Hi @gop3k I've been having the same issues on the Orange Pi 3 LTS. Video is really choppy and unwatchable, and I can't figure out why.
I know it's possible to play video smoothly on this board because I can do so with the Android OS that came on the device. I actually reinstalled Android on an sd card (you have to use Allwinner's proprietary sd flashing tool) so I could actually use it for Kodi in the short term. But ideally I'd like to get Armbian working.
I'm using a recent Armbian build for the Orange Pi 3 LTS: Armbian_community_24.8.0-trunk.495_Orangepi3-lts_noble_current_6.6.36_gnome_desktop
I have done some research, which I'll outline below. I'm certain some of my understanding must be wrong, so take that for what it's worth. If someone is willing to correct me I'm happy to be corrected.
I think that the gpu is not working properly in the most recent builds. I found that in older builds using Allwinner H6 chips that some people had to manually enable the GPU, but it looks like it is enabled but not working properly.
The Allwinner H6 has a Mali-T720 MP2 GPU and Panfrost is the open source driver for it. I used the commands from here to make sure Panfrost is installed, enabled, and working. Which all seemed to be true in this build. But when I run glmark2 I get a score of around 85-100. Based on research this seems to be half of what the Allwinner H6 is capable of.
Running armbian-config I see the option to enable hardware features, and as far as I know, this shows the different overlays you can enable in the device tree to tell the kernel about your hardware. These overlays are located in /boot/dts/allwinner/overlay/.
A problem with the overlays is that many of them seem to be for the Allwinner H616 cpu. Which I know is just an updated version of the H6, but I'm wondering if that's causing problems.
There is an option to enable the H616 gpu, which I turned on, then restarted. I still got the same 85-100 range of scores in glmark2.
Could it be that Armbian is trying to use settings for the H616 instead of the H6 and that could be causing problems?
I tried doing a custom build myself, which failed so I'll need to look into that if I want to try it again. But for now I'm going to try using an older automated build to see if that makes any difference. I'll respond again if I have anything to report.
