I'm trying to setup a GPS-based time server on an Orange PI Zero 3, running Armbian 24.8.0-trunk.495, kernel 6.6.43-current-sunxi64.
I have the exact same hardware setup working fine on a RaspberryPI 4b, running RPI OS / Debian 11 (bullseye) , kernel 6.1.21-v8+ #1642.
On the RPI4, gpsd recognises the (cheap chinese "M8N") GPS module as u-blox and keeps working in a stable way
root@rpi4:~# gpsctl /dev/ttyS0
/dev/ttyS0 identified as a u-blox SW ROM CORE 3.01 (107888),HW 00080000 at 9600 baud.
the /boot/config.txt has these two lines for the UART config
enable_uart=1
init_uart_baud=9600
On the OPIZ3 I configured /boot/armbianEnv.txt for UART5; I didn't find any setting for the initial UART speed
overlays=uart5-ph
The resulting /dev/ttyS1 is mostly working but not really well.
"gpsd --nowait --debug 1 --speed 9600 /dev/ttyS1" works, but it (usually) does not recognise the module as u-blox, and remains on the NMEA text protocol, meaning I can't use ubxtool.
And it logs a constant stream of "bad checksum" and other errors, and disconnect/reconnect cycles, which aren't nice for the clock stability.
root@orangepizero3-01:~# gpsctl /dev/ttyS1
/dev/ttyS1 identified as a NMEA0183 at 9600 baud.
root@orangepizero3-01:~# journalctl -u gpsd
Aug 12 18:57:49 orangepizero3-01.home gpsd[5223]: gpsd:WARN: bad checksum in NMEA packet; expected 23.
Aug 12 18:57:49 orangepizero3-01.home gpsd[5223]: gpsd:WARN: NMEA0183: malformed GPGSV - fieldcount 19 % 4 != 0
Aug 12 18:57:53 orangepizero3-01.home gpsd[5223]: gpsd:WARN: bad checksum in NMEA packet; expected 2C.
Aug 12 18:57:53 orangepizero3-01.home gpsd[5223]: gpsd:WARN: device read of /dev/ttyS1 returned error or packet sniffer failed sync (flags {ERROR})
Aug 12 18:57:53 orangepizero3-01.home gpsd_hook[10889]: start args: /dev/ttyS1 DEACTIVATE
Aug 12 18:57:53 orangepizero3-01.home gpsd_hook[10893]: start args: /dev/ttyS1 ACTIVATE
Aug 12 18:57:54 orangepizero3-01.home gpsd[5223]: gpsd:WARN: bad checksum in NMEA packet; expected 3C.
Once in a while, seemingly randomly, restarting gpsd seems "lucky" and it does recognise the module as u-blox and for a while it's a bit more stable, using the binary UBX protocol, to fail again after some hours.
So, I'm wondering if it's an issue with the OPIZ3 GPIO/UART, or with the Armbian kernel, or what.
Has anybody seen the same or similar issue?
Or if you have some suggestion on how to debug this (if possible without an oscilloscope), it would be much welcome.
Cheers, Sergio
