soldato
  1. disabling swap it is fine now. i compiled wheels and installed octoprint in 10 minutes more or less.....
  2. hi all, i installed a new build Armbian_community_24.8.0-trunk.596_Orangepizero_noble_current_6.6.44.img.xz into a new SD card i upgraded the OS and all was fine. but during the Octoprint install this phase freezed: Building wheels for collected packages: zeroconf, regex, MarkupSafe, argon2-cffi-bindings, sgmllib3k Building wheel for zeroconf (pyproject.toml) ... \ also the other two ssh terminal was freezed but the IP address (wired and wlan) was reachable, no toher SSH sessions was possible. i powered off the board and restarted i tried to reinstall octoprint ( OctoPrint/bin/pip install OctoPrint ) but it is very very slow during compiling phase always here during Building wheels for collected packages: zeroconf, regex, MarkupSafe, argon2-cffi-bindings, sgmllib3k Building wheel for zeroconf (pyproject.toml) ... \ i restarted again, same issue, i tried to swapoff the virtual memory , the ccl process use one core at 100% root@orangepizero:~# armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq Tcpu C.St. 00:20:24 1296 MHz 1.11 26% 1% 24% 0% 0% 0% 54.0 °C 0/7 00:20:29 1296 MHz 1.10 25% 0% 25% 0% 0% 0% 54.4 °C 0/7 yesterday with the old version buster the installation taken 10 minutes more or less today one hour is gone and it continues to build..... can anyone help me ? the bash shell is responsive, apt also. the SD card seems to sleep...... here there are the logs https://paste.armbian.com/zenupusire bye
  3. i apology but for some misteryous issue i lost completly the network, using nmtui i added only the IP gateway on my wired connection and after that i lost completly the network, i also mounted the SD on a ubuntu but all seems fine. but no network. after that i reimaged a new SD card with last armbian/noble release , and wifi connection works. i need to reinstall all OctoPrint sw. without IP gateway i cannot install armbianmonitor. i think we can close this thread if i cannot resume at least the wired connection. the next steps could be to disable Network Manager , can any one has a guide to perform this task using the SD mounted on a another machine ? bye
  4. hi all, i had a orange pi zero board that worked fine until yesterday. MY BOARD IS ORANGEPI ZERO (not 2) i upgraded the OS armbian : Linux orangepizero 6.6.31-current-sunxi #1 SMP Fri May 17 10:02:40 UTC 2024 armv7l GNU/Linux the board worked fine until the last reboot in order to test octopi startup, but before this reboot the OS was upgraded and rebooted the issue now is that the wlan0 seems to be always down i do a lot of setup but it still to remain down, i am not a very expert with these board but i am very new with this kind of issue. can anyone help me with the troubleshooting ? i can access the board via LAN (eth0) i can show some details: root@orangepizero:~# lsmod Module Size Used by xradio_wlan 110592 0 mac80211 643072 1 xradio_wlan cfg80211 606208 2 mac80211,xradio_wlan rfkill 20480 2 cfg80211 libarc4 12288 1 mac80211 sun4i_gpadc_iio 12288 0 ch341 16384 1 industrialio 57344 1 sun4i_gpadc_iio usbserial 36864 3 ch341 sun8i_thermal 12288 0 uio_pdrv_genirq 16384 0 uio 16384 1 uio_pdrv_genirq cpufreq_dt 16384 0 usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm g_serial 12288 0 libcomposite 49152 2 g_serial,usb_f_acm ip_tables 20480 0 x_tables 24576 1 ip_tables autofs4 36864 2 pwrseq_simple 12288 1 sunxi 12288 0 phy_generic 16384 2 sunxi ac200_phy 12288 1 root@orangepizero:~# sudo iwlist wlan0 scan wlan0 Interface doesn't support scanning : Network is down root@orangepizero:~# nmcli dev wifi list IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY root@orangepizero:~# ifconfig -a .................................................. wlan0: flags=4098<BROADCAST,MULTICAST> mtu 1500 ether 0a:5e:7a:3c:fa:2a txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 now i had this error but before was different: root@orangepizero:~# ifup wlan0 RTNETLINK answers: Invalid argument ifup: failed to bring up wlan0 root@orangepizero:~# rfkill list all 0: phy0: Wireless LAN Soft blocked: no Hard blocked: no the network interfaces was not touched before this issue, yesterday i only upgraded OS , python3 and octopi. i prefer don't reimage the OS..... i observed that the wlan0 MAC changes at every reboot. many thanks i pologize if i posted into orangepi zero 2 section
