zcrself
1 Follower
  1. my bricked tvbox into fel mode, Using linux-fexi tools, I tested my usb2ttl on my tvbox , without any output. I do not know why? Test command: https://github.com/linux-sunxi/sunxi-tools sunxi-fel -p write 0x4000 uart0-helloworld-sdboot.sunxi (succeed) sunxi-fel -p exec 0x4000 picocom -b 115200 /dev/ttyUSB0
  2. My USB2TTL is tested on other tvbox such as Amlogic tvbox, works
  3. No works, UART output null. I think that UART is disabld by OEM. because a working tvbox , UART also output is null
  4. thanks a lot, I will try it soon
  5. @rafman pmic is axp1530 via device info HW app
  6. @macros muniz try this: https://www.123865.com/s/96P8Vv-KmR0H Code: cNU2 No repaired @noelobo try this: https://www.123865.com/s/96P8Vv-KmR0H Code: cNU2
  7. Using imgRePacker and simgtoimg to extract apk files from a img
  8. @rafmanAlmost succeeded. The progress reached about 70% evpad5s.txt evpad6p.txt
  9. @rafman I try the three images, no progress. I think that TRANSPEED IMAGE is not suitable for my TV box
  10. @rafman I flash the firmware of T95 into my h616 tvbox. It does be successful. but my tvbos can't boot, I am confused about this。 The successful flashing log is attached t95-rom-to-h616.txt
  11. @rafman I think that the memory of my tvbox is made by Micron Technology. Because the ID of memory is "5LE77 D9QL" and The storage of 32G is made by Kimtigo Technology
  12. I flash this image using tools named "PhoneixUSBPro" and "PhoenixSuit". All do be not success. The debug logs is attached as follow PhoneixUSBPro_V4.0.0 PhoenixSuit_V1.19 burn.log
  13. I have tried two imgs which you compiled, still no working and black screen
