Benjamin Sonntag
  1. Thanks @ozacas ! I was wrong inded! root@orangepi5-plus:~# aplay -C -l **** List of CAPTURE Hardware Devices **** card 0: Analog [Analog], device 0: fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0 I guess that's an answer Also as a reply to @Werner : I will retry the kernel 6.1.75 vendor armbian image but when I tested it armbian-config didn't propose any overlay apart from a GPU thingy. no hdmirx uart or others.
  2. Sadly "alsa" does not exist as a command on Debian 😕 (I took the bookworm armbian initially) I just tested with the "Armbian 24.8.1 Noble Gnome" image, (kernel 6.1.75) but it has no support for hdmi input / hdmirx at all ... I then tested with the "Ubuntu 24.04 (Noble) / Gnome" image using kernel 6.10, dated August 2024 and I found that "alsa" command in the alsa-base package, present in Ubuntu but deleted long ago on Debian. This command basically tries to unload alsa module and reload them no change on my orange pi 5 plus when I did that, (I confirmed that the HDMI input had a signal before reloading, via dmesg saying "fdee0000.hdmi_receiver: hdmirx_wait_lock_and_get_timing: signal lock ok, i:2 ") root@orangepi5-plus:~# alsa force-reload Unloading ALSA sound driver modules: snd-soc-rockchip-i2s snd-soc-simple-card snd-soc-rockchip-i2s-tdm snd-soc-es8328-i2c snd-soc-simple-card-utils snd-soc-es8328 snd-soc-simple-amplifier snd-soc-core snd-compress snd-pcm-dmaengine snd-pcm snd-timer (failed: modules still loaded: snd-soc-simple-card snd-soc-rockchip-i2s-tdm snd-soc-es8328-i2c snd-soc-simple-card-utils snd-soc-es8328 snd-soc-simple-amplifier snd-soc-core snd-compress snd-pcm-dmaengine snd-pcm snd-timer). Loading ALSA sound driver modules: snd-soc-rockchip-i2s snd-soc-simple-card snd-soc-rockchip-i2s-tdm snd-soc-es8328-i2c snd-soc-simple-card-utils snd-soc-es8328 snd-soc-simple-amplifier snd-soc-core snd-compress snd-pcm-dmaengine snd-pcm snd-timer. sadly no hdmi audio input ... root@orangepi5-plus:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Analog [Analog], device 0: fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0
  3. Hi everyone, I just received an "orange pi 5 plus" and I wanted to use the hdmi-input feature in it. I installed armbian and added the hdmirx overlay, and now I can use ffmpeg or gstreamer to stream video input. Good. Alas, I see no alsa hdmi input card. I tried to search for some settings but didn't find any... The only information I found on this feature are here https://github.com/armbian/linux-rockchip/blob/rk-6.1-rkr3/arch/arm64/boot/dts/rockchip/rk3588-orangepi-5-plus.dts do you have any pointer to give me on how to enable this feature? (I know how to compile stuff, using Linux since 1998 ) thanks for any help / pointer you can give me ❤️ BS.
