BobX
  1. I did remove 10-dhcp-all-interfaces.yaml when I created the 20-static-ip.yaml. I have just download [Armbian_community_24.8.0-trunk.495] again and this has done the trick. The first download must have been corrupted or bad image copy. I now have pihole up and running. Thanks for the help. Regards BobX
  2. Model Orange pi zero v1.4 OS Armbian_community_24.8.0-trunk.495_Orangepizero_bookworm_current_ 6.6.36_minimal Original IP 192.168.12.115 Having trouble trying to setup Static IP I used the followed example on https://docs.armbian.com/User-Guide_Networking/#minimal-images-networkd /etc/netplan/20-static-ip.yaml it setup OK network: version: 2 renderer: networkd ethernets: end0: # Change this to your ethernet interface addresses: - 192.168.12.65/24 routes: - to: default via: 192.168.12.1 nameservers: addresses: - 1.1.1.1 - 1.0.0.1 sudo chmod 600 /etc/netplan/*.yaml sudo netplan try sudo netplan apply sudo reboot however when I rebooted it revert to the original 192.168.12.115. On check with ip addr
