hayat Sınav
  1. I was able to solve the problems. I couldn't format MMC from disk management, it kept giving errors. I went in with the MMC install option from armbian-install and formatted it, then canceled it before starting the installation. I formatted the mmc in ext4 format from disk management and started it. Then I installed it to mmc again with armbian install. I am currently using it by booting from mmc. After installing mmc, when I copied the wifi files to the brcm folder, wifi worked too. It's working fine now and I'm installing the klipper. thank you very much for everything
  2. I can't attend right now because I'm at work. I'll try your suggestions. I am adding photos. Actually, Vontar and Transpeed boxes are exactly the same, only the outer shell and names are different.
  3. Thank you. The problem was caused by my SD card. Gnome and xfce desktops work fine now. I have two different problems right now. First of all, while the system is running on the SD card, I change the name of the .bin file and copy it to the brcm folder with root permission. Even though I turn it off and on again, it doesn't see wifi. Do I need to add Armbian before compiling? My second problem is that the device does not boot when I install it on a 64GB mmc. I need support with MMC. Sorry for my bad english.
  4. John S. I have the vontar model identical to the box. The only difference is John S. Your box is v10, mine is v11. So far I've only been able to launch miniarc. I can't boot the Armbian images Nick gave me, it stays on a black screen. Does anyone have any ideas about this?
