Today I imaged 'Armbian_24.8.0-trunk.542_Rpi4b_noble_current_6.6.44_gnome_desktop.img' on to an SD card and then put it in my Raspberry Pi 4 GB. It booted up first time no issues and I went through the setup flow. I am using wired ethernet and was able to reach it remotely immediately.
I installed all the updates. When I do "sudo shutdown -h -r now" on the command line (either via SSH or locally in the terminal) it does not reboot. The device stops responding to pings and no longer has HDMI output. If I power cycle the board once, it does not boot up. On the second power cycle it boots up. This seems really odd. Is this some known issue with the raspberry pi 4 ?
