAILED] Failed to start ssh.servic…[0m - OpenBSD Secure Shell server.
Armbian-unofficial 24.8.0-trunk Bookworm ttyS2
nanopi-r6c login:
