GSAR
  1. Hello, aswering for you guys. @fabiobassa I'm unsure if the power surge damaged the USB subsystem. Is there any way to determine or repair it? @jock Sorry, but will this type of male-to-male USB cable in the image below work? It's what I have. I've attempted to boot using Armbian from the SD card, but it continues to display only a black screen and doesn't boot.
  2. Hello again! First of all Thank you for responding me. I followed your advice, but my TV BOX isn't responding when I press the reset button (located on the AV port). It seems like the RK3228A isn't recognizing any type of USB device, including the Male to Male USB cable. I've tried keyboards and mouses, but none of them are working at all. Apologies for bothering you again!
  3. Model: RK3228A. Hello, I'm having some problems while trying to burn an image onto my TV BOX. During the burning process (around 50% completion), the TV BOX shut down due to a power surge in my neighborhood. Now, when I try to use the Multitool, my keyboard doesn't work anymore. It lights up for a millisecond and then turns off. I have tried the following: Installed drivers during the Linux boot process by adding commands to the boot scripts, but I cannot change them due to permissions on the SD card. Reburned the SD card with the Multitool image, but it still doesn't work (I also tried different SD cards). Booted with an ISO to wipe data from memory and start again, but that didn't work either. Used another keyboard. Reset my TV BOX. Does anyone have any ideas to help me, please?
