Vidhome
8 -
On my TV box X88 pro 10 128 GB (Armbian 24.11.0-trunk.321 6.11.4-edge-rockchip6), the driver does not work when set to led-config 2. After studying, I performed several operations and everything worked. Maybe it will help someone!! In armbian-config, install led-config 2 and wlan-ap6334 next 1. dtc -I dtb -O dts /boot/dtb/rockchip/overlay/rockchip-rk3318-box-led-conf2.dtbo -o /root/rk3318-box-led-conf2.dtso 2. In the /root/rk3318-box-led-conf2.dtso file, edit reg = <0x24> to <0x0> 3. dtc -I dts -O dtb -f /root/rk3318-box-led-conf2.dtso -o /boot/dtb/rockchip/overlay/rockchip-rk3318-box-led-conf2.dtbo Wi-Fi and Bluetooth are working, the display is working too, but for some reason the lan and power symbols are mixed up. I solved it through the display service file display-service.txt
2
Good afternoon jock! I'm asking for your help again. The X88 pro 10 128 Gb(X88 PRO-B-RK3318-D4-V1.6) box does not want to work with an LED screen. Arabian-config led-config2 is set, the screen does not respond. There is no display folder in the /sys/class/leds directory. When installing the led-config5, the service works, the check starts, but the display does not light up at all! How do I set it up? Box H96 max It works great on this version and led-config5. 4.036378] spi_gpio i2c-aux-display: cs36 >= max 1 [ 4.036421] spi_master spi0: spi_device register error /i2c-aux-display/aux-display-controller@24 [ 4.036471] spi_master spi0: Failed to create SPI device for /i2c-aux-display/aux-display-controller@24 v24.11 rolling for RK3318 Box running Armbian Linux 6.11.5-edge-rockchip64 Packages: Debian stable (bookworm) Support: for advanced users (rolling release) Performance: Load: 32% Up time: 12 min Memory usage: 17% of 3.88G CPU temp: 59°C Usage of /: 6% of 114G I attached a photo of the led display chip (the outputs from the led display go to it) AIP16283BT35 (maybe it tm1628 ?) IMG_4802.heic
I tried, it didn't take off, only after these steps it works.
Jock thank you for your work! Everything worked on my H96Max RK3318. The sequence was as follows: 1. switch to beta repository in armbian-config or by changing apt.armbian.com to beta.armbian.com in /etc/apt/sources.list.d/armbian.list 2. run apt update and upgrade at least the kernel, dtb and armbian-bsp-cli-rk3318 packages, then reboot, run armbian-config (Software->Hardware->and on led-conf5) 3. apt install git make linux-headers-edge-rockchip64 -y 4. git clone https://github.com/jefflessard/tm16xx-display.git; cd tm16xx-display; ln -s /boot/System.map-`uname -r` /lib/modules/`uname -r`/build/System.map 5. make install The clock is ticking, the indicators are working. After the Homeassistant docker.
Thanks Jock! Do I have an H96Max RK3318 set-top box, will this firmware work?
Hi, my attempt to compile using the Haven openwfd driver method leads to errors. Why is this happening? make[1]: Entering directory '/usr/src/linux-headers-6.11.0-edge-rockchip64' CC [M] /root/linux_openvfd/driver/openvfd_drv.o /root/linux_openvfd/driver/openvfd_drv.c:44:7: warning: "CONFIG_AMLOGIC_LEGACY_EARLY_SUSPEND" is not defined, evaluates to 0 [-Wundef] 44 | #elif CONFIG_AMLOGIC_LEGACY_EARLY_SUSPEND | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c: In function ‘register_openvfd_driver’: /root/linux_openvfd/driver/openvfd_drv.c:400:75: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body] 400 | pr_dbg("%s: Succeeded to add openvfd module \n", __func__); | ^ /root/linux_openvfd/driver/openvfd_drv.c: At top level: /root/linux_openvfd/driver/openvfd_drv.c:622:19: warning: no previous prototype for ‘gpiochip_find’ [-Wmissing-prototypes] 622 | struct gpio_chip *gpiochip_find(void *data, | ^~~~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c: In function ‘gpiochip_find’: /root/linux_openvfd/driver/openvfd_drv.c:629:35: error: passing argument 2 of ‘gpio_device_find’ from incompatible pointer type [-Werror=incompatible-pointer-types] 629 | gdev = gpio_device_find(data, match); | ^~~~~ | | | int (*)(struct gpio_chip *, void *) In file included from ./include/linux/of_gpio.h:14, from /root/linux_openvfd/driver/openvfd_drv.c:36: ./include/linux/gpio/driver.h:641:39: note: expected ‘int (*)(struct gpio_chip *, const void *)’ but argument is of type ‘int (*)(struct gpio_chip *, void *)’ 641 | int (*match)(struct gpio_chip *gc, | ~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~ 642 | const void *data)); | ~~~~~~~~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c: At top level: /root/linux_openvfd/driver/openvfd_drv.c:669:5: warning: no previous prototype for ‘evaluate_pin’ [-Wmissing-prototypes] 669 | int evaluate_pin(const char *name, const unsigned int *vfd_arg, struct vfd_pin *pin, unsigned char enable_skip_evaluation) | ^~~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c:752:6: warning: no previous prototype for ‘get_pin_from_dt’ [-Wmissing-prototypes] 752 | void get_pin_from_dt(const char *name, const struct platform_device *pdev, struct vfd_pin *pin) | ^~~~~~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c:763:5: warning: no previous prototype for ‘request_pin’ [-Wmissing-prototypes] 763 | int request_pin(const char *name, struct vfd_pin *pin, unsigned char enable_skip) | ^~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c:1034:19: error: initialization of ‘void (*)(struct platform_device *)’ from incompatible pointer type ‘int (*)(struct platform_device *)’ [-Werror=incompatible-pointer-types] 1034 | .remove = openvfd_driver_remove, | ^~~~~~~~~~~~~~~~~~~~~ /root/linux_openvfd/driver/openvfd_drv.c:1034:19: note: (near initialization for ‘openvfd_driver.<anonymous>.remove’) cc1: some warnings being treated as errors make[3]: *** [scripts/Makefile.build:244: /root/linux_openvfd/driver/openvfd_drv.o] Error 1 make[2]: *** [/usr/src/linux-headers-6.11.0-edge-rockchip64/Makefile:1926: /root/linux_openvfd/driver] Error 2 make[1]: *** [Makefile:224: __sub-make] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-6.11.0-edge-rockchip64' make: *** [Makefile:5: modules] Error 2
