Hello, I updated recently my nanopi neo3 and I am unable to get it to boot. The log from uart is attached below. Is there any idea/log I could report to fix the issue?
Thank you and kind regards,
Juan.
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB0, 00:10:32
Press CTRL-A Z for help on special keys
DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 248
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=60906MB
FwPartOffset=2000 , 0
StorageInit ok = 32496
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x337a9f0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xaea08
RunBL31 0x40000
INFO: Preloader serial: 2
NOTICE: BL31: v1.3(debug):403e0b816
NOTICE: BL31: Built : 14:13:08, Aug 11 2020
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2022.04-armbian (May 27 2023 - 19:32:11 +0000)
Model: FriendlyElec NanoPi R2S
DRAM: 2 GiB
PMIC: RK8050 (on=0x40, off=0x00)
Core: 223 devices, 20 uclasses, devicetree: separate
MMC: mmc@ff500000: 1
Loading Environment from MMC... MMC Device 0 not found
*** Warning - No MMC card found, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
Net: eth0: ethernet@ff540000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
3252 bytes read in 5 ms (634.8 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
227 bytes read in 3 ms (73.2 KiB/s)
16255321 bytes read in 709 ms (21.9 MiB/s)
30030336 bytes read in 1305 ms (21.9 MiB/s)
65884 bytes read in 15 ms (4.2 MiB/s)
2825 bytes read in 8 ms (344.7 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Unknown command 'kaslrseed' - try 'help'
Moving Image from 0x2080000 to 0x2200000, end=3f40000
## Loading init Ramdisk from Legacy Image at 06000000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 16255257 Bytes = 15.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to 7cfa7000, end 7df27919 ... OK
Loading Device Tree to 000000007cf2e000, end 000000007cfa6fff ... OK
Starting kernel ...
Loading, please wait...
Starting systemd-udevd version 252.26-1~deb12u2
Timed out for waiting the udev queue being empty.
