Same problem, at first I used DietPi OS but I got another error, no hardware recognition.
I tried Radxa OS for Radxa Zero 3W but the CLI version is apparently buggy...
And I finally arrived at the same point as you, same problem with the same configuration...
# Setup the WiFi and SSH before flashing
mkdir -p armbian_mount/boot armbian_mount/root
sudo losetup -Pf Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img
losetup -a
sudo mount /dev/loop12p1 armbian_mount/boot
sudo mount /dev/loop12p2 armbian_mount/root
sudo touch armbian_mount/boot/ssh
sudo nano armbian_mount/root/etc/netplan/10-dhcp-all-interfaces.yaml
network:
version: 2
renderer: networkd
ethernets:
eth0:
dhcp4: true
optional: true
wifis:
wlan0:
dhcp4: true
optional: true
access-points:
"YOUR_WIFI_SSID":
password: "YOUR_WIFI_PASSWORD"
sudo umount armbian_mount/boot
sudo umount armbian_mount/root
sudo losetup -d /dev/loop12
# This is my cmd (with Arch Linux) for flashing the OS on the eMMC
sudo rkdeveloptool ld
sudo rkdeveloptool db rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly.bin
sudo rkdeveloptool ef
sudo rkdeveloptool wl 0 Armbian_24.5.3_Radxa-zero3_bookworm_vendor_6.1.43_minimal.img
sudo rkdeveloptool rd
# Wait 5s and connect to your Radxa with SSH
ssh root@YOUR_IP
sudo apt-get upgrade && sudo apt-get update
sudo apt-get install gstreamer1.0-tools gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
sudo apt-get install v4l-utils
armbian-add-overlay radxa-zero3-rpi-camera-v2.dts
sudo reboot
# More info cmd/bug:
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/test.jpg
root@radxa-zero3:~# gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=/home/test.jpg
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
../libs/gst/base/gstbasesrc.c(3132): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.003362617
Setting pipeline to NULL ...
Freeing pipeline ...
root@radxa-zero3:/home# gst-launch-1.0 v4l2src device=/dev/video0 ! fakesink
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
../sys/v4l2/gstv4l2src.c(976): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Buffer pool activation failed
Execution ended after 0:00:00.009337640
root@radxa-zero3:/home# dmesg | grep video
videodev: Linux video capture interface: v2.00
mpp_service mpp-srv: 6849c1e28b7b author: Ding Wei 2023-12-28 video: rockchip: mpp: px30: fix issue combo_init when device probe
usbcore: registered new interface driver uvcvideo
rockchip-dmc dmc: video_4k_rate = 780000000
rockchip-dmc dmc: video_4k_10b_rate = 780000000
WARNING: CPU: 3 PID: 1673 at drivers/media/common/videobuf2/videobuf2-core.c:835 vb2_core_reqbufs+0x310/0x408
__video_do_ioctl+0x260/0x37c
video_usercopy+0x2b8/0x5e4
video_ioctl2+0x20/0x30
root@radxa-zero3:/home# dmesg | grep v4l2
rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
CPU: 3 PID: 1673 Comm: v4l2-ctl Not tainted 6.1.43-vendor-rk35xx #1
v4l2_ioctl+0x50/0x78
root@radxa-zero3:/home# GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video0 ! fakesink
0:00:00.214107090 4321 0xaaaae4668400 WARN v4l2 gstv4l2object.c:4675:gst_v4l2_object_probe_caps:<v4l2src0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
0:00:00.216999881 4321 0xaaaae4668400 WARN v4l2 gstv4l2object.c:4485:gst_v4l2_object_get_crop_rect:<v4l2src0:src> Failed to get default crop rectangle with VIDIOC_G_SELECTION: Invalid argument
0:00:00.217261509 4321 0xaaaae4668400 WARN v4l2 gstv4l2object.c:3228:gst_v4l2_object_reset_compose_region:<v4l2src0:src> Failed to get default compose rectangle with VIDIOC_G_SELECTION: Invalid argument
0:00:00.222463456 4321 0xaaaae4668400 WARN v4l2bufferpool gstv4l2bufferpool.c:848:gst_v4l2_buffer_pool_start:<v4l2src0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.224169730 4321 0xaaaae4668400 ERROR v4l2bufferpool gstv4l2bufferpool.c:712:gst_v4l2_buffer_pool_streamon:<v4l2src0:pool0:src> error with STREAMON 19 (No such device)
0:00:00.224277065 4321 0xaaaae4668400 ERROR bufferpool gstbufferpool.c:572:gst_buffer_pool_set_active:<v4l2src0:pool0:src> start failed
0:00:00.224536068 4321 0xaaaae4668400 WARN v4l2src gstv4l2src.c:976:gst_v4l2src_decide_allocation:<v4l2src0> error: Failed to allocate required memory.
0:00:00.224573694 4321 0xaaaae4668400 WARN v4l2src gstv4l2src.c:976:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed
0:00:00.225619333 4321 0xaaaae4668400 WARN basesrc gstbasesrc.c:3352:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation
0:00:00.225778585 4321 0xaaaae4668400 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
0:00:00.225824378 4321 0xaaaae4668400 WARN basesrc gstbasesrc.c:3132:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.012100543
